Re: 3rd shift [Re: Wedgeman] #684015
05/02/10 05:58 PM
05/02/10 05:58 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
In this case wich ball would be missing ?
Dan
Re: 3rd shift [Re: Wedgeman] #684016
05/02/10 07:32 PM
05/02/10 07:32 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The large ball is in location #6 in the pic below, of the balls that sit in bathtub shaped pockets in the casting, #6 is in the only large bathtub.
Re: 3rd shift [Re: John_Kunkel] #684017
05/03/10 12:57 AM
05/03/10 12:57 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Got it !!
Thanks JoHn
Re: 3rd shift [Re: Wedgeman] #684018
05/03/10 12:45 PM
05/03/10 12:45 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Checkball is in there....the casting year I got from SMR trans is a 72.....the original is stamped '75....may be there is something there ?
Dan
Re: 3rd shift [Re: Wedgeman] #684019
05/03/10 06:04 PM
05/03/10 06:04 PM
Rio Linda, CA
Rio Linda, CA
I'd give it to the shop that built it.
The only other thing I can think to do is hook up a test gauge to the governor pressure test port and check the pressure on the road; there should be about 10 psi for every 10 mph.
Re: 3rd shift [Re: John_Kunkel] #684020
05/03/10 06:55 PM
05/03/10 06:55 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
HI JOhn,
I put the old VB in and everything works fine..
I''ll be returning the VB
Thanks everyone !
Dan
Re: 3rd shift [Re: Wedgeman] #684021
05/06/10 04:45 PM
05/06/10 04:45 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
And the answer is ..........
A non lock-up valve body, simply doesn't work in
a later lock-up transmission
Dan
