Found my valve train noise problem / bad head :(
#680341
04/25/10 09:58 PM
04/25/10 09:58 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Well, took the car out today and it seemed to be running good.... I hope this link works: http://www.facebook.com/video/video.php?v=1278280237340Then right about when I got home it started making bad noises. Pulled the valve covers, and found the #3 exhaust pushrod sitting between the intake and exhaust rockers. At first I thought I may have bent a pushrod? went to remove the rocker arms/shaft and the center hold down was really loose:
Re: Found my valve train noise problem / bad head :(
[Re: '72CudaRacer]
#680346
04/25/10 10:16 PM
04/25/10 10:16 PM
451Mopar
Aurora, Colorado
It looks like there was a flaw in the casting? the other head and all the other rocker stands look fine. The heads are new Victor MW heads, running T&D 1.6:1 rockers. I need to call Edelbrock and see if they will warranty the head, but I'm still out several hours of porting and a valve job, not to mention I don't know where the other 1/2 of the stand went! I'll probably have to pull the motor, clean it out and hope that is the only dammage I need to go through my old photos and check if there may have been evidence of a crack there when I got the heads? Maybe i should have got the procomp heads
[Re: 440forPOWER]
#680347
04/25/10 10:19 PM
04/25/10 10:19 PM
451Mopar
Aurora, Colorado
Is that a pro comp head?
Look at second photo right hand side.. New Edelbrock heads that what is really upsetting
[Re: lilred]
#680350
04/26/10 07:42 AM
04/26/10 07:42 AM
Posts: 1,443 Maryland
Dads426
Maryland
If there is enough thread engagement with the stud, I would just mill it flat and use a billet hold down like they use on the early max wedge heads. Angelucci Manufacturing Maybe they will sell you just one. You may have to shim/machine it to get the right height.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: 572B1]
#680352
04/26/10 08:13 AM
04/26/10 08:13 AM
451Mopar
Aurora, Colorado
How much side clearance on the rockers.
I'll have to go measure? The is no visual evidence on the rockers or spacers of the side clearance being too tight.
Maybe I should tig weld in some gussets on all the stands after fixing this one
I'm probbably screwed on the warranty because I bought the heads in June of 2008. Besides It may be easier to fix the rocker stand then get a new head, port it, do valve job, cut spring seats, and clearance the pushrod holes.
[Re: Dads426]
#680353
04/26/10 12:59 PM
04/26/10 12:59 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
[Re: 451Mopar]
#680354
04/26/10 02:26 PM
04/26/10 02:26 PM
i've seen that type of failure before. we make bolt on rocker stands but we have to have the head to do it. i would say from what i've seen in the past, it's not normally the fault of the head. in any event, it's certaily repairable.
[Re: AndyF]
#680357
04/26/10 07:39 PM
04/26/10 07:39 PM
451Mopar
Aurora, Colorado
I did have 0.020" rocker shaft shims, could that have caused the problem? The cam is a Comp HXL lobe profile which I think is more agressive profile than normal, but is supposed to have better harmonics that the .440 lobe profiles. The cam is not that big, only 264/264 @ 0.050", 0.714"/0.714" lift (with the 1.6:1 ratio), 112 LSA, installed at 108. Have 1.6:1 ratio T&D rockers, and 3/8" Smith Brothers pushrods, and all the pushrods/rocker gear appear to be oiling fine. The springs are PAC 1325 with Crower Ti retainers (+0.100"), machined steel 10-degree locks (standard height), 0.060" spring seat with the correct size inner locator, spring install height is 1.950", seat pressure is 275#, I think the open pressure is 715#, no problem with coil bind, or retainer to guide clearance. I also have plenty of piston to valve clearance. Originally I wanted to install the springs at 2.00" using +0.050" locks which would have reduced the seat pressure to 250#, but the retainer was too close to the bottom of the rocker arm, so I used the standard locks and 1.950" install height. Could it be the spring pressures are too high for the stands?
[Re: 451Mopar]
#680359
04/26/10 09:38 PM
04/26/10 09:38 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
If I am seeing it right, I see the piece you are missing.. Right below the head bolt..
Chris..
[Re: Chris'sBarracuda]
#680360
04/26/10 11:16 PM
04/26/10 11:16 PM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
Chris..
Yep, I see it too! Just below the rocker stand that is to the right of the damaged one.
