Re: What are you guys using to clean your trailer??
[Re: joshking440]
#705983
05/25/10 09:54 AM
05/25/10 09:54 AM
Challenger 1
Cincinnati, Ohio
If no one here has used the blue beacon truck wash for there truck and trailer, they are missing out. If you are getting ready to do a spring clean on the trailer, I suggest you give them a try. I know they are nation wide. The trailer will come out looking like new, and they use 100% reverse osmosis water, so no water spots, even on a black rig!!!
I have used them in the past many times while on the road. They do nice work and fast, But make sure they don't use the alkaline cleaner on your polished aluminum, it will put a haze on your polished aluminum. It polishes back out but is more work to get rid of the haze.
Like I said above, do the roof of your trailer or RV first so the sides stay cleaner longer, otherwise it will streak again after the first rain. Been there, done it many times.
[Re: Plumb Wired]
#705984
05/25/10 10:05 AM
05/25/10 10:05 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Chris, like mentioned previously the "Awesome" product from the dollar store works well. A good coat of wax will help prevent some of the streaking in the future. ![](/ubbthreads/images/graemlins/Twocents.gif)
Mike Gray
Yeah I forgot to say that in my 2 days of cleaning it I also did a coat of wax... I just used spray on floor wax after the cleaning... worked well ![](/ubbthreads/images/graemlins/wave.gif)
[Re: dusturbd340W5]
#705987
05/25/10 07:19 PM
05/25/10 07:19 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
This is the best stuff I have found to use. Was at Division race a few years ago and watched a guy clean his trailer in no time with this stuff. http://www.cleanyourtrailer.net [/quote
at 35.00 a gallon it better clean the trailer while I am sitting on the couch drinking a cold one
Yeah, I still have a gallon jug sitting on the shelf.....you can have for half price....wasn't impressed in the least, yeah it works, but it takes a lot elbow grease also.....try the totally awesome and you won't ever spend 30 bucks a gallon again when $6 a gallon will just wipe the black off ![](/ubbthreads/images/graemlins/Twocents.gif)
Rickster
