Re: Disassembly of BB 727 [Re: moparman89] #692607
05/18/10 12:09 AM
05/18/10 12:09 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
I don't want to be negative..but you should have got a manual before even starting. Your already in over your head and using the case as a core makes it even more complicated. There were production changes(zillions ) through the years and you'll be in trouble if you mismatch parts.
One book that is a good reference is by HPBooks.. Torqueflite A-727 Transmission handbook. Use that along with a mopar service book or even a B&M book that comes with their big rebuild kits.
http://cgi.ebay.com/ebaymotors/HP-Books-...=item4cef62ecc7
http://www.amazon.com/Torqueflite-727-Tr...5761&sr=1-1
The tranny(s) part number also helps in knowing the production year changes
Re: Disassembly of BB 727 [Re: 52savoy] #692608
05/19/10 02:23 PM
05/19/10 02:23 PM
Indy
moparman89 Offline OP
Indy
If I was interested in actually rebuilding it and using it obviously I would have gotten a manual. I'm taking it apart and cleaning it so I dont have to buy a case when I have a transmission built, simple enough.
Re: Disassembly of BB 727 [Re: moparman89] #692609
05/19/10 02:40 PM
05/19/10 02:40 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The main thing is there are a lot of internal parts that are reused in a trans build. A $1500 trans build can get up to $3000 and more if you have to replace everything inside. The case is the cheapest part in the build.
Re: Disassembly of BB 727 [Re: stumpy] #692610
05/19/10 03:18 PM
05/19/10 03:18 PM
scratchnfotraction Offline
I get it
you have a complete tranz you are gonna have rebuilt
you want to drop off the clean/empty case with it at the rebuilder in case it needs a case
ez enuff
bang it on the floor with pump bolts out,VB removed,snap ring and tail shaft removed
it will all fall out more or less
