Page 1 of 3 1 2 3
Is Shell Rotella the oil of choice...?? #702774
05/19/10 10:14 PM
05/19/10 10:14 PM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
...for a flat tappet these days?? Got a new cam from Bullet with a moderate bee-hive spring but don't want to take any chances.
Re: Is Shell Rotella the oil of choice...?? [Re: cudadoug] #702775
05/19/10 10:16 PM
05/19/10 10:16 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Brad Penn
Re: Is Shell Rotella the oil of choice...?? [Re: 69CHARGERMD] #702776
05/19/10 10:22 PM
05/19/10 10:22 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
I agree with Doc! Brad Penn,the "Green Oil"! Semi-synthetic,and good amount of zinc and phosphorous for flat tappets to survive! RandyB.
Re: Is Shell Rotella the oil of choice...?? [Re: Labratt] #702777
05/19/10 10:24 PM
05/19/10 10:24 PM
Mt.Vernon ,Ohio
VernMotor Offline
Happy Birthday VernMotor  Offline
Mt.Vernon ,Ohio
I have use the rotella 15-40 for the last 3 years..
Re: Is Shell Rotella the oil of choice...?? [Re: cudadoug] #702778
05/19/10 10:27 PM
05/19/10 10:27 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
I forget the hi-zinc code .. but the last time I checked a couple of stores ..... like Menards .... they had-it in Rotella.
Isn't that Brad Penn stuff real pricey ?
Re: Is Shell Rotella the oil of choice...?? [Re: dOoC] #702779
05/19/10 10:29 PM
05/19/10 10:29 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
NAPA sells Valvoline NFS (Not for Street Use) Racing oil. It is the best I have found. Reasonable too.
Re: Is Shell Rotella the oil of choice...?? [Re: Leon441] #702780
05/19/10 10:30 PM
05/19/10 10:30 PM
ill
dennismopar73 Offline
ill
i run mobil 1 10 w 30
Re: Is Shell Rotella the oil of choice...?? [Re: Leon441] #702781
05/19/10 10:35 PM
05/19/10 10:35 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
NEVER heard of this one .....what makes it NFS ? .... do they sell it in 5 gallon pails like Tractor Supply does ? ...
Re: Is Shell Rotella the oil of choice...?? [Re: dOoC] #702782
05/19/10 10:40 PM
05/19/10 10:40 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
what makes it NFS
marketing...same as most of the other "wiz-bang" oils. save your money, get educated about oil. i learned a little working in the lubes service center for a well known refiner
http://www.bobistheoilguy.com/cms/
Re: Is Shell Rotella the oil of choice...?? [Re: jamesc] #702783
05/19/10 10:48 PM
05/19/10 10:48 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
what makes it NFS
Marketing ? .... OK by me .... I F ... it is priced-right, has lots-o-zinc, is a major brand .....
They could call it WIZ-bang or whatever they choose !
Re: Is Shell Rotella the oil of choice...?? [Re: dOoC] #702784
05/19/10 11:05 PM
05/19/10 11:05 PM
jamesc Offline
jamesc  Offline
nfs has 1400 ppm zinc same as their regular racing oil and i believe the same (or close enough) to the shell oil mentioned
Re: Is Shell Rotella the oil of choice...?? [Re: jamesc] #702785
05/19/10 11:13 PM
05/19/10 11:13 PM
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
I was under the impression that the Rotella(which is a very good oil)had lowered zinc content for emissions!???
Re: Is Shell Rotella the oil of choice...?? [Re: jamesc] #702786
05/19/10 11:16 PM
05/19/10 11:16 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
anyone ever heard of the rottella containing a lot of ASH? and leaving these deposits in the chamber?
Re: Is Shell Rotella the oil of choice...?? [Re: Labratt] #702787
05/20/10 12:09 AM
05/20/10 12:09 AM
jamesc Offline
jamesc  Offline
i'm not advocating any particular oil, or slamming any. there's just a TON of marketing that goes on in the lubrication business. i don't claim to be any expert but i saw this FIRST hand and was somewhat shocked at the time. lubricants have to meet certain specifications imposed by both the government and API. if an oil has a given certification it must meet the specifications for that certification. not all oils had their ZDDP levels reduced the same amount depending on their rating. for the most part all oils had to reduce their content of certain additives. to make up for this they modified their additive packages in an effort to offset the loss of the restricted ones. below is a link to little info from an article. the link i posted to the BITOG is probably the best place to become somewhat educated about lubricants. afaik the shell turbo t is still around 1400ppm
oil
Re: Is Shell Rotella the oil of choice...?? [Re: jamesc] #702788
05/20/10 12:28 AM
05/20/10 12:28 AM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I like the Rotella 15-40 with a bit quart of Lucas. I pick it up at Advance and use these $10 off $25 coupons.
http://advancegrandopenings.com/admin/contest/enter#
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Is Shell Rotella the oil of choice...?? [Re: 69dart] #702789
05/20/10 01:35 AM
05/20/10 01:35 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I've run the 15/40 for years no problem, this year i want to try a 10/30 so going with Brad Penn
Re: Is Shell Rotella the oil of choice...?? [Re: cudadoug] #702790
05/20/10 07:03 AM
05/20/10 07:03 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
The newer Rotella is not the same as the old stuff.
Re: Is Shell Rotella the oil of choice...?? [Re: Challenger 1] #702791
05/20/10 07:39 AM
05/20/10 07:39 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Z-Alt Musclecar Oil is very good also.
http://www.z-alt.com/
Re: Is Shell Rotella the oil of choice...?? [Re: cudadoug] #702792
05/20/10 09:02 AM
05/20/10 09:02 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
For diesel trucks maybe. For race cars it's Brad Penn.
Re: Is Shell Rotella the oil of choice...?? [Re: Labratt] #702793
05/20/10 09:04 AM
05/20/10 09:04 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I can still get the original formula.
Page 1 of 3 1 2 3
