Re: Quench engine comparison
[Re: RoyceFlo73]
#695451
05/12/10 12:36 AM
05/12/10 12:36 AM
RapidRobert
the by far #1 adv of quench is that it lets you run a much higher static CR on the same octane that would ping on the same CR wo quench. CR is squeeze and squeeze is power. CR is one of the most important parameters of an engines power potential. It is what an engine is all about. I'd suggest getting an actual mocked up/measured twice .035-.040" (no more/no less) piston to head clearance in EACH hole. Takes alot of work to get it spot on. .035" is more efficient but requires minimal piston rock (tight P/W clearances) and dead on measuring so .040" is safer and very efficient. Is it a PITA? yes Is it worth it? absolutely
[Re: RoyceFlo73]
#695452
05/12/10 07:31 AM
05/12/10 07:31 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
David Vizard has written up a comparison experiment he did where he kept the compression ratio constant but altered the quench clearance. I can't remember whether it was in one of his books, http://www.amazon.com/s/ref=nb_sb_noss?u...amp;x=0&y=0or in a magazine article, but in a hazy way I seem to remember that Vizard claimed most of the horsepower gain benefit occurred by 0.060 inches total quench clearance. However, the theory is that less quench would have allowed the compression ratio to go up safely on the same octane fuel, which would have increased hp a bit more. The Internal Combustion Engine in Theory and Practice, Volumes I and II, by the father and son team both named Charles Fayette Taylor http://www.amazon.com/s/ref=nb_sb_noss?u...amp;x=0&y=0has several pages and a big graph devoted to General Motors research on quench clearance versus gasoline octane where detonation begins. If memory serves me right in contrast to David Vizard's finding, GM found more benefit kept being shown down to a quench clearance equivalent to 0.026 inches at a bore of 4.00 inches. The 0.026 number later stuck in my mind because in the magazine article 'Feeling Lightheaded' in 1999 High Performance Mopar about the Edelbrock aluminum SB Mopar V8 cylinder heads, McCandless wrote that he used 0.026 inches as the piston to deck height clearance of his test engine, which would make the total quench clearance that plus the compressed gasket thickness, and probably near the 0.060 that Vizard found. sample quote When it comes to choosing a suitable block, I prefer a '75 or earlier piece due to the extra material and strength of the castings. Our block was bored .060 over (371 cubes) and milled .010, just enough to clean up the deck surface and set the piston-to-deck-height at .026, the aluminum head's 65 cc's chambers, and using a Fel-Pro O-ring head gasket (sold through Mopar Performance) which adds 9 cc's of volume to each cylinder, the resulting compression ratio was 9.9:1. This was with a cast .060-over, flat-top piston with valve pockets I had custom made years ago
[Re: IcorkSOAK]
#695454
05/12/10 02:37 PM
05/12/10 02:37 PM
Posts: 374 CONNECTICUT
RoyceFlo73
CONNECTICUT
I've read that .040 in the average hot-rod engine is usually considered optimal. I've read that going any less than that is risky unless the rest of the engine (crank, main bearing journals, ect.) are machined. The theory being that, like stated, rods and/or pistons could be slighly loose and impact the head at higher RPMs. The .060 is interested because I've not read that anywhere else, but I will definatly look more into it. Thanks for all the information already. I think I may go talk to my mechanical engineering professor and see if he has any insight as well!
[Re: Frederick]
#695457
05/12/10 10:22 PM
05/12/10 10:22 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Quench just lets you run higher compression without detonation compared to the same non-quench engine. I'd guess it probably starts to become an issue around 10:1 compression (maybe lower with iron heads). My understanding the the quench or squish creates a much more turbulent air/fuel mixture inside the chamber and that delays/prevents detonation. Think like the difference between a category 1 hurricane compared to a category 5 hurricane, there's a lot more chaos going on with the 5 storm (maybe not the best analogy).
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
Re: 383man
[Re: mr_340]
#695460
05/13/10 12:27 AM
05/13/10 12:27 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
FWIW, I called Ross pistons a few weeks ago about having a set of flat tops I have cut for a dish. Reason being is so I could get 10 to 1 comp with a .040 quench. The guy at Ross (cant remember his name) asked me why I was wasting my time with trying to get a tight quench. He replied that trying to obtain a tight quench is more or less a waste of time, maybe 5hp or so. I told him I was more worried about detonation and again he told me a waste of time. He talked me into using .086 head gaskets with my flat tops to get down to 10 to 1 comp. So I dunno.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 383man
[Re: Von]
#695462
05/13/10 12:59 AM
05/13/10 12:59 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
The year I went to quench in my current combo, I gained 6 tenths. Same, cam, carb, gears, converter, etc.. The switch was 452, to 915.s Both home ported by me, with stock size valves. Most builders agree a full point of compression in a given combo is only worth 3%. Even if we say I gained a full point (after cc ing it, it was a little less than that) and tha I had 500 hp to begin with (which is debatable) I should have only gained 15 hp on the head swap. I also switched to 1.6/1.5 combo rockers at the same time. Again, builders say this swap isn't woth much. like 6 hp or less. There must have been something in the quench, cause 21 hp isn't giving up 6 tenths with a heavy pig, like my car .
