Re: 512 Assembly Is Under Way!!
[Re: tboomer]
#703144
05/20/10 11:49 AM
05/20/10 11:49 AM
Thumperdart
State of confusion
Gotcha ![](/ubbthreads/images/graemlins/thumbs.gif) You do what ya gotta do.......... ![](/ubbthreads/images/graemlins/biggrin.gif) All I can say is , HANG ON...... ![](/ubbthreads/images/graemlins/beer.gif)
[Re: tboomer]
#703145
05/20/10 11:52 AM
05/20/10 11:52 AM
Posts: 2,177 ill
dennismopar73
ill
what is the bank account number ha ha ![](/ubbthreads/images/graemlins/burnout.gif) went to the track tue to test new 543 in 67 coronet wasnt good news 1 run all kinds of bugs this motor has been a curse if had time i would detail it but that is off topic ![](/ubbthreads/images/graemlins/2231195-dggif.gif)
[Re: Thumperdart]
#703146
05/20/10 11:53 AM
05/20/10 11:53 AM
Posts: 2,648 GA
Boosted
GA
Cool my 512 is in th works also.... Should be driving it next month
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
[Re: tboomer]
#703150
05/20/10 06:02 PM
05/20/10 06:02 PM
Posts: 12,339 somwhere
smokinwoody
somwhere
A second mortgage comes to mind....
and the left and right side of the anatomy...
[Re: 451Mopar]
#703154
05/21/10 03:24 AM
05/21/10 03:24 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
I think the stroker kit is around $2,000? Heads with good springs/retainers/rockers $3,000+? Roller cam/lifters/timming chain/pushrods $1,000? Intake/carb $1500? Oil pan/pump/windage tray Maybe $500? machine work $1000-$1500?
So maybe $9,000 if you can do the assembly and reuse ignition/water housing and pump/pulleys/radiator and exhaust?
Add some trick parts or porting and I'm sure the cost will go up. You may be able to do it a bit cheaper too, but I think it would be difficult at the 700 range without compromising durability? The place where you could save some $$$ is if you can get a good used intake and carb and/or oil pan?
naaa... your way high on those numbers ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 451Mopar]
#703155
05/21/10 09:17 AM
05/21/10 09:17 AM
Posts: 2,177 ill
dennismopar73
ill
$1400 storker kit new heads new , $1499 block used $200 bare? cam new $300,with lifters intake ,new $250 machine work around $900 stud kit $150 gaskets $350 with cametic?? oil pan w pickup $150 water pump housing aluminum ,$125 water pump $30 total $5285.99 just a rough guess you can get it done around the $4800 area ![](/ubbthreads/images/graemlins/2231195-dggif.gif) am i close enough ![](/ubbthreads/images/graemlins/2231195-dggif.gif)
[Re: 493_DART]
#703156
05/21/10 10:26 AM
05/21/10 10:26 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
There may be some margin in the numbers for small stuff like gaskets and hardware ![](/ubbthreads/images/graemlins/thumbs.gif)
I could go get all my bills and add them up to see the actual cost, but I did my build over a few years and for two engines so I would need to seperate out the costs of each engine.
[Re: dennismopar73]
#703157
05/21/10 10:34 AM
05/21/10 10:34 AM
451Mopar
Aurora, Colorado
That sounds more like a 500 HP engine? You would be limited to the springs/retainers of the $1500 heads, and $300 for cam/lifters limits you to a flat tappet cam?
[Re: 451Mopar]
#703158
05/21/10 12:28 PM
05/21/10 12:28 PM
Posts: 26,022 United Socialist States of Ame...
tboomer
Here is some costs...Sure I will forget something.. Muscle Motors 512 kit...2029.00 Block...Don't know...It was Jimmys,I have to replace it with another.. Machine shop...Over 500.00 New roller cam and springs bought from Russ(Old Racer) 160.00..Profiled at Comp Cams..40.00 Roller lifters,stud kit,new oil pump,bronze drive and other stuff from Summit Racing..Around 1000.00..I already have the MP heads,M-1 intake and carb..Static pickup from the Source..55.00. New Mallory billet dual point Dizzy...20.00 from a swap meet guy..Also thru in a low deck Uni-lite..(needs repair)..This is just a few things I remember...There will be more stuff,I am sure... The look on my face when I drop the hammer the first time...Priceless,Baby!! I am very stoked about this build and Jimmy is a professional on his builds! He can build anything at his shop but prefers Mopars!! I strongly reccomend him for anyone needing chassis work,engine builds or tranny work.. ![](/ubbthreads/images/graemlins/thumbs.gif)
