Re: who's the best with heads
[Re: 1badD50]
#693140
05/10/10 10:05 AM
05/10/10 10:05 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Come on down to Albuquerque, NM for the Mopar shoot out in June...You're used to a 7000' DA Love your truck...
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: 1badD50]
#693143
05/10/10 08:52 PM
05/10/10 08:52 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I like your truck. Is your hood fiberglass or is it steel with a fiberglass cowl scoop? As you can see in my picture I need to do something about a hood?
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: BPE]
#693145
05/11/10 09:04 PM
05/11/10 09:04 PM
Posts: 637 Kokomo,IN
StripeHOG
Kokomo,IN
what was your best MPH????? looks to me like somethings of there running 10.90's w/ a glide you should be running 120+ what's your 60' also???
Andrew Brough D372
1969 Dodge Dart GTS
1.43 60'best
6.82 1/8 98mph
"the light came on and I ran out of talent"
[Re: 1badD50]
#693146
05/11/10 09:14 PM
05/11/10 09:14 PM
D-50
North, Alabama
the motor is pretty mild 9.5 to 1's comp cam around 588 lift, the heads due have small chambers i think like 62cc or around that, air gap rpm magnum intake with a 750 demon, running a poerglide with an 8 3/4 with 4.30's ran it yesterday at about 7700 feet elevation 10.82 @ 121.60 we figure it weights about 2200 to 2400 lbs
I wish mine was that light, mine weights 2820 lbs. I need to figure out how to get my weight down.
[Re: 1badD50]
#693147
05/12/10 12:33 AM
05/12/10 12:33 AM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
I really like www.immengines.com work. Brian has helped us go fast and has straightened out some of my friends cylinder heads that were ported by so-called reputable shops. Very good customer service and great results with our stuff.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
