Mechanical advance too quick on Mopar Perf Dizzy?
#703080
05/20/10 10:42 AM
05/20/10 10:42 AM
Posts: 1,226 Cookeville
Chilort
Will Work For Mopars
Cookeville
I've put a Mopar Performance dizzy in my 440 (.40 over, Eddy heads, around 9.2:1 compression, 60303 cam, 16* initial, 34* all in). I am getting a part throttle rattle at higher engine speeds (75mph with a 2.76:1 gear ... sorry, no tach). The engine builder seems to think it is detonation especially since it seems to get more sensitive as the engine warms up. It doesn't sound like any kind of ping or rattle I've hear heard. And it doesn't make the noise at or near full throttle. I pulled the initial back from 18/36 this morning to the 16/34 I listed above. It still does it. And yes, I pulled the vacuum advance hose off and plugged it to make sure it wasn't the vacuum advance (I've also gone 2 turns CCW with the adjustment in the vacuum canister). The engine builder gave me a bag full of springs to try out but they look to be for the older Mopar Performance Dizzy based upon what I can find here with the search function. So, here's a picture of the springs that are in the dizzy now. What would you do? ![](http://farm5.static.flickr.com/4021/4624379474_6ff9f793f5_o.jpg) ![](/ubbthreads/images/graemlins/smilie_help.gif)
Re: Mechanical advance too quick on Mopar Perf Dizzy?
[Re: Chilort]
#703081
05/20/10 12:37 PM
05/20/10 12:37 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
You can see the heavier spring in the top, is slotted, so it doesn't do anything initially. two springs like the toher one would like help the problem.
You can probably get some thing that will work at a local speeed shop. just ignore the applications on the packages. I have found gm pre hei springs work well on these.
You could grind a little off the weights too if you like, but with the long slotted spring you have, it won't help. AND there isn't a lot to the weights in those anyway, so if take much off, it becomes hard to get springs that are light enough.
[Re: Chilort]
#703091
05/20/10 11:43 PM
05/20/10 11:43 PM
RapidRobert
unhook/plug the vac adv hose and see if it pings @ 16/32 or 18/34. If it stop pinging I'd go back to 18/34 (assuming the eng/cam likes 18 inital) and go more CCW on the vac can and probably need a can w a smaller #. ![](/ubbthreads/images/graemlins/Twocents.gif) Holler back. Also what rpm is the mech all in at?
[Re: Chilort]
#703093
05/21/10 01:41 AM
05/21/10 01:41 AM
dave571
It could be that part of it is a mixture issue. A quick look at the cam specs, if I was curving one for you, with that much gear, I wouldn't bring it all in till 3400.
You can do more initial, than where you are at. I think your starting at 18 was probably ok.
I think 18 initial, with 34 total(16 mechanical), all in by 3400 would be a good start. Then do some plug reading, and see where you're at with your mixtures.
What converter are you using? that cam would seem to like around 3K or so.
[Re: Dodgem]
#703095
05/21/10 10:57 AM
05/21/10 10:57 AM
Chilort
Cookeville
The carb is a Holley 750 (80508S). I don't remember what the stock jets were but I did go up a size or two. Thanks for all the help. I may install a heavier spring in the dizzy this evening. But I likely won't get to test it out. I don't trust Atlanta drivers as it is and then add rain on top of that and it is a bad combo. Here's a picture of a spark plug from when I pulled them out to replace them with the Autolites. Of course, this is after driving it normally for a few miles while trying to test the effects of the things I've been doing and not a check after running it hard. And the converter is a TurboAction - 17805S (10").
[Re: Chilort]
#703096
05/21/10 01:32 PM
05/21/10 01:32 PM
dave571
After a normal cruise, and that much cam, it should be a lot more brown than that. Bump it two jets up on each end, after you do the timing mods, and look again. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: dave571]
#703097
05/21/10 01:45 PM
05/21/10 01:45 PM
Chilort
Cookeville
With that carb I can only change the primary (I think it is the primary) jets. It came with 70s and I put 72s in it. So I need to go with 74s? Edit: I ran the picture of the plug by the engine builder and he likes the color. I've always heard it should be a little brown too but he says his "gas man" says the plug should be the same color as when it came out of the box.... my new Autolites are black, so, I don't think I want that. ![](/ubbthreads/images/graemlins/frowwn.gif) (some things can be taken too literally).
