Re: What do you run your fuel pressure at? [Re: rickstershemi] #682978
04/29/10 05:23 PM
04/29/10 05:23 PM
Q
Quicktree Offline
Quicktree  Offline
Q
mine is at 9 or a little more. anything less and it ran out of fuel in the 1/4. no problem with the needle and seat
Re: What do you run your fuel pressure at? [Re: Quicktree] #682979
04/29/10 05:38 PM
04/29/10 05:38 PM
Cleveland, OH
fury413rb Offline
fury413rb  Offline
Cleveland, OH
8.5 with a bypass on a Holley Black with a Jegs billet return reg
Re: What do you run your fuel pressure at? [Re: 70satelliteguy] #682980
04/29/10 05:40 PM
04/29/10 05:40 PM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
7 dead head on mine.
Re: What do you run your fuel pressure at? [Re: fury413rb] #682981
04/29/10 06:22 PM
04/29/10 06:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A by pass doesnt have anything to do with it... pressure
is pressure BUT a by pass (return style) keeps a
more constant pressure (and cooler fuel)
Re: What do you run your fuel pressure at? [Re: MR_P_BODY] #682982
04/29/10 07:34 PM
04/29/10 07:34 PM
Cleveland, OH
fury413rb Offline
fury413rb  Offline
Cleveland, OH
easier on the pump too
Re: What do you run your fuel pressure at? [Re: fury413rb] #682983
04/29/10 11:25 PM
04/29/10 11:25 PM
I use to run 9.5 lbs with my Magnafuel 300 pump, I let it down to 5.5 lbs after talking to the Magnafuel techs and the car runs the same My message is some systems don't need as much pressures as others. I have seen systems like Brads that made the car go faster(not running out of gas)by turning up the pressure on the regulators to 9 or 10 lbs, especaiily the small original early Holley regs
