Re: Wade...that 318/390 stroker of yours...
[Re: cudadoug]
#682837
04/28/10 07:40 PM
04/28/10 07:40 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
[Re: rickstershemi]
#682839
04/28/10 09:33 PM
04/28/10 09:33 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
This was our first weekend our with it so I'm still hoping for a 10.90 or maybe even a 10.80 with some tuning.
Here is the combo:
1968 Fastback Barracuda 318 stroker (390cid) K1 4" forged crank Eagle Rods H-beam rods Ross flat top pistons - 11:1 compression Edelbrock heads (OOTB) -- untouched but hope to get them ported next year. Air-gap dual plane ---- Now M1 intake BG 750 silver claw – AV gas -- Now Holley 950 Alcohol carb Comp solid cam (.540/.555 252/262 @.050 106 lobe sep) 727 & Dynamic 9.5” converter 3.91 gears in a 8 ¾ sure grip ---- 4.30 gears and spool with 35 spline axles now Micky Thompson 26x10 slicks ----- Now GoodYear 28x10 Cal-tracs, mono leaf, Rancho 9way shocks & Cal-tracs 90/10 front shocks Carter mechanical fuel pump -- Now Aeromotive 2000 fuel pump TTI headers 1 5/8 step headers with full 3” TTI exhaust, X pipe with Dynomax turbos ran 11.35 at 118mph shifting at 5,700rpm
Here is what I did this winter: putting a 6 point roll bar in pulling out the stock tank and going to a 5 gal fuel cell Aeromotive 2000 fuel pump moving the battery to the trunk moving to a spool 4.30 gears GoodYear 28x10 slicks M1 intake Holley 950 Alcohol carb 132 jet and power valves (Going to Alcohol)
Weighed the car this weekend and it weighed 3,095 so race weight is somewhere close to 3,250lbs so I think that calculates to just over 550hp at the flywheel.
Timing is 38 degrees.
Best pass was 11.03 at 121mph with 1.502 60' shifting at 6,300 and stalling to 2,250 but it will stall over 3,000 but my wife is used to staging it at 2,250 from last year and since we were bracket racing, I left her alone. Will get her to move it to 2,500 next time out.
It's picking up the front tires between 3 - 4 inches.
I'll post a video in just a minute, but it's big, 25MB.
Anyone got any suggestions on how to get a little more out of it?
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: WadeMetzinger]
#682842
04/28/10 10:18 PM
04/28/10 10:18 PM
Triple Threat
Renton Washington
The car appears to work well, there isn't a whole lot of front end travel before it picks up the tires, its certainly not the 5 inches worth that Calvert recommends, but if its working well I don't see a problem with how it is.
I'm building a 4" stroke 318 based motor currently myself, so I like to see your results.Mine will be a 396 though, and likely be Indy headed.
[Re: Triple Threat]
#682843
04/28/10 10:37 PM
04/28/10 10:37 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
Take some timing out in High Gear... might bump you into the 10.s that or a cool night.... looks like a killer set up.. nice car cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: Triple Threat]
#682844
04/28/10 10:40 PM
04/28/10 10:40 PM
WadeMetzinger
Tulsa, Ok
I've got 5" of travel in the shop, measuring like the tell you to but in the video, I've got it stalled just under 3,000 so I'm taking some of that up with the stall. If you watch the video in slow-mo it looks like a good 4" of travel to me.
It also looks like it rolls 6 to 9 inches before it picks up the tires.
With your Indy head, more compression and better cam you'll be making much more power than I am. Several people including Ryan told me it wasn't a cam they would have selected for the combo but I picked it up cheap and had it on the shelf so I used it.
I'm limited by the 1 5/8 TTI step headers, no port work, and 11:1 compression and a 8" converter would make it leave harder but then I might start having traction problems.
[Re: WadeMetzinger]
#682845
04/28/10 10:42 PM
04/28/10 10:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Wade... whats the bore on that and did you sonic check it.... what was the final wall thickness.... nice runnin package
[Re: WadeMetzinger]
#682847
03/02/11 08:00 PM
03/02/11 08:00 PM
WadeMetzinger
Tulsa, Ok
Just picked up the heads from being ported, at 550 lift (which is what my can lift is) he pick them up from 230 to 265 cfm, so I'm looking to run some 10.70s this year if I can keep those small slicks hooked up.
[Re: WadeMetzinger]
#682848
03/02/11 08:36 PM
03/02/11 08:36 PM
Posts: 9,892 Weddington, N.C.
Streetwize
Weddington, N.C.
Eerily close to my 414 combo in cam and now RyanJ ported E-heads, I'm running a ported Victor and an 830 to start with 4.56's at around 2900 pounds. Maybe I should put the 341 back in!!
[Re: WadeMetzinger]
#682850
03/03/11 01:03 PM
03/03/11 01:03 PM
Streetwize
Weddington, N.C.
SDSS Stage 2 ported Flow #'s vs. stock Stock Edelbrocks LIFT-----IN/EX .100”----72.5/N/A .200”--131.1/107.0 .300”--182.9/151.8 .400”--216.6/181.2 .450”--227.7/182.9 .500”--235.9/185.6 .550”--238.7/185.6 .600”--242.2/185.6 .650”--243.2/185.6 .700”--243.2/185.6
SDSS ported Flow #'s
LIFT--IN/EX .100"--72.6/NA .200"--146.9/110.8 .300"--196.3/150.1 .400"--245.8/180.2 .450"--259.0/193.8 .500"--268.6/203.4 .550"--271.8/212.9 .600"--276.6/218.6 .650"--283.5/221.6 .700"--286.6/223.8
[Re: WadeMetzinger]
#682852
03/03/11 01:38 PM
03/03/11 01:38 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
That's what I figured, there is still a lot left in them with additional porting. (thanks for providing this info)
I think the motor will be much more efficient just from the "cleaning" up work and making them flow the same and consistently from cylinder to cylinder.
Can't wait to get to the track and find out!
I think adding 35 more CFM will pick it up also! Love this car/combo...it's working pretty well I must say.
We have a pic above of the trunk...we need one of the engine room and interior please!
Keep us posted!!
