Page 2 of 3 1 2 3
Re: 500cfm for a 440? [Re: AndyF] #70046
06/09/08 04:31 PM
06/09/08 04:31 PM
NASCAR guys make a ton of power with 390 cfm carbs, of course they have a few tricks but they are really 390 cfm carbs.
I think a 500 cfm carb will work just fine on a street driven 440. The power would be down a little bit at WOT but probably not more than 10 or 20 hp from a 750 or 850 carb. This is assuming it is a street motor with a mild cam and pump gas compression.
their also runnin 358cid engines too. I don't think a comparison can be made.
they'll be the first to admit there down a butt load of hp with 390 Holley's.
Figure about 50+hp down when compared to 850cfm Holley. even with a "mild"
cam and pump gas.
Re: 500cfm for a 440? [Re: moper] #70047
06/09/08 04:45 PM
06/09/08 04:45 PM
united kingdom
Simonic Offline
Simonic  Offline
united kingdom
check it out and see what happens
Keeping the Bee Buzzin'
Re: 500cfm for a 440? [Re: dave571] #70048
06/09/08 04:46 PM
06/09/08 04:46 PM
Jersey shore
Gary67 Offline
super street
Gary67  Offline
super street
Jersey shore
I'm conservative as far as carb size goes.
I even run a 625 road demon and my 440 tow rig winni, and find it is a great carb....
BUT 500 is way to small.
I remember I had a 600 eddy on a 400 with some mods. Threw on a 750, and saw a 30 wheel hp gain on a g tech.
I agree with running both.
I'm of the same thinking..I have an 800dp on my 66, I had a larger carb to use but am sticking with the smaller one. I definately would do larger than 500cfm on a street car, but it doesn't have to be an 850 to run well either...
Re: 500cfm for a 440? [Re: mark7171] #70049
06/09/08 04:50 PM
06/09/08 04:50 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
TQ arent cool, they'll never catch on.
the sportier carter would be the AVS.
the hollies DP750 on 440 will kick some butt. the 800 AVS will keep up, and is much easier to tune.
AVS has a longer pumpshot good for highway gears too. for cruising the avs wins.
are you talking about the new 800 eddy? ummm it will not keep up w/ a good 750DP.
Re: 500cfm for a 440? [Re: Mr.Yuck] #70050
06/09/08 05:40 PM
06/09/08 05:40 PM
Stick it on there! A Mopar six pack has a 350CFM center carb--that is the one you run on all the time UNLESS you floor it!--yea it is small and won't be as good as a bigger one when you kick it but I bet you would be amazed at the throttle response! Later when you find a deal on something else do it! AED in Richmond Va. builds one of the best DP Holleys for the $$---available from many dealers that discount them some and they come with AMAZING customer service
Re: 500cfm for a 440? [Re: Mr.Yuck] #70051
06/09/08 05:43 PM
06/09/08 05:43 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
what does keep up mean ? it supplies fuel on demand, yes.
you burn Oxygen.
on a build that wouldnt require the dual pumps volume, it would win...
Re: 500cfm for a 440? [Re: ] #70052
06/09/08 05:46 PM
06/09/08 05:46 PM
one CANNOT compare a 6-bbl setup to a single four. BOTTOM line
is that a 500cfm 4-bbl is TOO small for a 440. but hey..
if you wanna give up 50+hp a very little fuel economy.. go for it.
Re: 500cfm for a 440? #70053
06/09/08 06:46 PM
06/09/08 06:46 PM
Yea--it is too small but I bet you could drive it from Canada to Cape Horn if you wanted to.
Re: 500cfm for a 440? [Re: ] #70054
06/09/08 06:58 PM
06/09/08 06:58 PM
sure. i could do it with a 125cfm one barrel too, or a 1050 dominator.
Re: 500cfm for a 440? [Re: Alexdodge] #70055
06/09/08 08:45 PM
06/09/08 08:45 PM
Eastern ohio
Alexdodge Offline OP
Eastern ohio
Well I put in an order with summit on Sunday evening for the eddy 800. After reading all these messages, hope I did the right thing.
Thanks all, Alex
Re: 500cfm for a 440? [Re: mark7171] #70056
06/09/08 08:46 PM
06/09/08 08:46 PM
Heart of Ohio
4boxers4 Offline
4boxers4  Offline
Heart of Ohio
W/ AVS! and best mpg, if some care. Performance is why I like it, mpg is nice side effect. TQ is ok.
there is an equation to determine proper cfm but obviously 2bbl's work(especially 3 of them!)
Persistance is omnipotent Durability Engineer, Chair and Couch division...