[Re: 360view]
#695463
05/13/10 07:19 AM
05/13/10 07:19 AM
Posts: 8,162 USA
360view
USA
There is a section in one of the books ) about the Honda V-Tech engine, which originally was also lean burn. I remember that it listed the quench clearance as 0.75 mm, and I had to get out a calculator to figure: (1/25.4) times 0.75 = 0.0295 inches
If my memory is not faulty I think the Honda engineers wrote that the 0.0295 quench was necessary to both successfully get ignition on the 22 to 1 air to fuel ratio at part throttle, and to run at full throttle without detonation on 87 octane gasoline.
It certainly seems true that many engine manufacturers don't make the quench very tight even if the cylinder head has quench pads and the piston is either flat top or has an outer quench area. Quench is unquestionably designed in, because the pads are there, but not made very tight for some reason.
The 1995 Magnum 5.9 V8 seems to be about: 9.585-6.123-1.622-(3.578/2) = 0.051 inches in the hole plus the 0.0475 compressed gasket adding up to a whopping big 0.0989
Did Chrysler really need that much clearance to make up for sloppy factory tolerances?
Anyone know the tightest factory Chrysler engine quench clearance, at least the 'blueprint' value ?
Is it possible that in time carbon deposits naturally 'close up' the quench clearance to the minimum that does not hit?
I have also wondered how much thickness of carbon deposits is really built up on both metal surfaces of opposing quench pads in the real world, and if the surface roughness of the deposits either adds to, or takes away from the strength of the jets of gases shot out into the main combustion chamber.
On a racing engine using leaded gasoline I wonder if the lead deposits close up the quench clearance. Lead deposits certainly formed a hard coating at the valve seats in the old days.
Pollution-wise, I have read that too much total metal area for quench can lead to higher unburned hydrocarbons. Some fuel droplets get absorbed down into the tiny metal surface pits and does not burn when the quench is close together, then, as the fuel 'comes out of the sponge holes in the metal surface' in the second half of the power stroke this partially burned fuel goes out into the exhaust and has to be handled by the catalytic converter.
[Re: 360view]
#695464
05/13/10 11:30 PM
05/13/10 11:30 PM
Von
NE Oklahoma
I wasnt saying I agreed with the guy at Ross. Ive read too much suggesting that quench is valuable.
With that said, my current mota has about .150 quench (452s with a .045 gasket). Static compression is 10.5 to 1 and has no ping on pump premium with the timing at 34-35 degrees. At 38 I do get some pinging. The combo runs pretty good for what it is, ET/MPH in my sig.
Re: 383man
[Re: dave571]
#695465
05/13/10 11:38 PM
05/13/10 11:38 PM
Von
NE Oklahoma
So you dropped from 12.40s to 11.80s?
Any idea how the 2 heads compared on a bench?
I dont think you can say "concrete" that you got .6 from just quench.
Id think it would be everything put together gained you the .6. The cam liked the point of compression, maybe the 915s flowed better, (port work, valve job, etc) Maybe the whole combination just flat out "works" better now.
As far as the rockers go, on my current motor, my stuff ran almost .15 and and hair over 1 MPH faster just going from .022 to .016 on the intake lash. Nowhere near the same effect of going from 1.5 to 1.6 rockers. Just depends on the combo.
Re: 383man
[Re: dave571]
#695467
05/14/10 01:07 AM
05/14/10 01:07 AM
Posts: 6,109 Valencia, España
NachoRT74
Valencia, España
ok, maybe I'm still a lot confused about how to get a "quenched" engine, but after read some replies here:
how you can get a propper quench without affect ( reducing, keeping or increasing ) the CR ? I simply don't get it
Re: 383man
[Re: hooziewhatsit]
#695469
05/14/10 02:26 AM
05/14/10 02:26 AM
NachoRT74
Valencia, España
ok, nice thread, but I think not answered yet LOL for example, I got KB240s for my 400 ( flat tops/valve reliefs ). They supposelly sits around 015-020 down the hole. My block was decked due sleeves long time ago so maybe I can get closer to 015-010. then I got metallick gaskets what suposelly are rated on 020... then I got my engine almost quenched BUT I HAVE OPEN CHAMBERS. I can get ( and is what I have proyected to get 84-86 cc chambers and close to 9.5 CR ) maybe 045 milled down, but they will be still open with that job. lets say I'll get 070-080 total "quench" Ok, let say I use closed heads... I theorically will get the perfect quench on 040-050 rate. I'm UNVARIABILY CHANGING THE CR, I think is imposible not affect that, even slightly, making the heads change. or even milling down the open heads, not converting into closed chambers, what really affects engine geometry and valve to pistons clearence, but making a more radical heads mill down job definitelly CR will be affected!!! beside this, then it looks there is no way to get a perfect quenched engine on an open chambers head unless you raise over the block deck the piston... well another CR variable being affected at this moment then this reply: Quote:
Picture of a typical dished piston designed to obtain quench with a closed chamber yet retain a sane compression ratio...
