QWK ENUF - E85 RESULTS
#693566
05/09/10 11:46 PM
05/09/10 11:46 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
best with tunnelram and 110 gas 10.11@130best with 1050 on 110 gas OTB calibration 10.17@129made 9 passes today on E85 1050 HP with QF E-85 kit installed as per instructions 10.27@129 off the trailer MJ 98 from 96 10.18@130timing 35 from 32 10.10@131MJ 99 from 98 timing still at 35 10.05@132called it a day E85 is great fuel for the day at $2.29 a gallon no more $5 plus race fuel for me.
WAXER
Re: QWK ENUF - E85 RESULTS
[Re: QWK_ENUF]
#693570
05/10/10 08:50 AM
05/10/10 08:50 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Love the stuff.... I have jetted up 2 jet sizes and run exactly the same ET... havent touched the timing yet and it might need a little more jet... mine is also a QF 1050 ![](/ubbthreads/images/graemlins/wave.gif)
[Re: QWK_ENUF]
#693573
05/10/10 09:39 AM
05/10/10 09:39 AM
Posts: 16,934 NC
440Jim
NC
You have already beat the gas carb by 0.12 ET. How was the weather on both days? It looks like the more fuel you put in, the quicker it goes. How is the sixty foot time? What air bleed changes did you make?
[Re: TheOtherDodge]
#693575
05/10/10 10:43 AM
05/10/10 10:43 AM
Posts: 16,934 NC
440Jim
NC
Thanks for the great info! Bummer E85 is not that common around the Houston area...
Several Krogers and H-E-B stations in Houston carry E85:
http://www.e85refueling.com
So it should be easy to fill a drum for a race car. If you want to convert your daily driver, than there may not be enough?
[Re: QWK_ENUF]
#693578
05/10/10 04:39 PM
05/10/10 04:39 PM
Posts: 257 madison, ohio
modified1090
madison, ohio
best with tunnelram and 110 gas [Email]10.11@130[/Email]
best with 1050 on 110 gas OTB calibration [Email]10.17@129[/Email]
[Email]10.27@129[/Email] off the trailer
MJ 98 from 96 [Email]10.18@130[/Email]
timing 35 from 32 [Email]10.10@131[/Email]
MJ 99 from 98 timing still at 35 [Email]10.05@132[/Email]
called it a day
what is your engine combo? i am doing a 4150 950cfm with the help of AJ. hope to get it done soon as i am not sure i like the carb i have now running the E
[Re: modified1090]
#693579
05/10/10 06:08 PM
05/10/10 06:08 PM
Posts: 686 PA
ajcasini
PA
I have done 3 conversions on my own carbs at this point and helping out John (modified1090) with his. I had very few issues with mine. The biggest issue I had was getting the carbs converted and having to wait for the snow to melt to run them. The two carbs I have ran: On my roadrunner best et on 110 race gas 11.07 118 Best pass with E85 10.98 121. The biggest difference I have seen in it is that it ran the 10.98 in mineshaft air. Then the following weekend hot, humid and head wind still ran 11.11 at 118. I was really impressed. Car only lost .013 when everyone on gas was .3 slow. The stuff is killer consistent too. 2 weeks ago first run at 1PM last run at 10PM went 11.06 at 1PM 11.04 at 10PM. With my dragster best run on 110 race gas 9.05 144 E85 8.78 151 If you have any questions send me an email ajcasiniracing@hotmail.com or PM on here.
[Re: racerx]
#693581
05/10/10 06:27 PM
05/10/10 06:27 PM
MR_P_BODY
Besides the carb. change .what else is required to run this e-85?fuel pump? Thaxx.
Being that the E-85 burns 30% more fuel over gas the only thing is that will your pump supply the added 30% with a cushion... so maybe 40 % more than when you run gas ![](/ubbthreads/images/graemlins/wave.gif)
[Re: QWK_ENUF]
#693585
05/10/10 09:26 PM
05/10/10 09:26 PM
QWK_ENUF
LOWELL IN
best thing was engine temp
warmed motor to 160 (t-stat rating)
fans on while heating tires
stage at 170 fans off
trap at 180 fans on
temp back at 160 at trailer
60 deg day , normally i would be 200 and have to run water pump and fans to cool down
WAXER