Re: 500cfm for a 440? [Re: Alexdodge] #70057
06/09/08 09:21 PM
06/09/08 09:21 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
excellent thats what i have on my 440's action + top end... a edelbrock thunder AVS800. works great, i put the spring loaded high flow needle and seats in ,and checked the float level. the rods and jets are a snap to tune in. easier than a holley, but im more familiar with holley's. the carb is the best AVS unit i ve worked with.
make sure you know how to set the high idle on the choke and it will start right up.
the mechanical secondary kick in nicely on a 440.
my other 440 top end is a 750 SD demon on a RPM intake. that runs rich low, but fine top end.
i tried the dominator single and it was terrible on the street. ..nuff said.
Re: 500cfm for a 440? [Re: 4boxers4] #70058
06/09/08 09:25 PM
06/09/08 09:25 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
the equation is bogus. it doesnt account for actual effeciency. it takes a standard and applies it to many.
most charts i see show a number thats 80% of what you really need.
my dart wants big carbs. i put a 770 street avenger on it with a stiff spring , and its happy. the 600 was too small ? the 600 edelbrock was alright, and responded better up top.
Re: 500cfm for a 440? [Re: mark7171] #70059
06/09/08 09:36 PM
06/09/08 09:36 PM
Heart of Ohio
4boxers4 Offline
4boxers4  Offline
Heart of Ohio
Are you saying your AVS (Thunder) doesn't work well with the Street dominator manifold? I always found it to be one of the best combo's out there. I have a manual tranny though so it is easy to launch.
Well the fact that there are some assumptions necessary is the reason to use the equation for volumetric efficiency as a guideline, but the equation itself isn't what I would call bogus. in a controlled environment, it carries some legitimacy. It just isn't that easy to control your street car.
Re: 500cfm for a 440? [Re: Supercuda] #70060
09/19/08 09:43 AM
09/19/08 09:43 AM
united kingdom
Simonic Offline
Simonic  Offline
united kingdom
[quote
IMO, a double pumper is a great way to waste gas on a street car.
Re: 500cfm for a 440? [Re: Simonic] #70061
09/19/08 09:47 AM
09/19/08 09:47 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
[quote
That's because you don't know how to tune it...lol
any 4bbl carb will be a waste if you foot is heavy. and why would you have a 440 and care about mpg's? FWIW I managed to get 13mpg hwy in a 67 coronet (440) w/ 3.91's doing 70.
Re: 500cfm for a 440? [Re: moper] #70062
09/19/08 10:16 AM
09/19/08 10:16 AM
united kingdom
Simonic Offline
Simonic  Offline
united kingdom
The amount of misinformation on this board about carb sizing is staggering. Any performance carb will supply "enough gas" to mix with the air that can flow through the carb. The 500 cfm carb will support about 300 horsepower. That's using the rule of thumb of 0.6 hp per cfm.
Thousands of 413s ran millions of hours with two-barrel carburetors, pumping water and performing other industrial tasks. As I have said in a previous post my family car in the early '70s was a 2-barrel 455 olds which would run 90 in the quarter and would top out over 100 mph, the fastest indicated speed I ever saw was about 122 but the stock speedometer could have been lying too. (Growing up in North Dakota had its advantages in that there was hardly ever a cop around on the roads I drove.) The carb on that car was the larger Rochester two-barrel which I doubt flowed more than 375 cfm rated as a two-barrel carb, which would be about 265 rated as a 4-barrel.
Keep in mind also the thousands of dirt track racers using the Holley 4412 500 cfm 2-barrel, which would be 353 cfm rated as a 4-barrel.
Stick on a 500 instead of a 750 and you are leaving about 100 top end hp on the table. This power loss should all be above the torque peak. The car will run really strong until it "runs out of breath" which will be a disappointment but will not be accompanied by any expensive noises. Try it and see what you think. You can always buy a bigger carburetor later.
R.
Especially with that misinformation part..
Re: 500cfm for a 440? [Re: Simonic] #70063
09/19/08 05:43 PM
09/19/08 05:43 PM
dogdays Offline
dogdays  Offline
I'm such a stud!
R.
Re: 500cfm for a 440? [Re: Supercuda] #70064
09/19/08 06:40 PM
09/19/08 06:40 PM
BRawls Offline
super gas
BRawls  Offline
super gas
A good running 440 will love a 750 DP. Your choice of makes. IMHO, anything less than a750 dp will cause your 440 to stumble and fall when you floor it, as it screams for more gas. scott
A six pack screams on 2 barrels, until the outboarbs kick-in. You are only going to notice a small carb holding you back on the top end. Low end will be a blast to drive, it's not going to stumble if it's tuned properly.
Re: 500cfm for a 440? [Re: BRawls] #70065
09/19/08 06:49 PM
09/19/08 06:49 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
THIS topic deserves a one-liner ....... Better to be UNDERcarbed ...than over.
Page 2 of 3 1 2 3
