Re: Traction Problems......looking for suggestions
[Re: tywebb2]
#698828
05/19/10 10:25 PM
05/19/10 10:25 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
I also think your sitting too high for maximum traction. I have a 73 Challenger street car with 440 4 speed. Superstock rear springs clamped in the front. I'm certainly no expert and haven't really tried to tweak my suspension yet. I have small block torsion bars that are not cranked up. Shocks are stock with extentions on the rear. First picture is the car launching on ET Streets. Second picture is the car sitting in the staging lanes. It really stretches out at launch and has pulled the front tire a few times. Best time of 11.83 on a very close to stock 440. ![](http://i260.photobucket.com/albums/ii4/71rtchallenger/challistrip.jpg)
[Re: KillerBee]
#698829
05/19/10 10:34 PM
05/19/10 10:34 PM
Posts: 2,177 ill
dennismopar73
ill
[Re: dennismopar73]
#698830
05/19/10 10:41 PM
05/19/10 10:41 PM
KillerBee
N.E. Ohio
might go faster if youre window was up all the way
LOL. When I was going up to the line the bolt on the window crank came loose and I couldn't roll it all the way up. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: KillerBee]
#698831
05/19/10 10:49 PM
05/19/10 10:49 PM
Posts: 1,221 Jarrettsville, MD
tywebb2
super gas
super gas
Jarrettsville, MD
...and they let you run without a helmet?
'72 440 Cuda 11.673 @ 115.91 w/1.663 60'
[Re: tywebb2]
#698832
05/19/10 10:53 PM
05/19/10 10:53 PM
KillerBee
N.E. Ohio
The pics posted were taken at my local 1/8 mile track but I didn't have a helmet or a cage for that matter when I was running at the 1/4 track either. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: tywebb2]
#698833
05/19/10 11:06 PM
05/19/10 11:06 PM
Posts: 598 NC, USA
davenc
NC, USA
I have been puzzled some by the 5" rise recommendation. I fully appreciate the need to maximize the front end rise. However, solely lowering the front of the car to get that result seems over simplified.
If the front end of the car drops below a neutral, level stance (horizontal), then in a static sense you are pulling weight off of the rear. Obviously that weight can be transferred back onto the rear as the front end lifts back up to the horizontal stance. Does such a motion (back to attaining a level, horizontal stance) actually help traction?
It seems to me that the recommendation should be to maximize lift above a level, horizontal stance. This would be accomplished by increasing total front suspension rise distance thru techniques like reducing the snubber height, and making sure the shock is long enough to not be the limiting factor.
Obviously the faster the rise, the quicker the tires could try and bite. The weight needs to get on the rear tires before they spin, since traction (coefficient of friction) on a spinning tire is less than one that is not.
I realize that some may say, "then why not crank up the torsion bars and put as much weight on the rear in the static stance?". I think the answer to that lies in the dynamics of the motion. Without any ability to rise further in the front, any body stance changes in the rear could result in harsh shocks to the body, which could potentially upset the equation.
Those are the thoughts I have pondered about for some time regarding front end rise. Anyone care to comment on why these are valid/invalid ways of looking at it?
[Re: tywebb2]
#698835
05/19/10 11:34 PM
05/19/10 11:34 PM
BradH
Captain Budget...is there any chance you could post a pic of your car...
[Re: BradH]
#698836
05/20/10 09:06 PM
05/20/10 09:06 PM
tywebb2
super gas
super gas
Jarrettsville, MD
I got to mess around with the Cuda tonight. It appears I did have the front drivers side cranked up a bit. I measured to the top center of the wheel well lips. I took measurements before and after putting the original small block torsion bars back in it.
L Front: 27 3/8" (before) 25" (after) R Front: 26 13/16" (before) 25" (after)
L Rear: 29 9/16" (before) 29 1/16" (after) R Rear: 27 15/16" (before) 28 1/4" (after)
Before I made the switch, when I jacked up the front end to see what my suspension travel was getting a measurement of 30 1/8" on the left side and 29 5/8" on the right side. So there was 2 3/4" travel on the drivers side and about 2 3/4" travel on the passenger side. I didn't recheck to see what the max height number was after the changes up front. I will have to do that tomorrow.
[Re: BradH]
#698838
05/21/10 07:06 PM
05/21/10 07:06 PM
tywebb2
super gas
super gas
Jarrettsville, MD
Well I put the rear springs in the upper mounting hole today and readjusted the front end using the upper pivot of the lower control arm as the measuring point. I ended up with the following:
L Front: 25 3/4" R Front: 25" L Rear: 29" R Rear: 27 1/8"
It measured 7" from the bottom of the K-frame to the floor and I get around 9 1/2 - 9 3/4" from the upper pivot in the LCA to the ground. Measuring the rake it is level to 1* nose down on both sides.
While this did lower the car front and back the car still sits really lopsided. Basically the whole right side of the car sits much lower than the left. Is this much "tilt" to be expected with the SS springs? If so...I may switch to the Caltracs set-up just for the fact that I would like to level the car out?
[Re: tywebb2]
#698839
05/21/10 07:10 PM
05/21/10 07:10 PM
tywebb2
super gas
super gas
Jarrettsville, MD
I have a set of ESPO (+1" I think) leaf springs for my car that I bought before I raced it. Would these springs work with Caltracs or would there be an advantage going with the mono-leaf?
