Re: Collapsed Lifter? [Re: Scott Carl] #690529
05/07/10 12:37 PM
05/07/10 12:37 PM
Nanaimo, B.C.
GwaiiEagle Offline OP
Mannix
Mannix
Nanaimo, B.C.
They were Summit's K6401 cam and lifter kit new.
Re: Collapsed Lifter? [Re: GwaiiEagle] #690530
05/07/10 04:22 PM
05/07/10 04:22 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
The factory offered .030" oversize lifters. Make sure you measure the lifter bores and the lifter diameters.
Re: Collapsed Lifter? [Re: GwaiiEagle] #690531
05/07/10 07:17 PM
05/07/10 07:17 PM
Bellaire, Ohio
66cornet Offline
66cornet  Offline
Bellaire, Ohio
Those metal shavings had to go somewhere.
I just went through the same type of thing with a MP 509 cam and lifters. #8 intake lifter stuck and wiped the cam lobe.
When I dropped oil pan it looked like metal flake paint in there. I had to do a complete teardown, wash and rinse. I put all new main and rod bearings in, got new cam etc, almost together. Maybe fire tomorrow or sunday....Good luck on your motor.
Re: Collapsed Lifter? [Re: 66cornet] #690532
05/07/10 08:00 PM
05/07/10 08:00 PM
Snoopy Offline
Snoopy  Offline
What replacement lifters did you buy?
Re: Collapsed Lifter? [Re: Snoopy] #690533
05/09/10 04:10 PM
05/09/10 04:10 PM
Bellaire, Ohio
66cornet Offline
66cornet  Offline
Bellaire, Ohio
I decided to go with a completely new cam. Bought the Lunati VooDoo cam and lifter kit #60304.
Hopefully everything will go ok this time. If not I'm going roller.
