Re: What are you guys using to clean your trailer?? [Re: Plumb Wired] #705982
05/25/10 09:36 AM
05/25/10 09:36 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
If no one here has used the blue beacon truck wash for there truck and trailer, they are missing out. If you are getting ready to do a spring clean on the trailer, I suggest you give them a try. I know they are nation wide. The trailer will come out looking like new, and they use 100% reverse osmosis water, so no water spots, even on a black rig!!!
Re: What are you guys using to clean your trailer?? [Re: joshking440] #705983
05/25/10 09:54 AM
05/25/10 09:54 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have used them in the past many times while on the road. They do nice work and fast, But make sure they don't use the alkaline cleaner on your polished aluminum, it will put a haze on your polished aluminum. It polishes back out but is more work to get rid of the haze.
Like I said above, do the roof of your trailer or RV first so the sides stay cleaner longer, otherwise it will streak again after the first rain. Been there, done it many times.
Re: What are you guys using to clean your trailer?? [Re: Plumb Wired] #705984
05/25/10 10:05 AM
05/25/10 10:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Chris, like mentioned previously the "Awesome" product from the dollar store works well. A good coat of wax will help prevent some of the streaking in the future.
Mike Gray
Yeah I forgot to say that in my 2 days of cleaning it
I also did a coat of wax... I just used spray on
floor wax after the cleaning... worked well
Re: What are you guys using to clean your trailer?? [Re: MR_P_BODY] #705985
05/25/10 10:38 AM
05/25/10 10:38 AM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
This is the best stuff I have found to use. Was at Division race a few years ago and watched a guy clean his trailer in no time with this stuff.
http://www.cleanyourtrailer.net
Switched to the dark side...
Re: What are you guys using to clean your trailer?? [Re: JSR1485] #705986
05/25/10 11:15 AM
05/25/10 11:15 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
[/quote
at 35.00 a gallon it beter clean the trailer while I am sitting on the couch drinking a cold one
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: What are you guys using to clean your trailer?? [Re: dusturbd340W5] #705987
05/25/10 07:19 PM
05/25/10 07:19 PM
Lehigh Acres, Florida
rickstershemi Offline
[/quote
at 35.00 a gallon it better clean the trailer while I am sitting on the couch drinking a cold one
Yeah, I still have a gallon jug sitting on the shelf.....you can have for half price....wasn't impressed in the least, yeah it works, but it takes a lot elbow grease also.....try the totally awesome and you won't ever spend 30 bucks a gallon again when $6 a gallon will just wipe the black off
Rickster
Re: What are you guys using to clean your trailer?? [Re: rickstershemi] #705988
05/25/10 09:51 PM
05/25/10 09:51 PM
Richmond , Virginia
BEEQUIK Offline OP
BEEQUIK  Offline OP
Richmond , Virginia
Thanks guys !! I will get some awesome cleaner from the dollar store and give it a whirl,I have not done the roof and will need to do that.
Re: What are you guys using to clean your trailer?? [Re: BEEQUIK] #705989
05/25/10 09:58 PM
05/25/10 09:58 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Make sure you float plenty of water while cleaning up on top. If "Awesome" even comes close to drying, it is hard to remove the "clean streaks". Plus, it strips any protective finish from the aluminum panels, so wax on, wax off. All and all, enclosed trailers are a P I T A.
Re: What are you guys using to clean your trailer?? [Re: Leigh] #705990
05/25/10 10:22 PM
05/25/10 10:22 PM
Russiaville, IN
mopar376d Offline
mopar376d  Offline
Russiaville, IN
Have used awesome a long time. Found something better a guy let me try. It is called "Fastball" I am about out of it and need to find some more.
spray fastball on and wipe it with a rag and it will even remove the clean streaks or stains. Before I was buffing them out.
Best stuff I have ever seen.
Why does divorce cost so much? Because it is worth it!!!!!
Re: What are you guys using to clean your trailer?? [Re: mopar376d] #705991
05/26/10 05:56 AM
05/26/10 05:56 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
