Re: Bumber Jack Info. [Re: Hemiruss] #692793
05/17/10 08:29 PM
05/17/10 08:29 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
3 examples of stamped date codes on the jack mechanism at this link;
http://www.hamtramck-historical.com/dateCodes101.shtml
I have not seen a jack like yours in any 1970 model year car & every one I have seen has a date code.
Re: Bumber Jack Info. [Re: Alaskan_TA] #692794
05/17/10 08:50 PM
05/17/10 08:50 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
the only other # is on the jack hook I found the letter A in the middle of it...A large "A" right behind the #'s and a Penstar.....
So I can't find anyother #'s I guess I'm gonna have to sand blast it to get down to it...Which I don't want to...
Re: Bumber Jack Info. [Re: Hemiruss] #692795
05/17/10 08:54 PM
05/17/10 08:54 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
The reason you can't find a date code on the mechanism is cause it was probably like I said a mid sixties jack. This was before they were date coded I think they started in Mid/late 67 dating jack masts. My opinion is you have the right hook since it's clearly the right part # but it's the wrong mast and base for that era....
Re: Bumber Jack Info. [Re: QuickBpBp] #692796
05/17/10 09:32 PM
05/17/10 09:32 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Other than the hook, it does not fit for a '70 at all.
Re: Bumber Jack Info. [Re: Alaskan_TA] #692797
05/17/10 11:50 PM
05/17/10 11:50 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
But would all the paint match perfectly?? Ive never heard of this...but Im no expert...
Re: Bumber Jack Info. [Re: Hemiruss] #692798
05/18/10 12:05 AM
05/18/10 12:05 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Expert = X is the unknown quanity & spurt is a drip under pressure, so do the math, experts are over rated.
The gray paint was used over several years, I have an early jack (no date code) so it is likely from '68 or farther back. The gray is the same.
Re: Bumber Jack Info. [Re: Hemiruss] #692799
05/18/10 09:40 AM
05/18/10 09:40 AM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
All Together
Go up to this post and look again. I'll be honest in this pic only the base and mechanism match. The hook is a different shade.....
Re: Bumber Jack Info. [Re: QuickBpBp] #692800
05/18/10 07:49 PM
05/18/10 07:49 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
It's the pic,I'm looking at all of it and it looks alike...
