Re: Anyone test "Super Sucker"/ HVH tapered carb spacers? [Re: Leon441] #690441
05/08/10 09:52 AM
05/08/10 09:52 AM
ill
dennismopar73 Offline
ill
buddy of mine got one
i think its a gimmick
dynos mean absolutly 0 to me
its what it runs at the track
all that matters
Re: Anyone test "Super Sucker"/ HVH tapered carb spacers? [Re: dennismopar73] #690442
05/08/10 10:04 AM
05/08/10 10:04 AM
Az
Crizila Offline
Crizila  Offline
Az
I run a Wilson 1" 4 hole taper spacer on my 408. For sure I gained 1" between the carb and manifold
Fastest 300
Re: Anyone test "Super Sucker"/ HVH tapered carb spacers? [Re: Crizila] #690443
05/08/10 10:35 AM
05/08/10 10:35 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I see a lot of folks running the 1" spacers...anyone using the 2" spacers? I have been considering a 2" to go on my Air-gap.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Anyone test "Super Sucker"/ HVH tapered carb spacers? [Re: FlyFish] #690444
05/09/10 07:40 PM
05/09/10 07:40 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
I didn't really get a good test this weekend. I'll try it again next weekend. I messed with the float level when I changed the spacer and the car bogged after launch really bad. So I returned everything back since 1st round was coming. Plus the wind was rediculous so I doubt 5-10 HP would have been noticeable with 50 MPH wind gusts.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Anyone test "Super Sucker"/ HVH tapered carb spacers? [Re: 69dart] #690445
05/09/10 07:56 PM
05/09/10 07:56 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
69dart can you please exp. played with the flaots ...i did some work to my duster and it started with a bogg and would like to hear more on the flaot deal....also when you add a spacer how much jet would be needed i know most are diff. but what 1/2 sizes...sorry about asking ??? on your post but i want to go to a diff. spacer aswell got 1" open now and want to try 4 hole
Re: Anyone test "Super Sucker"/ HVH tapered carb spacers? [Re: earthmover] #690446
05/09/10 08:22 PM
05/09/10 08:22 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
I thought the floats were set too high on the front bowl so I lowered it down. But I was a dummy because the car wasn't on level ground and I messed it all up. After the bog run I parked on level ground and raised it back up (set to where fuel just trickles out of the sight plug).
The car ran 6.68 1st T/T - 6.89 bog - Went 6.71 on 6.69 for 1st Round - Then 6.73 on 6.71 for 2nd round. Wasn't real consistent but we had rediculous wind to contend with. It sprinkled just before 2nd round so she was moving around a bit. The weather was just terrible so I really wasn't too upset to pack up and head home.
Re: Anyone test "Super Sucker"/ HVH tapered carb spacers? [Re: 69dart] #690447
05/11/10 06:44 AM
05/11/10 06:44 AM
pa
572charger Offline
572charger  Offline
pa
had one on my hemi and it picked up over no spacer ,but then i took it off and installed a open 1" spacer and picked up my 60' 1.39 to a 1.37 i did this at the track back to back runs!! my car never 60' that good ever before so i know for a fact it was the spacer ,hey pro sport i'll lend ya my super sucker hvc ,if u want to try it !!! i think every ones car is different even if some one says" it" does'nt work i try it on mine cause it usually does !!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
