Re: Questions about relocating the battery.
[Re: 64physhy]
#696126
05/14/10 01:51 PM
05/14/10 01:51 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
With only a two prong switch and a ford starter solinoid try this...
Oh the green wire is the wire that would normally go to the starter.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#696128
05/14/10 02:57 PM
05/14/10 02:57 PM
Posts: 154 Escondido, CA
64physhy
Escondido, CA
That one looks easy enough. The alt wire is still always going to be hot though. I guess it's always hot with a stock set-up too, isn't it? Thanks again for your patience and help. Where in So Cal are you? I plan on getting this thing to the Barona track sometime this summer.
[Re: 64physhy]
#696129
05/14/10 03:18 PM
05/14/10 03:18 PM
Posts: 7,759 So Cal
HealthServices
So Cal
I'm in orange county basically N. Tustin, one day I'll swing by Barona just to see what it is like.
Yes the alt will be hot always if routed that way.
Allen
#696131
05/14/10 03:50 PM
05/14/10 03:50 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
With just a two prong switch, you could mount 2 master switches and use a tandem link rod to switch them on and off. This way if you were to use Rob's version of wiring it would look something like this If I understand how Rob was saying it.
Yep that's it.
Allen, you becoming the master of photoshop? Nice work. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: RobX4406]
#696132
05/14/10 03:53 PM
05/14/10 03:53 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Thanks ![](/ubbthreads/images/graemlins/thumbs.gif) Actually this just using the paint program with Vista! But I am learning more stuff on photoshop, and now learning a little about moving gif. I started with these pictures... https://board.moparts.org/ubbthreads/show...part=1&vc=1
Allen
#696133
05/14/10 09:20 PM
05/14/10 09:20 PM
64physhy
Escondido, CA
Would it make a difference if I routed the power to the Disconnect Switch first, and then go to the Solenoid? In all the examples, it's going to the solenoid first, then to the switch. I'm using a Mac, or I'd draw I diagram on paint, but what I'm thinking is : Battery to disconnect Disconnect to solenoid Solenoid to Starter Starter to hot terminal on Relay Wire from Relay to Solenoid (Green Wire on above diagrams)
Pretty much the same as the examples, except going through switch first, and no running the hot wire for the relay all the way back. Will this do the same thing?
I've got the Alternator to Batt routed, and got a circuit breaker to put in line.
[Re: 64physhy]
#696134
05/14/10 09:27 PM
05/14/10 09:27 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Going to the battery side of the switch then to the solenoid, gives you more potential for voltage loss. Each additional spice and connection to the starter means more voltage loss at the starter.
This is why I put the cable going to the starter first then to the starter relay rather than the other way around. Less potential for voltage loss.
And with this way of thinking you could have one line go directly from the battery to the switch instead of from the battery to the solenoid and then to switch.
But at the same time I do not like a lot of connections at the battery itself, so using the battery side of the ford solenoid as a power take off is good.
Allen
#696135
05/14/10 09:36 PM
05/14/10 09:36 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Boy I'm loss as to which diagram you decided to use. ![](/ubbthreads/images/graemlins/laugh2.gif) I photochop a dual switch in place of the single I have. This will give you an idea what I mean by using two master disconnects. If you have a high amp alternator and want to disconnect it, this would work rather than using a very expensive high amp 4 prong disconnect.
Allen
#696138
05/14/10 11:07 PM
05/14/10 11:07 PM
Posts: 7,759 So Cal
HealthServices
So Cal
There is no wire from the starter to the mopar relay.
The only heavy wire you need is the one from the ford starter relay to the starter, and the ford starter relay to the battery.
Everything else can be lighter guage.
Allen
#696140
05/14/10 11:10 PM
05/14/10 11:10 PM
64physhy
Escondido, CA
Yeah, it was an idea I was kicking around until I realized that if I did it that way (not the way of the diagram, the way in my head), I would only have power when cranking because of the solenoid.
[Re: 64physhy]
#696141
05/14/10 11:11 PM
05/14/10 11:11 PM
Posts: 7,759 So Cal
HealthServices
So Cal
8 guage from alt to battery is good.
8 would be good from the master switch to the mopar starter relay as well.
14 would work for the starter signal.
Allen
[Re: 64physhy]
#696143
05/14/10 11:15 PM
05/14/10 11:15 PM
Posts: 7,759 So Cal
HealthServices
So Cal
eh, its alright I'm taking care of the little one today and work was slow. Keeps my mind going ![](/ubbthreads/images/graemlins/thumbs.gif) Make sure you jumper the two posts on the starter. These two if you use a mini starter.
Allen
