Page 5 of 7 1 2 3 4 5 6 7
Re: Running hot with 440 source housing and pump [Re: 440challenger] #685523
05/06/10 08:45 PM
05/06/10 08:45 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Oh like what was said, go back to a 180 or even 195 stat. Good luck
Re: Running hot with 440 source housing and pump [Re: 440challenger] #685524
05/07/10 05:34 PM
05/07/10 05:34 PM
NJ
440challenger Offline
NJ
well i got a blown head gasket or cracked head. I did a coolant test and there is exhaust gasses in the coolant. time to rip apart a fresh motor in a freshly restored car. ahh the fun
Re: Running hot with 440 source housing and pump [Re: 440challenger] #685525
05/07/10 08:15 PM
05/07/10 08:15 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Sorry to hear that. What head gaskets did you have on the build? What heads also?
Re: Running hot with 440 source housing and pump [Re: ireland383] #685526
05/07/10 08:18 PM
05/07/10 08:18 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Nevermind I read your other post.
Re: Running hot with 440 source housing and pump [Re: 1965_PLYMOUTH] #685527
05/09/10 08:02 PM
05/09/10 08:02 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
how heavy of radiator caps are you guys running that have heating issues? excessive pressure builds excessive heat.
I think you have that backwards , the heat builds the pressure .
Also one thing some of you are forgetting is the new cars running higher coolant temps also run HIGHER SYSTEM pressure , I had to buy an upgrade kit for my rad pressure tester , it tests up to 30 psi now .
Re: Running hot with 440 source housing and pump [Re: JohnRR] #685528
05/10/10 06:00 AM
05/10/10 06:00 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Also one thing some of you are forgetting is the new cars running higher collant temps also run HIGHER SYSTEM pressure , I had to buy an upgrade kit for my rad pressure tester , it tests up to 30 psi now .
Higher system pressure raises the boiling point of water and helps prevent steam pockects.
Re: Running hot with 440 source housing and pump [Re: gdonovan] #685529
05/10/10 04:34 PM
05/10/10 04:34 PM
dark side of the moon
Dougsmopars Offline OP
Higher presure cap does not raise water temp. It raises boiling point. Yes new cars do run hotter but lets not forget the new motors are built to much better tolerences. New cars run 200,000 miles all the time. The 60's motors were worn out at 70 or 80 K on them.
Re: Running hot with 440 source housing and pump [Re: fourgearsavoy] #685530
05/10/10 04:53 PM
05/10/10 04:53 PM
Long Island NY
yellow sixpack Offline
Long Island NY
Heres an article for you. http://www.dodgecharger.com/forum/index.php/topic,60599.0.html
If you can't be smart.....don't be stupid!
Re: Running hot with 440 source housing and pump [Re: GTXKen] #685531
05/10/10 06:53 PM
05/10/10 06:53 PM
own private Idaho
N
ngpSatellite Offline
N
own private Idaho
I just pulled the source pump and housing in favor of a stock housing and milodon pump. Hasn't been hot enough to make a difference but I will report back.
... FINALLY!!! THE MYSTERY IS SOLVED!!! ....HATS off to Doug for the topic and NachoRT74 for that awesome link put a stock housing on and a milodon pump and it cruzed all day long in 90+ florida heat yesterday, stop and go, everywhere!!! The 440 housing I had, you could barly get your pinky into the 90 deg turn in the lower opening. I put that 440 housing and pump on my new motor 2 1/2 years ago and could'nt get the temp down but never suspected the housing because it was brand new..........
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685532
05/10/10 07:20 PM
05/10/10 07:20 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
.....Yes new cars do run hotter but lets not forget the new motors are built to much better tolerences. New cars run 200,000 miles all the time. The 60's motors were worn out at 70 or 80 K on them.
Hmmmm. Bit of a simplification. Maybe the 4 or 5 speed overdrive lock up converters have a little something to do with it and their 2.0 final overall drive ratios.
Re: Running hot with 440 source housing and pump [Re: BSB67] #685533
05/10/10 07:39 PM
05/10/10 07:39 PM
there also computer controlled. Running a 60's motor runnung at todays engine temps would kill them in 30K miles.
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685534
05/10/10 09:49 PM
05/10/10 09:49 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Please be more specific.
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685535
05/11/10 12:45 AM
05/11/10 12:45 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Do tell............
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685536
05/11/10 05:46 AM
05/11/10 05:46 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
"Higher system pressure raises the boiling point of water"
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685537
05/11/10 06:07 PM
05/11/10 06:07 PM
Illinois, USA
superbee69 Online content
superbee69  Online Content
Illinois, USA
I bought r/h inlet 440 source housing & under the thermostat there was a 1/2 inch passage cast shut except 1/8 hole on l/h side mybe your problem
Re: Running hot with 440 source housing and pump *DELETED* [Re: Dougsmopars] #685538
05/11/10 08:46 PM
05/11/10 08:46 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Post deleted by DusterKrazy
Re: Running hot with 440 source housing and pump [Re: DusterKrazy] #685539
05/11/10 08:48 PM
05/11/10 08:48 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
I do not agree. I've never seen a 318 worn out at 70-80k miles, much less a /6. If they wore out it is simply because people did not take care of them
Re: Running hot with 440 source housing and pump [Re: DusterKrazy] #685540
05/11/10 09:21 PM
05/11/10 09:21 PM
The exception not the rule. a 300 Ford would run for 100,00 with a knock. That does not mean every american engine ever built in the 50's and 60's would run for 200,000 like the newer motors do. Anybody that has spent any time working on cars will know that. Into the early 80's american car engines were worn out around 90 to 100 K. Simple fact. Lot's have changed since then. Back in the 70's and 80's they were rotted to the door handle's in 5 years. You don't see them rotted like that anymore.
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685541
05/11/10 10:50 PM
05/11/10 10:50 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Still waiting for a detailed explanation of the above claim.
Re: Running hot with 440 source housing and pump [Re: Von] #685542
05/11/10 11:04 PM
05/11/10 11:04 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
If you run a 440 at 220 degrees, it won't like it. New engines run even hotter than that at times IIRC.
I want my fair share
