Re: 91 Spirit...speedo and odometer not working...
[Re: dusturbd340W5]
#70200
06/10/08 08:17 PM
06/10/08 08:17 PM
Posts: 6,022 Morningside
AdventurerSport
waaaay out there in left field
Morningside
My '91 Acclaim did that a few years ago...no speedo/odo, no code, but changed the sensor and been fine ever since...almost 80,000 miles ago...:)
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red 06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II 06 Chrysler 300C AWD 5.7L Hemi 10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI 10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI 11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red 16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
[Re: AdventurerSport]
#70201
06/11/08 10:50 PM
06/11/08 10:50 PM
Posts: 93 Anacortes, WA
russ71satellite
Anacortes, WA
just checked for codes, and I'm getting a 38. this is a 3.0L. Does anyone know what this code is? Also, when I turn the key quickly to read the code, occasionally the speedo needle pegs, then goes back down. What does that mean?
71 Satellite Sebring, all stock 1989 Dodge Daytona, daily driver 2008 PT Cruiser
[Re: russ71satellite]
#70202
06/12/08 10:21 PM
06/12/08 10:21 PM
russ71satellite
Anacortes, WA
bump...
speedo needle bounces and pegs while I turn key to read codes...any ideas what that means?
#70203
06/13/08 09:27 AM
06/13/08 09:27 AM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
shop key shows 38 being lock up control problem
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#70204
06/13/08 11:16 PM
06/13/08 11:16 PM
russ71satellite
Anacortes, WA
Replaced the speed sensor today, but no help...
[Re: burdar]
#70206
06/13/08 11:25 PM
06/13/08 11:25 PM
russ71satellite
Anacortes, WA
the gear looks good. It was of course attached to the old sensor, but I checked it and clipped it onto the new sensor.
#70207
06/16/08 09:54 AM
06/16/08 09:54 AM
Posts: 3,547 stratford,ontario,canada
JD340
Hey Russ, it's the Hijacker here. Messed around with my Neon the better part of Saturday. New speed sensor=NO change. Started tearing into gauge cluster. Poor connection between cluster and dash wiring. Gave terminals a little twist to improve connection. Result: still intermittent at best. Built up terminals with a little solder. Same result! Maybe there is a break in the wiring somewhere. I haven't found it yet! I feel your frustration with this. We probably put 10-15 miles on the car, on the hoist trying to find the "sweet" spot where the speedo would run consistently. If we ever trace it down, I'll give you a heads up.
Nothing to see here. Carry on.
