Re: Running hot with 440 source housing and pump
[Re: Dougsmopars]
#685468
05/01/10 09:10 PM
05/01/10 09:10 PM
Challenger 1
Cincinnati, Ohio
Same fan that was on it before swapping the houseing and pump. Works fine.
They do go bad, expecially if there stored flat and put back on the car.
It's what keeps the engine cool(fan clutch) during stop and go. You should be able to hear the fan when it's working during hi temps.
I've seen em go bad with more than one car over the years.
[Re: RapidRobert]
#685471
05/01/10 09:25 PM
05/01/10 09:25 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Ok, so you changed the water pump, water pump housing, and the CAM...and you think the overheating is from the water pump?
I'd look at the cam swap before the water pump. with a cam change, your carb will need re-tuned, and your timing will need re-tuned. you could be lean, your timing could be way off...and that could be a HUGE reason for running hot.
I'd suspect that before the water pump.
**Photobucket sucks**
[Re: Dougsmopars]
#685478
05/02/10 12:37 PM
05/02/10 12:37 PM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
Lunati 513/533 Initial is happest at 20 degree's yes new valley pan i never reuse a gasket. I think the problem is the pump. easy change to find out.
ALSO! Before bolting the new pump on, determine the impeller-to-housing clearance. There have been reports of interference and/or excessive clearance with some combinations. I would think the most effective is for the impeller to be as close as possible to the housing, w/o interference.
As stated by another poster, the design of the 440source impeller does not look like it would flow well. Report back with your results!
[Re: Pacnorthcuda]
#685479
05/02/10 01:26 PM
05/02/10 01:26 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
IMO, get a Milodon HV pump and be done with it.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
