Page 3 of 7 1 2 3 4 5 6 7
Re: Running hot with 440 source housing and pump [Re: 440challenger] #685483
05/04/10 09:58 PM
05/04/10 09:58 PM
dark side of the moon
Dougsmopars Offline OP
My Milodon pump will be here tomorrow. I'll put it in thureday night and let you know.
Re: Running hot with 440 source housing and pump [Re: 440challenger] #685484
05/04/10 10:01 PM
05/04/10 10:01 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Get rid of the Source pump and put the themal fan back on it. The housing is probally OK.
Re: Running hot with 440 source housing and pump [Re: RapidRobert] #685485
05/05/10 12:59 AM
05/05/10 12:59 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
The pump is made by Cat and is sold by many different people.
I have a NIB cat pump going onto a mild 451
I have a CAT housing and pump with a 160 t-stat and I can't even get it past 160 degrees with a stock 22" radiator w/clutch fan. My 440 has 12-1 compression and a .600 lift cam. I did drill out the head gasket's water holes that were slotted.. Not sure how much diff that made.
Re: Running hot with 440 source housing and pump [Re: 52savoy] #685486
05/05/10 01:13 AM
05/05/10 01:13 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Most of my overheating problems went away as soon as I got rid of the underdrive crank pulley.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Running hot with 440 source housing and pump [Re: NachoRT74] #685487
05/05/10 07:03 AM
05/05/10 07:03 AM
own private Idaho
N
ngpSatellite Offline
N
own private Idaho
Re: Running hot with 440 source housing and pump [Re: ngpSatellite] #685488
05/05/10 07:38 AM
05/05/10 07:38 AM
Cincinnati, Ohio
Cincinnati, Ohio
something interesting to read about
Read the thread...that link was already posted in this thread.
Just because someone post it, doesn't make it fact.
Re: Running hot with 440 source housing and pump [Re: Challenger 1] #685489
05/05/10 08:08 AM
05/05/10 08:08 AM
NJ
440challenger Offline
NJ
you know what. after i read that thread it reminded me. When my t stat opens up the fluid does just "coast" by very slowly. You guys think those source housings are ok?
Re: Running hot with 440 source housing and pump [Re: 440challenger] #685490
05/05/10 08:17 AM
05/05/10 08:17 AM
Cincinnati, Ohio
Cincinnati, Ohio
I think the housings are cheap and junky and wouldn't want one on my car, but I don't think there the reason for running hot. I do think the Source pump is junk and causing the overheating problem. If it still runs hot with a decent pump, then it's the clutch on the clutch fan. My
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685491
05/05/10 08:53 AM
05/05/10 08:53 AM
sixbbl69 Offline
sixbbl69  Offline
go to dodge charger .com and read what was said about this 6 months ago and is still at top of page.
Re: Running hot with 440 source housing and pump [Re: sixbbl69] #685492
05/05/10 09:12 AM
05/05/10 09:12 AM
NJ
NJ
I just swaped out the source pump for a reman stocker i had on the shelf . i will let you know tonight if there is a difference. I can tell you that the source pump and stock are 2 completely different animals as far as construction and design.
Re: Running hot with 440 source housing and pump [Re: 440challenger] #685493
05/05/10 02:31 PM
05/05/10 02:31 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
I just pulled the source pump and housing in favor of a stock housing and milodon pump. Hasn't been hot enough to make a difference but I will report back.
Re: Running hot with 440 source housing and pump [Re: GTXKen] #685494
05/05/10 03:26 PM
05/05/10 03:26 PM
Marcell, MN
68 Roadrunner Offline
Marcell, MN
I'm curious to see what you guys find out. I just put on a 440 Source pump and housing on my new motor. I'm not quite done installing it. Hopefully I don't have this overheating problem!
1968 Roadrunner 383 auto .060 KB 400 domed pistons, Stealth heads, Torker intake, Holley 830, Lunati Voodoo cam 276/284, .513/.533, TCI 3500, 3.91 gears, all ARP fasteners,
Re: Running hot with 440 source housing and pump [Re: Challenger 1] #685495
05/05/10 05:13 PM
05/05/10 05:13 PM
own private Idaho
N
N
own private Idaho
.... take it easy man... ........I have a 440 source housing and top end heat issues.... it will cost about 30 bucks to get a stock housing and swap it out... relax... you act like you work for 440 source
Re: Running hot with 440 source housing and pump [Re: ngpSatellite] #685496
05/05/10 07:00 PM
05/05/10 07:00 PM
My Milodon pump came today. What a difference in impeller design and size. This will definitely move a lot more water then the junk 440 source pump. It's going in tomorrow.
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685497
05/05/10 08:44 PM
05/05/10 08:44 PM
NJ
NJ
Well I just test drove the car with the reman stock pump. Went to a local cruise night. it was a nice and cool 65 degree night and its still running hot. The car was running great, 170-190..then after about 15 minutes into the drive it will get up to 210-215. Im not sure why its doing this... The temp is not dropping down while cruizing..
In my case, the source pump was NOT the problem. Now could the housing be a problem?
I flushed the block a bunch when i built the motor, and flushed it recently again. Im going to try a 160 stat and see what happens.....
Re: Running hot with 440 source housing and pump [Re: 440challenger] #685498
05/05/10 08:56 PM
05/05/10 08:56 PM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
how heavy of radiator caps are you guys running that have heating issues? excessive pressure builds excessive heat.
Re: Running hot with 440 source housing and pump [Re: Challenger 1] #685499
05/05/10 10:11 PM
05/05/10 10:11 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Well the one fact that is indisputable is that MY engine ran cooler with the stock housing and Milodon pump. There was also much better circulation across the top of the rad with this setup vs the 440 source housing & pump. That's a FACT !
INMO, the housing is a problem, anything that restricts waterflow in & out can't be good for cooling. Coolant that languishes inside the block & heads too long is going to boil.
Ron
Re: Running hot with 440 source housing and pump [Re: firefighter3931] #685500
05/05/10 10:45 PM
05/05/10 10:45 PM
Cincinnati, Ohio
Cincinnati, Ohio
Ron
I hear you, and agree.
Bummer 440challenger, can you or will you change out your Source housing to see if it cures your problem?
Isn't there guys here running the Source housing without overheating issues?
Re: Running hot with 440 source housing and pump [Re: Challenger 1] #685501
05/06/10 12:56 AM
05/06/10 12:56 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
What kind of stat are you running?
Some have the big slots, others have the more common small passage.
I want my fair share
Re: Running hot with 440 source housing and pump [Re: Challenger 1] #685502
05/06/10 07:09 AM
05/06/10 07:09 AM
Cincinnati, Ohio
Cincinnati, Ohio
