Magnum heads on 360 LA #682175
04/27/10 10:46 PM
04/27/10 10:46 PM
Middle River, MD
Mapandjlp Offline OP
Middle River, MD
I've been trying to figure out the best way to build the 360 for my Challenger. I'm considering magnum heads but have a couple of questions.
First - are the holes for mounting the PS pump, A/C, and Alternator bracketry the same as the LA heads?
Second - any thoughts on what effect they'll have on compression ratio on my '75 360 if I stick with the stock pistons?
Thanks, Guys! If anyone can help, I know you all can.
Re: Magnum heads on 360 LA [Re: Mapandjlp] #682176
04/27/10 10:49 PM
04/27/10 10:49 PM
ILLINOIS
V
volaredon Online content
volaredon  Online Content
V
ILLINOIS
it will improve the CR. and when I put the "EQ" Magnum heads onto my 83 318 truck engine everything bolted up fine.
Re: Magnum heads on 360 LA [Re: Mapandjlp] #682177
04/27/10 11:19 PM
04/27/10 11:19 PM
my unmilled mags were 63 cc's
Re: Magnum heads on 360 LA [Re: RapidRobert] #682178
04/27/10 11:33 PM
04/27/10 11:33 PM
Middle River, MD
Middle River, MD
Any idea what the standard '75 360 head cc'd at?
Re: Magnum heads on 360 LA [Re: Mapandjlp] #682179
04/27/10 11:36 PM
04/27/10 11:36 PM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
iirc b/w 68-72cc's.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: Magnum heads on 360 LA [Re: Prince_Valiant] #682180
04/28/10 12:12 AM
04/28/10 12:12 AM
Concord California
E
Evil_Ways Offline
Evil_Ways  Offline
E
Concord California
If your going to use Magnum heads, spend the cash and get the EQ ones that are always on E bay. You can even get them already drilled for LA intakes if you already have an LA intake.
The stock ones are prone to crack right between the intake and exhaust valves. I made the mistake of buying some freshly rebuilt stock ones and ended up with a pair of giant paper weights.
Re: Magnum heads on 360 LA [Re: Evil_Ways] #682181
04/28/10 02:40 AM
04/28/10 02:40 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
http://www.hughesengines.com/Index/produ...mp;partid=25702
$699 ready to go with LA intake..or they are also available with magnum intake..
Tony
70 AARCuda Vitamin C
Re: Magnum heads on 360 LA [Re: Evil_Ways] #682182
04/28/10 03:15 AM
04/28/10 03:15 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Regarding the "Large Paperweights" cracked heads....What caused you to remove them? Did you blow a head gasket or get leaks into the cooling system? I passed on several junkyard heads when I saw that they were cracked. My machinist said that in most cases, the cracks would pose no problem. I didn't want to risk it.
Re: Magnum heads on 360 LA [Re: Kern Dog] #682183
04/28/10 06:23 AM
04/28/10 06:23 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
As a retired Chrysler line tech I can't recall a single magnum 5.2 or 5.9 that was in the shop for a problem caused by cracked heads.
Intakes plates sucking oil yes, cracks in the head causing a problem no.
Like anything in life I'm sure it caused someone a problem but working on thousands of Dodge rams at Linder Dodge we never ran across it.
IMHO
Gary
Re: Magnum heads on 360 LA [Re: Mapandjlp] #682184
04/28/10 07:00 AM
04/28/10 07:00 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
with stock pistons and if you can find the thin (.028") head gaskets, you'll be about 8.75:1 with magnum heads. the hughes ones for $699/pr is the best deal around, as they have springs that'll handle a nice hydraulic roller or solid flat tappet up to about .540" lift.
the accessory holes are in the same location as the LA heads, but they are all on the same plane, wheras the LA's lower hole is rearward by like 3/4" or 1". I had to modify my alternator bracket to fit. also, the front shape of the head is slightly different, and interfered with the back of the alternator, and I had to space all my accessories out about 1/8".
2017 Grand Cherokee Overland
Re: Magnum heads on 360 LA [Re: Mapandjlp] #682185
04/28/10 07:18 AM
04/28/10 07:18 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
I used Magnum heads, Weisco dished pistons to get tight quench and a 4 inch crank. I'm very happy with the results
Re: Magnum heads on 360 LA [Re: dmerc] #682186
04/28/10 04:41 PM
04/28/10 04:41 PM
Middle River, MD
Middle River, MD
Did you have to do any other work to the block to use the 4" crank? No clearancing? What rods did you use?
Re: Magnum heads on 360 LA [Re: Mapandjlp] #682187
04/28/10 05:23 PM
04/28/10 05:23 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
My 4" crank cleared with eagle sir rods- they have the ARP capscrews. I think nut and bolt setups or H-beams need notching.
Re: Magnum heads on 360 LA [Re: Mapandjlp] #682188
04/28/10 08:39 PM
04/28/10 08:39 PM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
Nope, no grinding on anything. I too used the SIR rods and as a bonus I was able to neutral balance the crank without using any mallory metal.
Re: Magnum heads on 360 LA [Re: gdonovan] #682189
04/28/10 09:01 PM
04/28/10 09:01 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
I guess I'm the odd case then. My 98 5.9 ram had cracks between the intake and exhaust valves on both heads. #1&7 also #2&8. The truck would miss and coolant bottle would drop slowly over time. I finally snapped a spark plug off in the head trying to remove it. Thats when I decieded to replace the heads. The truck only had around 35000 miles on it when this happened. It was out of warrenty by time not miles. Chrysler offered nothing to help When I called them they said no problems they are aware of. I said thats funny the local rebuilder says most sets they see are all cracked between the valves. The truck now has about 86000 miles so far so good. The reman heads I put on were repaired in this same area.
Re: Magnum heads on 360 LA [Re: dmerc] #682190
04/28/10 10:18 PM
04/28/10 10:18 PM
Which 4" crank and do you remember the bobweight?
Re: Magnum heads on 360 LA [Re: Kern Dog] #682191
04/29/10 12:58 AM
04/29/10 12:58 AM
Concord California
E
Evil_Ways Offline
Evil_Ways  Offline
E
Concord California
Actually I never even installed them. I bought them from someone who had them on a freshly rebuilt motor (maybe 1500 - 2000 miles on them) and then decided to go with some edelbrocks and a bigger motor. After reading about so many people getting magnum heads and then finding out they were cracked. I took mine to my usual machine shop just for some piece of mind.
They called me back and said they were BOTH cracked right between the intake and exhaust valves. They said they see alot of the magnum heads come in and that's the spot they always crack. Something about a thin spot in the castings.
Re: Magnum heads on 360 LA [Re: RapidRobert] #682192
04/30/10 06:26 AM
04/30/10 06:26 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
Pretty sure it was an Eagle cast crank and the bob weight total was 1760 grams.
Re: Magnum heads on 360 LA [Re: dmerc] #682193
04/30/10 09:44 AM
04/30/10 09:44 AM
thank you Dmerc and I have an Eagle cast 4" crank.
Re: Magnum heads on 360 LA [Re: RapidRobert] #682194
05/01/10 01:21 AM
05/01/10 01:21 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
the eagle cast cranks balance very easily because they leave out critical weight in important places on the rod journal side of the crank, particularly the front journal overlap area, seen quite a few break in extremely mild engines
