Re: 500cfm for a 440?
[Re: AndyF]
#70046
06/09/08 04:31 PM
06/09/08 04:31 PM
NASCAR guys make a ton of power with 390 cfm carbs, of course they have a few tricks but they are really 390 cfm carbs.
I think a 500 cfm carb will work just fine on a street driven 440. The power would be down a little bit at WOT but probably not more than 10 or 20 hp from a 750 or 850 carb. This is assuming it is a street motor with a mild cam and pump gas compression.
their also runnin 358cid engines too. I don't think a comparison can be made. they'll be the first to admit there down a butt load of hp with 390 Holley's. Figure about 50+hp down when compared to 850cfm Holley. even with a "mild" cam and pump gas.
[Re: dave571]
#70048
06/09/08 04:46 PM
06/09/08 04:46 PM
Posts: 1,367 Jersey shore
Gary67
super street
super street
Jersey shore
I'm conservative as far as carb size goes. I even run a 625 road demon and my 440 tow rig winni, and find it is a great carb....
BUT 500 is way to small.
I remember I had a 600 eddy on a 400 with some mods. Threw on a 750, and saw a 30 wheel hp gain on a g tech.
I agree with running both.
I'm of the same thinking..I have an 800dp on my 66, I had a larger carb to use but am sticking with the smaller one. I definately would do larger than 500cfm on a street car, but it doesn't have to be an 850 to run well either...
[Re: mark7171]
#70049
06/09/08 04:50 PM
06/09/08 04:50 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
TQ arent cool, they'll never catch on.
the sportier carter would be the AVS.
the hollies DP750 on 440 will kick some butt. the 800 AVS will keep up, and is much easier to tune.
AVS has a longer pumpshot good for highway gears too. for cruising the avs wins.
are you talking about the new 800 eddy? ummm it will not keep up w/ a good 750DP.
[Re: Mr.Yuck]
#70050
06/09/08 05:40 PM
06/09/08 05:40 PM
Stick it on there! A Mopar six pack has a 350CFM center carb--that is the one you run on all the time UNLESS you floor it!--yea it is small and won't be as good as a bigger one when you kick it but I bet you would be amazed at the throttle response! Later when you find a deal on something else do it! AED in Richmond Va. builds one of the best DP Holleys for the $$---available from many dealers that discount them some and they come with AMAZING customer service
[Re: ]
#70052
06/09/08 05:46 PM
06/09/08 05:46 PM
one CANNOT compare a 6-bbl setup to a single four. BOTTOM line is that a 500cfm 4-bbl is TOO small for a 440. but hey.. if you wanna give up 50+hp a very little fuel economy.. go for it.
#70053
06/09/08 06:46 PM
06/09/08 06:46 PM
Yea--it is too small but I bet you could drive it from Canada to Cape Horn if you wanted to.
[Re: ]
#70054
06/09/08 06:58 PM
06/09/08 06:58 PM
sure. i could do it with a 125cfm one barrel too, or a 1050 dominator.
[Re: Alexdodge]
#70057
06/09/08 09:21 PM
06/09/08 09:21 PM
Posts: 1,261 ILL
mark7171
ILL
excellent thats what i have on my 440's action + top end... a edelbrock thunder AVS800. works great, i put the spring loaded high flow needle and seats in ,and checked the float level. the rods and jets are a snap to tune in. easier than a holley, but im more familiar with holley's. the carb is the best AVS unit i ve worked with.
make sure you know how to set the high idle on the choke and it will start right up.
the mechanical secondary kick in nicely on a 440.
my other 440 top end is a 750 SD demon on a RPM intake. that runs rich low, but fine top end.
i tried the dominator single and it was terrible on the street. ..nuff said.
[Re: 4boxers4]
#70058
06/09/08 09:25 PM
06/09/08 09:25 PM
Posts: 1,261 ILL
mark7171
ILL
the equation is bogus. it doesnt account for actual effeciency. it takes a standard and applies it to many.
most charts i see show a number thats 80% of what you really need.
my dart wants big carbs. i put a 770 street avenger on it with a stiff spring , and its happy. the 600 was too small ? the 600 edelbrock was alright, and responded better up top.
[Re: Supercuda]
#70060
09/19/08 09:43 AM
09/19/08 09:43 AM
Posts: 216 united kingdom
Simonic
united kingdom
[quote IMO, a double pumper is a great way to waste gas on a street car. ![](/ubbthreads/images/graemlins/iagree.gif)
Keeping the Bee Buzzin'
[Re: Simonic]
#70061
09/19/08 09:47 AM
09/19/08 09:47 AM
Mr.Yuck
Brookeville, Md
[quote
That's because you don't know how to tune it...lol any 4bbl carb will be a waste if you foot is heavy. and why would you have a 440 and care about mpg's? FWIW I managed to get 13mpg hwy in a 67 coronet (440) w/ 3.91's doing 70.
[Re: Simonic]
#70063
09/19/08 05:43 PM
09/19/08 05:43 PM
dogdays
[Re: Supercuda]
#70064
09/19/08 06:40 PM
09/19/08 06:40 PM
BRawls
super gas
super gas
A good running 440 will love a 750 DP. Your choice of makes. IMHO, anything less than a750 dp will cause your 440 to stumble and fall when you floor it, as it screams for more gas. scott
A six pack screams on 2 barrels, until the outboarbs kick-in. You are only going to notice a small carb holding you back on the top end. Low end will be a blast to drive, it's not going to stumble if it's tuned properly.