[Re: tywebb2]
#698840
05/21/10 08:54 PM
05/21/10 08:54 PM
Posts: 16,934 NC
440Jim
NC
Depending on the front tire diameter (26"?), that still sounds high to me. Just a little. If you have 28" front tires, maybe not.
[Re: 440Jim]
#698841
05/21/10 09:38 PM
05/21/10 09:38 PM
tywebb2
super gas
super gas
Jarrettsville, MD
The front tire diameter works out to be 27.1" for what its worth.
The problem I had with setting it down any lower is that the frame is sitting down on the LCA bumpers. The way I have it set now I have about 1/2" or better between the frame and the LCA bumpers which the Mopar Chassis Manual recommended. I am not sure if cutting down the bumper is an option or if that would cause other problems?
[Re: tywebb2]
#698842
05/21/10 09:48 PM
05/21/10 09:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Cut the LCA bumpers down some(take a 1/2" off) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: tywebb2]
#698843
05/21/10 09:56 PM
05/21/10 09:56 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
i missed posting on this thread earlier..i was reading.. i have read alot of recommendations... at a risk of confusing the situation.. first..i am gonna say.. after looking at all of your posted videos.. your right rear tire is loosing traction first.. you can see it almost all of the launches..and its exaggerated..in one of the burnouts.. the car drives right out of the hole ..and your steer it back to the left. I was gonna suggest/ask about your routine in air pressure settings for the rear tires.. if one tire has more air..it could be the cause of this.. (if we rule air pressure out) next..is preload.youve mentioned you measured the car at 4 corners..ill have to go back and try to decipher what you changed and what you had. but.. Pre load or more ride height in the right front can unload the right rear..causing this loss of traction..and drive out to the right. trying to keep things simple so you dont get lost... i need to re-read what youve done..and changed.
before i do this..i will mention..moving the front spring eyes up..i doubt will fix anything.. rear ride height doesnt concern me that much.right now.. however..you dont have alot of action on the rear of the car..it doesnt extend (rebound) when torque is applied..this needs to be addressed. this comes from pinion angle.. i fear moving the spring eye up will raise the i/c and it definately moves the pinion in the wrong direction...based on where you say it is now. i will pace my comments ...so as not to confuse.
so.. 1 vote for the softer tortion bars...(and a tad lower front ride height..ie suspension rise. 2.fix pinion angle. 3.change out the rear shocks with more/adj. rebound. (please explain your tire pressure routine.) cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: tywebb2]
#698844
05/21/10 10:25 PM
05/21/10 10:25 PM
Posts: 526 NC
barracuda man
NC
Went to the track today and I couldn't get the car to hook all day. I recently advanced the cam 8* and my current set-up just can't handle the extra torque.
1972 Cuda 440 Mopar Super Stock Springs Mopar Rear Drag Shocks 4:10 gears 28" Mickey Thompson ET Street Radials Comp Eng Adjustable Front Shocks (set on 90/10) Front sway bar unbolted
I messed with tire pressure but with no luck. Started at 20psi (where it I always used to run without any problems) then did 18psi..then 15psi...then 13psi...then back to 15psi. 15psi worked the best but I could still feel it spinning.
Launching at around 2,000rpm.
Best run today was 11.814 @ 115.10 w/a 1.701 60'.
Do you think regular drag slicks would do any better? How about a Caltracs system....or are there any other recommendations?
This is what you do.Take the upper bump stop out to get full travel.get some cal-vert front 90/10s.for the rear don't waste your money on the ranchos.The plan jane truck shocks from autozone works the best or keep the mopar shocks.Trust me i've been there.The super stock springs/cal-vert split mono leafs/cal-tracs.I went with a ladder bar set up and a big tire.It hooks Now. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: barracuda man]
#698845
05/21/10 10:47 PM
05/21/10 10:47 PM
tywebb2
super gas
super gas
Jarrettsville, MD
As for the tire pressures....I check them before ever run when I am in the staging lanes and both rear tires are always the same (i.e. 20, 18, 15, etc.) so we can rule that out. Now that you mention it....whenever I do a burnout the ass end of the car always slides to the left on me. I am not sure if this is something in my technique or in the suspension set up but it does prevent me from doing any pro-mod style burnouts ![](/ubbthreads/images/graemlins/laugh2.gif) I think the biggest issue is that I had the front of the car jacked up too high. I remembered today while I was under the car that one of the reasons I did this was to get the steering linkage to clear the #2 primary tube. I put a call in to a local chassis guru that also does headers and he is going to fix this problem for me near the end of June (hopefully). I will trim a 1/2" off the LCA bumpers per Mr P Body's recommendations. I think I also saw a low-profile bumper that I could use for the UCA. I would like to have something up there so it doesn't just slam down metal-to-metal. I already swapped the small block torsion bars back in it last night so I am all set there. I will get a set of the Calvert 90/10's for the front and am still debating the Ranchos for the rear. I just like the idea that they are adjustable for fine tuning. $40.00 for std. Monroe truck shocks or $178 for 9-way adjustables? Did moving the rear springs to the uppper mounting hole in the front do more harm than good? It dropped the car a little lower in the rear but are there adverse effects when doing this?
[Re: BradH]
#698847
05/22/10 03:43 PM
05/22/10 03:43 PM
tywebb2
super gas
super gas
Jarrettsville, MD
With the SS springs there are 5 leafs on the left(drivers) side and 6 leafs on the right (passengers) side. Why is it then that the right side sits lower? I would have thought that with the extra leaf the right side would sit higher and that would be the side you would want higher since the front left would want to rise and twist the car forcing down on the right rear?
