Re: Interior Nearing Completion
[Re: VIPERDUST]
#701850
06/08/10 11:14 PM
06/08/10 11:14 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Looks incredible! Those 340's are fun and indestructible.
[Re: VIPERDUST]
#701851
06/09/10 09:18 AM
06/09/10 09:18 AM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Hey Vic, could you get me the info on all the parts needed to install an air shifter in mine? Looks good. Matt
Dedenbear has a kit for the Turbo Action shifter. Summit Part number......DED-AS-1K
From what I can tell, it comes with C02 bottle, regulator, air solenoid, tubing and Dedenbear RPM switch. Several companies carry RPM switches. You can even use an MSD RPM switch and change the pills.
I got a Biondo RPM-2SHIFT so I could set my shift points for 2-3 shift different from 1-2 shift. ACD may be that way too but, I don't know for sure.
