Found my valve train noise problem / bad head :( #680341
04/25/10 09:58 PM
04/25/10 09:58 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Well, took the car out today and it seemed to be running good....
I hope this link works:
http://www.facebook.com/video/video.php?v=1278280237340
Then right about when I got home it started making bad noises. Pulled the valve covers, and found the #3 exhaust pushrod sitting between the intake and exhaust rockers. At first I thought I may have bent a pushrod? went to remove the rocker arms/shaft and the center hold down was really loose:
Re: Found my valve train noise problem / bad head :( [Re: 451Mopar] #680342
04/25/10 10:00 PM
04/25/10 10:00 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Another view:
Re: Found my valve train noise problem / bad head :( [Re: 451Mopar] #680343
04/25/10 10:04 PM
04/25/10 10:04 PM
tboomer Offline
Happy Birthday tboomer  Offline
Ouch!! What hold downs??
Re: Found my valve train noise problem / bad head :( [Re: 451Mopar] #680344
04/25/10 10:06 PM
04/25/10 10:06 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Now thats real nice. Are/were they new heads? I'm guessing that it can be repaired, but I'd really want to know what caused it before I just fixed it and put it back together. Good luck.
Brian
Re: Found my valve train noise problem / bad head :( [Re: '72CudaRacer] #680345
04/25/10 10:09 PM
04/25/10 10:09 PM
Lincoln NE
440forPOWER Offline
super gas
440forPOWER  Offline
super gas
Lincoln NE
Is that a pro comp head?
Re: Found my valve train noise problem / bad head :( [Re: '72CudaRacer] #680346
04/25/10 10:16 PM
04/25/10 10:16 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
It looks like there was a flaw in the casting?
the other head and all the other rocker stands look fine. The heads are new Victor MW heads, running T&D 1.6:1 rockers. I need to call Edelbrock and see if they will warranty the head, but I'm still out several hours of porting and a valve job, not to mention I don't know where the other 1/2 of the stand went! I'll probably have to pull the motor, clean it out and hope that is the only dammage
I need to go through my old photos and check if there may have been evidence of a crack there when I got the heads?
Maybe i should have got the procomp heads
Re: Found my valve train noise problem / bad head :( [Re: 440forPOWER] #680347
04/25/10 10:19 PM
04/25/10 10:19 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Look at second photo right hand side..
New Edelbrock heads that what is really upsetting
Re: Found my valve train noise problem / bad head :( [Re: 451Mopar] #680348
04/25/10 10:30 PM
04/25/10 10:30 PM
Lincoln NE
440forPOWER Offline
super gas
440forPOWER  Offline
super gas
Lincoln NE
Sorry, don't see to well in my old age.
Re: Found my valve train noise problem / bad head :( [Re: 440forPOWER] #680349
04/25/10 10:39 PM
04/25/10 10:39 PM
katakan
lilred Offline
lilred  Offline
katakan
Good luck with VIC the DI_K, I had a water pump from them go bad, sent down all kinds of pics to show proof of damage as well as the pump itself and they kept beating around the bush forever as well they quit answering my emails at that point I just gave up and promised to never buy another part certified by the D_CK himself and tell as many ppl as possible about their quality parts, again good luck!!!
Re: Found my valve train noise problem / bad head :( [Re: lilred] #680350
04/26/10 07:42 AM
04/26/10 07:42 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
If there is enough thread engagement with the stud, I would just mill it flat and use a billet hold down like they use on the early max wedge heads. Angelucci Manufacturing Maybe they will sell you just one. You may have to shim/machine it to get the right height.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Found my valve train noise problem / bad head :( [Re: Dads426] #680351
04/26/10 07:45 AM
04/26/10 07:45 AM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
How much side clearance on the rockers.
Re: Found my valve train noise problem / bad head :( [Re: 572B1] #680352
04/26/10 08:13 AM
04/26/10 08:13 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I'll have to go measure? The is no visual evidence on the rockers or spacers of the side clearance being too tight.
Maybe I should tig weld in some gussets on all the stands after fixing this one
I'm probbably screwed on the warranty because I bought the heads in June of 2008.
Besides It may be easier to fix the rocker stand then get a new head, port it, do valve job, cut spring seats, and clearance the pushrod holes.
Re: Found my valve train noise problem / bad head :( [Re: Dads426] #680353
04/26/10 12:59 PM
04/26/10 12:59 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Re: Found my valve train noise problem / bad head :( [Re: 451Mopar] #680354
04/26/10 02:26 PM
04/26/10 02:26 PM
i've seen that type of failure before. we make bolt on rocker stands but we have to have the head to do it.
i would say from what i've seen in the past, it's not normally the fault of the head. in any event, it's certaily repairable.
Re: Found my valve train noise problem / bad head :( [Re: 451Mopar] #680355
04/26/10 03:21 PM
04/26/10 03:21 PM
Call Edlbrock and see if they will look at it and analyse why it failed and repair it for you for no charge Worst thing they can say is no
Re: Found my valve train noise problem / bad head :( [Re: 451Mopar] #680356
04/26/10 03:41 PM
04/26/10 03:41 PM
AndyF Offline
AndyF  Offline
Should be able to fix that by going to rocker arm stands. Might want to carefully check over the whole valvetrain. You either had something together wrong or else you have a nasty valvetrain harmonic issue. Could be cam, pushrods, valve springs or the combination of those items. Something isn't right there, that is for sure.
Re: Found my valve train noise problem / bad head :( [Re: AndyF] #680357
04/26/10 07:39 PM
04/26/10 07:39 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I did have 0.020" rocker shaft shims, could that have caused the problem? The cam is a Comp HXL lobe profile which I think is more agressive profile than normal, but is supposed to have better harmonics that the .440 lobe profiles.
The cam is not that big, only 264/264 @ 0.050", 0.714"/0.714" lift (with the 1.6:1 ratio), 112 LSA, installed at 108.
Have 1.6:1 ratio T&D rockers, and 3/8" Smith Brothers pushrods, and all the pushrods/rocker gear appear to be oiling fine.
The springs are PAC 1325 with Crower Ti retainers (+0.100"), machined steel 10-degree locks (standard height), 0.060" spring seat with the correct size inner locator, spring install height is 1.950", seat pressure is 275#, I think the open pressure is 715#, no problem with coil bind, or retainer to guide clearance. I also have plenty of piston to valve clearance. Originally I wanted to install the springs at 2.00" using +0.050" locks which would have reduced the seat pressure to 250#, but the retainer was too close to the bottom of the rocker arm, so I used the standard locks and 1.950" install height.
Could it be the spring pressures are too high for the stands?
Re: Found my valve train noise problem / bad head :( [Re: 451Mopar] #680358
04/26/10 08:23 PM
04/26/10 08:23 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Thats what I was kind of thinking...
Re: Found my valve train noise problem / bad head :( [Re: 451Mopar] #680359
04/26/10 09:38 PM
04/26/10 09:38 PM
Arizona
Chris'sBarracuda Offline
Arizona
If I am seeing it right, I see the piece you are missing.. Right below the head bolt..
Chris..
Re: Found my valve train noise problem / bad head :( [Re: Chris'sBarracuda] #680360
04/26/10 11:16 PM
04/26/10 11:16 PM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
Chris..
Yep, I see it too! Just below the rocker stand that is to the right of the damaged one.
