Traction Problems......looking for suggestions
#698768
05/15/10 09:47 PM
05/15/10 09:47 PM
Posts: 1,221 Jarrettsville, MD
tywebb2
super gas
super gas
Jarrettsville, MD
Went to the track today and I couldn't get the car to hook all day. I recently advanced the cam 8* and my current set-up just can't handle the extra torque.
1972 Cuda 440 Mopar Super Stock Springs Mopar Rear Drag Shocks 4:10 gears 28" Mickey Thompson ET Street Radials Comp Eng Adjustable Front Shocks (set on 90/10) Front sway bar unbolted
I messed with tire pressure but with no luck. Started at 20psi (where it I always used to run without any problems) then did 18psi..then 15psi...then 13psi...then back to 15psi. 15psi worked the best but I could still feel it spinning.
Launching at around 2,000rpm.
Best run today was 11.814 @ 115.10 w/a 1.701 60'.
Do you think regular drag slicks would do any better? How about a Caltracs system....or are there any other recommendations?
'72 440 Cuda 11.673 @ 115.91 w/1.663 60'
Re: Traction Problems......looking for suggestions
[Re: tywebb2]
#698770
05/15/10 10:06 PM
05/15/10 10:06 PM
Posts: 6,653 Near Reading PA USA
pinkduster
Near Reading PA USA
I assume you were the orange Cuda at Cecil County today. ![](/ubbthreads/images/graemlins/shruggy.gif) I had the purple Road Runner. I saw your 11.81 pass today in the right lane. for what it's worth, I couldn't do much in the left lane today without spinning the tires. ![](/ubbthreads/images/graemlins/Twocents.gif) I think I only made one 11 second pass in the left lane, the rest were all in the right lane. Curious... Is that 440 a stock stroke? I had the ET street drag radials and couldn't hook up at all with them. I switched to the regular ET streets and I do much better, but traction is still iffy at best. The radials were a lot nicer on the street though. ![](/ubbthreads/images/graemlins/Twocents.gif) I'll be watching people's suggestions here as I have a similar setup. I haven't disconnected the swaybar. Does that even help? ![](/ubbthreads/images/graemlins/shruggy.gif) I had my best 60' time today... A 1.65 which is still nothing to get excited about. ![](/ubbthreads/images/graemlins/crazy.gif)
[Re: pinkduster]
#698773
05/15/10 10:28 PM
05/15/10 10:28 PM
tywebb2
super gas
super gas
Jarrettsville, MD
That was me. I wanted to stop over to see how you made out today but you were in the staging lanes when I was heading out. Funny...I used to have the bias ply ET Streets and switched to the radials. The bias plys seemed to make the car a little squirrely down the track and the radials seemed to hook better until today.
Yep...it's a stock stroke. 10:1 compression, Eddy heads, MP 509 cam, Eddy dual plane intake...nothing crazy.
Jimmy Halsey ran his pro-mod car down the right lane so I would have to think there was enough track prep to handle my car? I did talk to a couple other guys today that were having traction issues as well though?
Unbolting the sway bar is something that was suggested to me a couple years back. Back then I tried that along with 90/10 front shocks and Prostar wheels (vs. my old ralleyes) up front and saw some improvement. Not sure how much the swaybar did but I still unbolt it every time out. I figure it allows the front end to "move" more freely....right?
I would have been very happy with a 1.65 60' today.....I was searching for an 11.7 run but it was just out of reach.
[Re: tywebb2]
#698774
05/16/10 08:22 AM
05/16/10 08:22 AM
tywebb2
super gas
super gas
Jarrettsville, MD
The tires are 275/60/15 mounted on 15x8 prostars. As far as the contact patch goes, the tire shows even wear and nothing abnormal
Shouldn't the MT drag radial be able to handle an 11 second car? I don't use them for street driving. Just went with them because it seems the classes I run in require DOT approved tires.
Could it be as simple as the rear shocks? Can you give me any details on the Monroe shocks you are using that helped (i.e. part#, for what make model car, etc.)? Can anyone else give me details on what shocks they are running with their superstock springs?
[Re: tywebb2]
#698775
05/16/10 09:04 AM
05/16/10 09:04 AM
Posts: 2,177 ill
dennismopar73
ill
just because pro mod car ran doesnt mean ] the track is preped looking at the responces i d say the track wasnt preped at all or you guys dragged up water 11 sec cars should never have a prob hooking j m o super springs, etc ![](/ubbthreads/images/graemlins/2231195-dggif.gif)
[Re: tywebb2]
#698776
05/16/10 09:18 AM
05/16/10 09:18 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Track prep is huge especially on a sticky street. unhooking swaybar(better taking off) does help transfer a lot. lose the comp 3 ways for cal trac 90/10's. If you only race a few times a year you can swap front shocks in 20 minutes!! I would think a rancho shock from Cal trac may be an improvement set at 7 driver and 6 pass. Unclamping the back of your SS springs lets them fan a bit and lets the front sections work better. I used an extra full length leaf in my SS stack help hold the heavy GTX up and stiffened the front sections even more. All cal tracs stuff works. Most noticable improvement over the years was moving battery to rear pass side of the car! bigger burn outs! (less air always worked for me) Then on sticky streets I used to like to load the car hard 2700 with 4000 stall then stab it on last yellow but only 1/3 to 1/2 so it launched but did not break loose then feed the rest through the 60 foot. It's a talent and takes practice easier to do TT's then racing when the adrenilin is pumping! LOL!!! ![](/ubbthreads/images/graemlins/Twocents.gif) Oh yea with streets go around the water back up into just where it is damp and do 2 to 3rd gear burn out. water will stay up in the treads if you drive through and squeezes out on the track! Slicks are cool best chance of not spinning! LOL!
