Re: Hughes rocker shaft hold down set questio. [Re: Hemi Allstate] #687957
05/19/10 10:01 PM
05/19/10 10:01 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Only draw back to centering the tips perfectly on the valve stem is you often wind up with push rods hitting the intake ports. Sometimes you have to come to an acceptable middle ground. I also had to machine down the hughes hold downs.
Brian
Re: Hughes rocker shaft hold down set questio. [Re: '72CudaRacer] #687958
05/19/10 10:45 PM
05/19/10 10:45 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i had to take 0.30" off each side of the hughes hold downs to get 0.15" side clearance per pair with comp pro magnums and stealth heads. i was expecting to do some milling though from what i read here.
Re: Hughes rocker shaft hold down set questio. [Re: dirtybee] #687959
05/20/10 05:40 AM
05/20/10 05:40 AM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
I'm in the middle of setting the rocker gear up on my B1BS heads. Had to take off about .030" per side also. I'm glad I saw this also. Using aluminum rockers, if the minimum clearence is .015", what would be the acceptable maximum?
Randy
Re: Hughes rocker shaft hold down set questio. [Re: Dartin] #687960
05/20/10 03:59 PM
05/20/10 03:59 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I got a full set of shims with my kit.
Mick
