Re: 950 HP on E85 - idle taking off
[Re: ajcasini]
#690398
05/07/10 04:25 PM
05/07/10 04:25 PM
Posts: 654 ohio
dbran451
ohio
Mr P I found the link you were talking about I think but its for 4500 dominator style boosters which are easy to change. I couldnt find anything on the 4150 carbs like he has. With the 4150's from my experience you need a special tool to swedge the boosters in place. if you have something for the 4150 please post it.
As far as the idle I would look at timing and possible throttle plate sticking open. I found a strange thing when I replaced the 4 hole gasket on my car. Used a Summit brand gasket and the gasket was actually hanging up the secondary throttle blades.
I would look for a vacuum leak around the intake as well. I have had that issue before.
As far as running better than gas you bet it will. You should be .1 or more faster than on gas. I picked up .3 and 4 MPH over 110 race gas on a 10.5 - 1 440.
I would change the air bleeds and set them up somewhere around 26-28 on the High Speed Bleed and 62 on the Idle Air bleed.
I changed the boosters in mine as I feared it would lean out too much on the top end with the smaller boosters.
can you post a link thanks
[Re: 69dart]
#690399
05/08/10 11:19 AM
05/08/10 11:19 AM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
I know you drilled your own jets but what jets would your .129 hole be equal to - 90-something? [/quote .129 hole size is close to holley #100 jets. Don
[Re: 69dart]
#690402
05/15/10 08:54 PM
05/15/10 08:54 PM
Posts: 5,992 Anoka County, MN
Leigh
Anoka County, MN
Anyway no more tuning for now because tomorrow is the big race. Hopefully I can go some rounds when it matters!
Amen. Now sharpen up that shoe polish bottle, and go mow em' down.
[Re: 69dart]
#690403
05/16/10 12:45 PM
05/16/10 12:45 PM
Posts: 16,932 NC
440Jim
NC
I picked up the air bleeds today same as Jim was using so we'll see if they help.
The idle problem has cleared up. Changing the air bleeds as suggested made a huge difference. The car drives around with better manners and pulls much better on the big end.
So that seems better. I am looking forward to hearing the track results.
Getting enough fuel without changing the booster might be tough, but I ran mine that way all year (2008). E85 is pretty forgiving on A/F (within reason). I had Mark Sullens put larger flowing boosters in mine, but I haven't used the carb since the rebuild because I put the Ron's injection on.