BTW image was stolen from 440 Source Thanks Brandon, hope you don't mind...
hell WOW! a dished piston will afect total volume too so do the CR against a flat top or domed.
I think anything you build inside a cilinder affects the CR... more or less.
I get the quench deal, and I can understand some setups can be build to MAKE the quench, but I don't get how do you change anything on engine without change CR.
are open chambers heads owners far away from a good quenched engine built ?
Re: 383man
[Re: NachoRT74]
#695470
05/14/10 11:00 AM
05/14/10 11:00 AM
Von
NE Oklahoma
Sort of. You can use the pistons with a step pad on them to achieve quench with an open chamber head. KB has made them for 15 plus years.
But, to obtain a true uniform quench with open chamber heads (Im talking factory iron, the Eddy open chambers might be better) you (or your machinist) has to put the time in getting some sort of uniformity out of the chambers. The chambers wont be uniform from left to right, up down, etc, so to get a true quench the chambers have to be corrected, along with the castings being milled. Hope that makes sense.
I used (still have) a set of KB step pistons and didnt mess with correcting the chambers. Still didnt have a tight quench as the heads really needed milled .020 to be "correct". Had about .060 quench. Static compression was right at 10.5 and ran fine on pump 91.
FWIW, my current motor has the same heads that motor had, same intake, carb, etc. But, Different cam, headers, and converter. But, runs 1.1 seconds faster.
Re: 383man
[Re: Von]
#695471
05/14/10 11:44 AM
05/14/10 11:44 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Unfortunately the effect of quench, which is an affect from the movement of the intake charge, not the gap between parts, is very individualistic. It's the combination of parts and timing that makes more power. The piston to head clearance, combined with the piston shape and chamber design of a given haed all have to work together to get a good qeunching effect and all the bonuses that come along with it. Something to realize is the time a burn takes is directly related to the power that burn produces, and the faster the pressure spike that results from a faster burn, the better able a builder is to time that spike where it puts the most force on the crank. Building for quench does give nothing but positive results and one of these is more power from the same given displacement, stroke, cam, and carb. With no other changes, on lower octane fuel, you will make more power if it's done right. Now, as far as the distances... The closer the piston and chamber top get, the harder the gases are pushed and the more effective teh quenching is. So further is not better. Closer is better, right up until they hit.
Re: 383man
[Re: moper]
#695473
05/14/10 12:56 PM
05/14/10 12:56 PM
Posts: 11,269 Slantytown
DUFFMAN
Ask And Ye Shall Receive
Slantytown
Here is the explaination of how "quench" or "squish" works I got when I asked about it in an engines design class. The instructor had his PHD in engines engineering and also worked with formula 1 teams. The reason that squish works to prevent detonation is actually fairly simple. Detonation occurs when the air fuel mixture combusts outside the flame kernal(sp?). In an engine with a wedge shaped combustion chamber the spark plug is located to one side of the chamber. The flame front can only travel so fast across the piston, thus it takes longer to reach one side of the piston than it does the other. This allows the opertunity for detonation to occur at the farther side of the piston due to compression (auto ignition). As most of you know auto ignition happens when the mixture is compressed to the point of igniting without a spark. In the case of "squish" the volume of the cylinder at the furthest point from the ignitor is very small and thus can't easily support auto ignition, basically most of the mixture "squishes" out of that area into the larger part of the chamber. Once combustion starts and the piston is travelling down the pressure then drops and auto ignition cannot be support. Remember the pressure inside the cylinder has to be the same throughout the volume. The CR for the area of squish is higher but the actual pressure throught the volume of the cylinder is determined by the total CR. I would suspect that there is a threshold where the volume in the squish area becomes too small to support auto ignition. Because volume is based on the area of squish I would imagine that the point where the clearence from the head to the piston required to reap the benefits is going to depend on the percentage of squish area to the area of the piston. So I don't think you can put a hard and fast rule on how much clearence you need, at best it's a rule of thumb. I hope this makes sense. Let me add to that detonation is not caused by colliding flame fronts. The only effect that multiple flame fronts have is that they will reach the outer edges of the cylinder quicker. Thus the reason the modern HEMI has 2 spark plugs.
No longer taking $h!t from anyone!
Re: 383man
[Re: DUFFMAN]
#695474
05/14/10 02:33 PM
05/14/10 02:33 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Also because the squish area is a very thin "slice" of part of the cylinder, the surface/volume ratio is higher than in the main combustion chamber. More area for a given volume of hot gas to transfer its heat to the water jacket instead of getting hot enough to go boom. At least that's what I remember about it
