Re: Where did you mount your ignition box? [Re: GTX MATT] #683373
04/29/10 09:29 PM
04/29/10 09:29 PM
Atlanta
DartGTX Offline
DartGTX  Offline
Atlanta
Under my horn on the radiator support. It's been flawless since 2000........
Good luck
Re: Where did you mount your ignition box? [Re: GTX MATT] #683374
04/30/10 08:04 AM
04/30/10 08:04 AM
wilmington,ohio
O
ohiodemon Offline
ohiodemon  Offline
O
wilmington,ohio
mounted mine under left front fender.
remember,heat is what kills them.
Re: Where did you mount your ignition box? [Re: Dougsmopars] #683375
04/30/10 12:38 PM
04/30/10 12:38 PM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
they like that air on the backside of them, best to put it a cool area in the engine bay.
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: Where did you mount your ignition box? [Re: MonGoo$e] #683376
04/30/10 03:49 PM
04/30/10 03:49 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
I put an MSD6 box in the cab of my truck. With a 440, long tube headers, and almost no muffler I can still hear that stupid thing squealing away. I'll never put another in the cab.
Re: Where did you mount your ignition box? [Re: DartGTX] #683377
04/30/10 04:16 PM
04/30/10 04:16 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
x2. Horn and washer bottle hides it pretty good. Can't see it at all when looking from the front.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Where did you mount your ignition box? [Re: wingman] #683378
04/30/10 06:53 PM
04/30/10 06:53 PM
IN
ahy Offline
ahy  Offline
IN
On my battery tray with the battery in the trunk. I fabricated a bracket that mounts the MSD and injection control computer on a repop tray. There is a cooling opening for the battery that helps keep it all cool when rolling.
Re: Where did you mount your ignition box? [Re: DartGTX] #683379
04/30/10 09:17 PM
04/30/10 09:17 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Good luck
Me too.
Re: Where did you mount your ignition box? [Re: Dougsmopars] #683380
04/30/10 09:52 PM
04/30/10 09:52 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
This is the bracket i used. It's for Mopar boxes. Mounts on back of intake. Got it on ebay. Seller is Rocketresto
I used the same....been there for 3 years with no troubles
1MYTGTX
Re: Where did you mount your ignition box? [Re: 1MYTGTX] #683381
04/30/10 11:21 PM
04/30/10 11:21 PM
BC Canada
O
ogopogo Online content
ogopogo  Online Content
O
BC Canada
I always use MSD 6al's so I have a rev limiter and I always mount them on the underside of the battery tray!
Re: Where did you mount your ignition box? [Re: Dougsmopars] #683382
04/30/10 11:36 PM
04/30/10 11:36 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Year 1 also sells a clone of this...
Just my $0.01..
Re: Where did you mount your ignition box? [Re: Sinitro] #683383
05/01/10 01:24 AM
05/01/10 01:24 AM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
I was thinking about putting a MSD 6AL in the trunk behind the spare. Maybe make up a separate harness for the MSD, fuel pump, and speakers and run it down the rh side of the car?
Re: Where did you mount your ignition box? [Re: Silverbullet2] #683384
05/01/10 02:23 AM
05/01/10 02:23 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: Where did you mount your ignition box? [Re: 1_WILD_RT] #683385
05/01/10 02:31 AM
05/01/10 02:31 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Well I mounted it. I HATE messy, hacked, criss crossed wiring everywhere so I try to keep everything as neat as possible.
I mounted it on the firewall right under the voltage regulator so that its kind of hidden by the air cleaner and blends in with the other wiring stuff, and a GTX air cleaner would hide it even better. Most importantly I only need 6 inches of wire to tie it into the ballast resistor and I can run it with the rest of the wiring harness to the distributor and coil.
Thanks for the input guys.