[Re: dennismopar73]
#698777
05/16/10 09:22 AM
05/16/10 09:22 AM
Quicktree
not really true imo. the ET of the car doesn't dictate wether it will hook or not. key to hooking is having a good shock so you can adjust if needed. cal trac and good shocks looks to be better than SS springs.
[Re: Quicktree]
#698778
05/16/10 09:47 AM
05/16/10 09:47 AM
Posts: 2,177 ill
dennismopar73
ill
stay with my original post, bad track pep street drag tires are a little more dicy but as all the post everyone had trouble hooking so slick track ![](/ubbthreads/images/graemlins/2231195-dggif.gif)
[Re: dennismopar73]
#698779
05/16/10 10:18 AM
05/16/10 10:18 AM
tywebb2
super gas
super gas
Jarrettsville, MD
There were plenty of cars there yesterday that were making great passes and didn't have any traction problems. That just leads me to believe that they have their cars set up right and I do not....right?
Anyway, I don't really want to throw a lot of money at this point so Caltracs would be a last resort. After doing a couple searches it seems like there are plenty of guys out there running SS springs with quicker cars than I have.
I am going to check my pinion angle first to see if that needs some adjustment. Maybe a set of those Rancho adjustable shocks unless someone else has a better recommendation? Adjustable would be nice so I can do some easy tweaking at the track if needed. I have read good and bad on the Caltracs 90/10 fronts so I am hesitant to spend the money on them.
I am not sure if this tells you anything or not but when my car launches both the front and rear appear to rise about the same amount so that the car looks like it is lifting straight off the ground...then it moves forward. My brother has a small block '73 Cuda and when he launches his front end lifts up and he gets a lot of rear squat. So it seems he is getting much better weight transfer. Of course he has a small block on the nose and I have the big block.
[Re: tywebb2]
#698780
05/16/10 11:00 AM
05/16/10 11:00 AM
Dodgem
Ontario, Canada
Yes the front not lifting fast enough and the rear too much is a problem. adjustable shocks set to resist separation help a lot Rancho set at 8 7 or 7 6. do try unclasping the rear of the spring last clamp should be right behind axle. Try the cal track 90/10 they are inexpensive and will work great. Take them off if you don't like street ride 20 minute job! Battery in trunk back of pass side is a must IMHO! http://calvertracing.com/rancho.phpeverything is available from Mancini's http://chucker54.stores.yahoo.net/catrbarsy1.html
[Re: tywebb2]
#698781
05/16/10 11:07 AM
05/16/10 11:07 AM
Posts: 2,530 PA
moparacer
PA
Maybe your hitting the tire too hard?
If the rear end is rising like the front end I bet its hooking initially then its spinning.
You can control that with rear shocks and spring clamps.
Best thing to do is video the car and post it so everyone can see what its doing.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: 440Jim]
#698783
05/16/10 01:25 PM
05/16/10 01:25 PM
tywebb2
super gas
super gas
Jarrettsville, MD
Battery is already in the trunk on the passenger side. I put it there when I resto'd the car so that has been a constant.
440Jim...what shocks are you running front and back?
Are most people running the adjustable rancho's in the rear and Calvert's 90/10's up front? I already change out the Comp front shocks when I race anyway. I run KYB gas adjusts on the street.
I have some video of each run yesterday and I will try to post it. I have never done that before so it may take me a while??
Re: 383man
[Re: 383man]
#698785
05/16/10 02:07 PM
05/16/10 02:07 PM
tywebb2
super gas
super gas
Jarrettsville, MD
Ron...I put an 8" ATI in it a couple years ago but last fall I switched back to my original 10" Turbo Action. I like the 10" much better on the street and the difference at the track was not significant enough to keep the 8" in it.
So when it comes to front shocks you want something that will extend easily and compress hard? When it comes to the rears you want something that is harder to extend in order to keep the rear from rising. Do I have this right?
Re: 383man
[Re: tywebb2]
#698787
05/16/10 03:57 PM
05/16/10 03:57 PM
Posts: 415 Peru
cbarracuda
Peru
use you torcion bar and go up at driver side
