Re: Burnout technique?
[Re: Kevins493]
#681184
04/27/10 04:55 PM
04/27/10 04:55 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have only raced with street radials and found they would get greassy if I got em too hot so I just get the rear tires wet put it in 1st and stomp it with no brakes for a couple seconds and they were good to go. No need to run 6000rpm mabey 4000 max, I always run a VB with low band apply and never had a problem. My favorite car I drag raced was a 4dr 66 dart with a mild 360 and a 2.94 open 7.25 rear. I pulled pretty consistent 2.1 60s and ocasionally got a 2.0 flat. When doing the burn out with that car I had to run the steering back and forth a little to make sure both tires got a little spin.
[Re: 62 Savoy]
#681186
04/27/10 05:06 PM
04/27/10 05:06 PM
Posts: 2,379 MD
Kevins493
MD
As far as burnout technique, here's what i do: Start in second, bring it up to 5000, shift to high, give it a little more throttle, at 6000 or so release the linelock, more power to hold it at 6000ish, do rolling burnout at least 10 ft to get you out of the water thrown forward by the tires and the balled-up rubber near the burnout box. Stop, kick it in neutral, clear motor, pull up to the line allowing 10ft or so to ensure proper engagement. Never stop the burnout in the water or near it, never start in first gear. I usually do a bit longer of a rolling burnout (if you watch videos of my car, it almost looks like I dont hold it in the box at all) because i used to drive a jr dragster and that's what I'm used to.
[Re: Bob_Coomer]
#681189
04/27/10 07:22 PM
04/27/10 07:22 PM
Posts: 2,042 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
At some of the tracks I run at, we have to pull from the staging lanes and BACK into burn out box. I back into water, flap the throttle to get tires wet and roll out of water to do burn out. Trans in 2nd gear, line lock on, whack the throttle hard to get up on the tires and immediatly go to high gear. About 1 1/2-2 seconds, turn loose of the line lock and as the car starts to move foreward, I start rolling out of the throttle till it starts to bite, let completely out of the throttle and roll towards the beams. I stop short of the top light, go to Neutral, turn on air shifter, put pre stage light on and wait. (no hilbilly tune up for me, car "idles" about 1800 RPM's) I'm not sure why I don't have a very long tire life??? Brian Dunnigan
