Re: Help my doggy 383
[Re: Dougsmopars]
#680178
04/26/10 07:31 PM
04/26/10 07:31 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
42 to 44 is to much total for a big block mopar. 36 to 38 tops.
I agree. Without knowing what cam he has it is hard to try and cover up the problem without throwing a bunch of tricks,do dads and such at it and get good resaults. he could have a 509 cam low compresion low staul coverter and you could never make it right. Put a dial indicater on the thing and find out what cam it is. Then maybe put a deree wheel on it and find out where it is instauled at. That would tell you what direction to go. If it is anything like the video that guy was shifting and he wasn't on the pipe yet.We have found on the dyno that most pump gas big blocks like 32-34 total.
JAKES AUTOMOTIVE
[Re: JAKE68]
#680179
04/26/10 10:18 PM
04/26/10 10:18 PM
Posts: 1,647 IL
71383beep
IL
FWIW...my 383 was doggy with the big open chamber 906 heads. With a set of 516s on her now she is a totally different animal and she is running the .474 cam. It DEFINITELY puts you in your seat and will annihilate the tires from a stop. So my ![](/ubbthreads/images/graemlins/Twocents.gif) says that you may be very low on compression and that is really all you need to work on.
'73 GK6 Challenger Rallye - 340 4-Speed
[Re: Dougsmopars]
#680181
04/27/10 07:59 AM
04/27/10 07:59 AM
JAKE68
Shelby mi.
i agree that there are alot of newer cams that will have better manners and make more power with less but that 509 is by no means junk. It just likes compresion,converter and gear to work good. If any of the combo is off it could be a turd.
JAKES AUTOMOTIVE
[Re: Paul_Fancsali]
#680184
04/27/10 03:16 PM
04/27/10 03:16 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
My reply for 42-44 is for a car with low comp and too much cam like the 509 Too many people go by the Mopar perf bible that are often way out of date.I had a Mopar perf tech guy tell me a 509 would be ok in a small block with exhaust manifolds NOT. Now I do my own thing and if it works for me so be it.
Paul, you're right. Them little guys need timing. It is NOT a 440. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 71383beep]
#680186
04/27/10 07:02 PM
04/27/10 07:02 PM
Posts: 583 San Antonio, TX
CurYellowBird
San Antonio, TX
Hey 71383bee,
How do you like that .474/.474 MP cam?
I'm looking at a build for the 383 in my 71'bird and I think we talked a couple times before. Comp cams camquest version of this MP cam gives my 383 the max hp and torque and should work well with my 4 speed and AC.
What gears and transmission are you running? Hi-po manifolds or headers?
Don't mean to hijack the thread, just not alot of guys who drive the 383 as much as 440's, or the MP cams since they are "old technology".
Project War Bird:
1971 Plymouth Roadrunner
383 4 speed with air conditioning
GY3 Curious yellow
All original
[Re: CurYellowBird]
#680187
04/27/10 09:19 PM
04/27/10 09:19 PM
Posts: 4,503 NJ
440challenger
NJ
Well a little update. i went to check timing today with my matco dial back and it seems to not be working... It will flash but with very long pauses in between. Who makes one that works with a an msd box? So i ended up just popping the distributor out and i looked under the plate and realized one of the advance springs was missing! The remaining spring was the lighter of the factory installed springs. I ended up putting BOTH Mopar perf. Light springs in and stabbed the dist. back in where it was. I had no way to check timing but i did notice when i fired the motor up my rpms went from a previous 700rpm at idle to now 1k at idle,and a noticeabley smoother idle/power.. On test ride it was a night and day seat of pants difference. Now i just need a timing light to see where im at. It looks like she has some potential to make some decent power. ![](/ubbthreads/images/graemlins/thumbs.gif) I do notice now when i rev it out and shift from 1st to 2nd 2nd to 3rd it lags quite a bit before it goes into gear. its not a firm shift. is this an adjustment that i can make or do i need a shift kit? Thanks for the help so far! ![](/ubbthreads/images/graemlins/punkrocka.gif)
[Re: Dougsmopars]
#680192
04/28/10 06:42 PM
04/28/10 06:42 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
plllussst... ran 383's up to 42 easy on a good day and good gas. give it as much timing as it will take.
[Re: CurYellowBird]
#680194
04/28/10 06:50 PM
04/28/10 06:50 PM
Posts: 1,647 IL
71383beep
IL
Hey 71383bee,
I am very happy with it. It has got excellent street manners and can bring it when it needs to. The motor dyno'd at 400/430 hp/tq which was my goal.
Its a pretty mild build really...040 over on the bores, KB162 pistons, mill the deck 020, built 516 heads with the 2.14/1.74 valves IIRC and a bit of bowl blend and porting, Comps 474 version (nostalgia purple plus) cam, street dominator intake, FBO prepped 650 mighty Demon, and the FBO ignition.
Haven't tried it at the track. Running a 727 auto with the TF2 shift improver kit and 3.73 gears. I prefer to slapstick it. From a stop first gear is virtually useless with the tires I have, but its a fun cruiser! There certainly is faster out there, but she holds her own pretty well. I can drive it anywhere and she holds an idle very well with power brakes.
I have been following your thread too. FWIW i would just try and coax 400 to 450 hp from your stock 383 and keep it mostly stock appearing. Unless you already have the 440 that is. I do have to agree that as much fun as having an absolute killer 500 hp motor is it does eat in to how much you really can use the car. Especially it being a fairly rare real 4 speed high impact bird. 400 hp is still a lot of fun and it has good street manners means IMHO that you can do more with the car. I have several friends that have invested so much into there cars that they are no longer as tame for taking on nice cruises or going to a long distance show. they kill at the strip which is cool, but they sometimes miss out on just cruising the backroads and raising a bit of he[[! A 400 to 450 hp mill will still be respectable at the strip and you won;t have to modify the car much to handle it. Anyways thats just my ![](/ubbthreads/images/graemlins/Twocents.gif)
