Re: Interior Nearing Completion
[Re: 412 SB Duster]
#701823
06/01/10 07:39 PM
06/01/10 07:39 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Little update........progress is slow with me wiring a car. So far, I have the starter relay, MSD box, Dedenbear delay, tail lights, fuel pump, Biondo RPM switch for air shifter and line lock wired and tested. A lot of zip-ties.
[Re: S/ST 3040]
#701828
06/01/10 07:56 PM
06/01/10 07:56 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
wow, you gotta carpet in there! I like it, but how come you have it in there? (I may end up using some in my car just for driving on the street to keep some of the noise and heat down) Your car's coming along! wont be long now.
[Re: Dunnuck Racing]
#701829
06/01/10 08:04 PM
06/01/10 08:04 PM
S/ST 3040
How much weight did all the carbon fiber decals add?The Vic I know would never add all that weight just for looks!
I can't imagine it added 3 lbs. for everything that gets covered. The old 340 will never know the difference.
Post deleted by Defbob
[Re: Mrs.Hitman]
#701834
06/03/10 06:04 PM
06/03/10 06:04 PM
[Re: S/ST 3040]
#701835
06/03/10 06:11 PM
06/03/10 06:11 PM
#701836
06/03/10 10:28 PM
06/03/10 10:28 PM
S/ST 3040
Whose carbon did you use ? I have Neffy and the 3m DI NOC getting ready to start this weekend
Fred....I think this carbon fiber print is on Oracal vinyl. I'm not sure of name brand for the actual design?? If I'd used the wrap on the exterior, they said I'd probably have to get the 3M vinyl. I went with the cheaper stuff.
[Re: S/ST 3040]
#701837
06/03/10 10:44 PM
06/03/10 10:44 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Very nice Vic... Im at the same point as you on the wiring, that crap always goes slower than I think it should. But this is the first time I have taken the extra step to make sure all ends are perfect and even shrink wraped..... Very nice looking car your going to have.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#701838
06/03/10 10:55 PM
06/03/10 10:55 PM
S/ST 3040
Thanks Bob. If I ever have to do this again, I'll start with about 6 rolls of different colored wire and plan a little better. A few more wires and we can put the dash in and start on something held together with bolts.
[Re: S/ST 3040]
#701839
06/03/10 11:22 PM
06/03/10 11:22 PM
B1Fish540
Flint, Michigan
I had carpet in it before........It just looks better in there. (covers up the ugly.)
Vic, my bad, I forgot you had stock floors. wiring does'nt look like much fun...but your work looks good!
