Page 2 of 3 1 2 3
Re: Budget 360? [Re: JCCuda] #689441
05/07/10 08:00 PM
05/07/10 08:00 PM
Richmond Va
jdg68 Offline
jdg68  Offline
Richmond Va
JCCuda: That's the most impressive thing I've seen in a long time. I remember seeing the car in a magazine shootout ages ago but looks like it got a lot faster. Very impressive for such a modest combination.
Re: Budget 360? [Re: jdg68] #689442
05/08/10 06:21 AM
05/08/10 06:21 AM
NJ
JCCuda Offline
JCCuda  Offline
NJ
Thank's JDG68, When it was in the High Performance Mopar it had a 100,000 plus mile 360 with the cam I mentioned in the earlier post but with the 100,000 mile valve springs. It used the same headers, intake, conv. and rear gear. The suspension consisted of worn out bushings and shocks in front and worn out leafs with the rear clamps off and a pinion snubber on the rear. The exh. was 2 1/2" to the axel with cheap turbo mufflers. I think the fastest that combo went was 13.20 @ about 101. I bolted on the pocket ported J heads with new springs all else the same and the car went 12.87 @ 105. After about 12 passes one of the crane valve spring retainers broke in half, it dropped a valve and put a hole in the piston. That's when I put in the engine described in my first post. I think the first pass on the combo in the previous post the car went 12.30 something. I always thought with the right converter (to 11sec's. point) and some more tuning it would've gone 11.70's-80's but the no rollbar cutoff when I was racing that car more often was still 12.00 and I didn't want to deal with the nonsense of new belts every 2 years a fire jacket etc. As a side note that 100,000 mile short got a piston from another used 360 fresh rings and bearings a 340 blueprint cam with a cast 4 bbl. int and went into a friends Demon with 2.74 gears and went 13.67
Re: Budget 360? [Re: JCCuda] #689443
05/11/10 06:36 PM
05/11/10 06:36 PM
Richmond Va
jdg68 Offline
jdg68  Offline
Richmond Va
Any more out there?
Re: Budget 360? [Re: jdg68] #689444
05/12/10 02:16 AM
05/12/10 02:16 AM
Florida STAYcation
IcorkSOAK Offline
Financed his waterbed
IcorkSOAK  Offline
Florida STAYcation
Seems as though those J heads are popular .... how about the X heads ? How about pistons ? ... in a motor that needs rebuilding. OEM budget cast or aftermarket budget cast, hyper or forged ?
A N D .. how about balancing the assembly internally? .. worth the effort and expense?
Re: Budget 360? [Re: IcorkSOAK] #689445
05/12/10 08:16 AM
05/12/10 08:16 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Really little if any difference other than the casting number and the X's have 2.02 valves and most of the 915's had 1.88 valves which is not a big deal unless you are going to be spinning in the higher RPM range in order to utilize the larger valve.
Re: Budget 360? [Re: MoparforLife] #689446
05/12/10 07:10 PM
05/12/10 07:10 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Heres one.
71 Swinger, weight unknown.
95 360 shortblock with lots of miles.
New set of RHS heads, re-groung stock roller, .477/.477, .218/.218 @50 112, this is with stock 1.6 rockers, Crosswind RPM, Summit headers, 650dp, MSD dist., timing set at 10* int., 30* total, 17 inches manifold vacuum. 7 blade solid fan. 2.1/4" exhaust, summit mufflers.
904 with cheetah VB, PTC 11" 2800, spooled 3.73s, 255/60/15 MT DRs., stock springs (clamped), home made frame connectors.
Car is driven to the track ( 100 mile round trip), through the exhaust shifting at 5200 it ran a best (so far) of 12.58 @ 104 on a 1.79 60ft. Track is at. 1650ft.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Budget 360? [Re: joedust451] #689447
05/12/10 07:56 PM
05/12/10 07:56 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
The 360 Edelbrock RPM package (cam,heads,intake,3.73 gear) is able to take down 14 flat in a 4000lbs diplomat. After a year of tunning and going with a higher stall.
The RPM package from edelbrock takes out the guesswork. You know what you are going to get . That it will kack the wack it was built to. Works together like magic. Wanna be really crazy ...hit it with a 100 shot. EEEHhhWwweee! 13's for sure'
Re: Budget 360? [Re: SLOW67] #689448
05/12/10 08:15 PM
05/12/10 08:15 PM
SoCal
Brian Hafliger Offline
SoCal
Looking to start collecting parts for my 360 build. I'm not looking to make a ton of hp but I want the car to get down the track. The only things I want out of the motor are: must run on pump gas, hyd. flat tappet cam only, Iron heads, no strokers and no $500 pistons. I want to make a reliable 400hp. I have 3.55 and a 5.38 geared center sections to work with and the trans will be built with all CRT parts...
Our 410 we did for CC made 485HP and 517 TQ with our RHS heads, no porting, pump gas and a hyd. cam.
So a 360 with same heads, intake, smaller 275HL cam and 9.8:1 should make 430-440HP with no other changes.
http://www.carcraft.com/techarticles/ccrp_1006_small_block_mopar_stroker_dyno_test/index.html
Brian Hafliger
Re: Budget 360? [Re: mark7171] #689449
05/12/10 09:59 PM
05/12/10 09:59 PM
Florida STAYcation
IcorkSOAK Offline
IcorkSOAK  Offline
Florida STAYcation
WHERE in-the HECK is all that weight in a M-body ?
