Re: Where did you mount your ignition box?
[Re: DartGTX]
#683379
04/30/10 09:17 PM
04/30/10 09:17 PM
Posts: 1,565 tennessee
pushbutton
tennessee
Under my horn on the radiator support.
Good luck
Me too.
[Re: Dougsmopars]
#683382
04/30/10 11:36 PM
04/30/10 11:36 PM
Posts: 5,449 So Cal
Sinitro
So Cal
This is the bracket i used. It's for Mopar boxes. Mounts on back of intake. Got it on ebay. Seller is Rocketresto
Year 1 also sells a clone of this...
Just my $0.01..
[Re: 1_WILD_RT]
#683385
05/01/10 02:31 AM
05/01/10 02:31 AM
Posts: 5,167 CT
GTX MATT
CT
Well I mounted it. I HATE messy, hacked, criss crossed wiring everywhere so I try to keep everything as neat as possible. I mounted it on the firewall right under the voltage regulator so that its kind of hidden by the air cleaner and blends in with the other wiring stuff, and a GTX air cleaner would hide it even better. Most importantly I only need 6 inches of wire to tie it into the ballast resistor and I can run it with the rest of the wiring harness to the distributor and coil. Thanks for the input guys.