Re: Budget 360? [Re: IcorkSOAK] #689450
05/12/10 10:43 PM
05/12/10 10:43 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Sound dedener, power seats, cruise control, tilt wheel, radios with more than one speaker, emmisions equiptment, 4drs, funky safety bumpers, and more sound dedener
Re: Budget 360? [Re: HotRodDave] #689451
05/12/10 10:58 PM
05/12/10 10:58 PM
Florida STAYcation
IcorkSOAK Offline
IcorkSOAK  Offline
Florida STAYcation
OK Dave ...compare it to that 70 Valiant 4 dr .....
WHERE is 900 lbs more ?
Re: Budget 360? [Re: IcorkSOAK] #689452
05/12/10 11:20 PM
05/12/10 11:20 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I think alot of times this weight of cars gets tossed around without hard evidence, not saying the M bodies aren't heavy from the "factory", but in most cases, if you start building & drag racing them, you've somewhat lightened them up by stripping parts.
Re: Budget 360? [Re: joedust451] #689453
05/12/10 11:36 PM
05/12/10 11:36 PM
Florida STAYcation
IcorkSOAK Offline
IcorkSOAK  Offline
Florida STAYcation
I realize that an M-body is going to be heavier than a 4 dr A body ... but 900 lbs ?
OK .. the FRONT seat weighs 50 lbs more? .. rear seat 10? ... door beams - 40 ? ... bumpers with the beams (MORE than the A body) - 40 ? Electric windows...30? ..Xtra insulation and carpeting diff ? .. 40.
I would HONESTLY like to know. I have always liked the idea of a 5th as a SLEEPER project with a BIG B engine ... but there are major issues with that ... that being a decent exhaust system.
CAN'T be done.
Sooooo ...an A engine IT IS !
Re: Budget 360? [Re: IcorkSOAK] #689454
05/13/10 09:03 AM
05/13/10 09:03 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
CAN'T be done.
40lbs here, 50lbs there adds up quick. don't forget, an M is closer in width to a pre-71 B than an A.
my 5th ave was 3950 with 1/2 tank of gas, without me when I was dropping off some scrap at a metal recyclers, without the scrap in it.
the weight adders to mine:
A500, 1" rear sway bar, 5 leaf rear springs, 1.125" front sway bar, 11.75" brakes, 8.75" rear
the weight reduction:
aluminum intake, loss of smog pump
the weight wash:
17x8 mustang rims w/255/50R17's vs. steel 15x7 with 205/75's, headers and 3" big single exhaust vs. stock manifolds and thick walled 1.875" exhaust with 3 cats.
realistically, I'd gather my 5th, stock probably was 3700-3800 lbs. the sound deadener under the carpet is HEAVY. the bumpers are, too. the interior door panels have a fair amount of heft to them, too. the front power seats are quite weighty....
a big block in an M is quite roomy, if you stick to a low deck, and/or use a K car power brake booster. the huge booster in them makes even a small block snug. as far as room for an exhaust, headers aren't a problem, the rear, you can fit a big single (3") over the axle pipe, or move the tank over, and you can fit dual 2.5" tails....there's enough room under the car to run the large body dynomax (5x11x20" case) mufflers under the rear seat.
2017 Grand Cherokee Overland
Re: Budget 360? [Re: SLOW67] #689455
05/13/10 01:10 PM
05/13/10 01:10 PM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
good info...
71 GTX 4sp Dana GY9 HD Road King
Re: Budget 360? [Re: AZ-Nick] #689456
05/13/10 09:30 PM
05/13/10 09:30 PM
Toronto
mshred Offline
mshred  Offline
Toronto
anyone else with any combos? this is an interesting thread
Re: Budget 360? [Re: SLOW67] #689457
05/15/10 07:42 PM
05/15/10 07:42 PM
The Great White North
RAMM Offline
RAMM  Offline
Boy oh boy will you want to be a fly on the wall of my shop for the next couple o' weeks. I just broke in a customer's stock stroke, pumpgas, hydraulic flat tappet, dual plane 367 (.040" over). He wanted 400 HP and I just broke it in and did a very short pull from 3500-4200rpm. Torque is GOOD as usual 402 lbs the whole run. Nothing is optimized yet and already making 321 hp @ 4200. Ran out of fuel and time but will update Tuesday. Also will be running a EngineQuest MAgnum headed 367 in the next two weeks as well--Can.t wait for that. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Budget 360? [Re: RAMM] #689458
05/16/10 12:02 AM
05/16/10 12:02 AM
CONNECTICUT
RoyceFlo73 Offline
RoyceFlo73  Offline
CONNECTICUT
Patrick,
I was wondering if you could post a link to those magnum heads from Hughes. I couldnt seem to find them on their site, i saw a set for $825.
It would be greatly apperciated!
Re: Budget 360? [Re: RoyceFlo73] #689459
05/16/10 08:42 AM
05/16/10 08:42 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
When i bought my RHS heads from hughes, the EQs were on back order, you may want to call them & find out if they have them now, But you might be better off with the RHSs for 175.00 more, they flow 10cc more OOTB then the EQs, there also more benificial in the long run if you plan on doing any milling or porting, i will say i'm very very happy with mine just basically OOTB with the 1.92 valves & there 1110 springs, but i'm limited on lift.
These are the iron rams
http://www.hughesengines.com/Index/produ...mp;partid=25701
These are the RHSs
http://www.hughesengines.com/Index/produ...mp;partid=25738
Re: Budget 360? [Re: RoyceFlo73] #689460
05/17/10 08:08 AM
05/17/10 08:08 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Patrick,
http://www.hughesengines.com/Index/produ...mp;partid=25702
looks like they've upped the price $26....
Page 2 of 3 1 2 3
