Re: Roller rocker arms for 440
[Re: AndyF]
#675893
04/21/10 04:25 PM
04/21/10 04:25 PM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
Put stock rockers on it. Then, take the money you saved and spend it on a a higher stall converter, sticky tires, an 850 carb etc. Either way, the money's spent....pick your poison
Rich H.
Esse Quam Videri
[Re: AndyF]
#675894
04/21/10 04:30 PM
04/21/10 04:30 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Why waste your money, just use stock stamped rocker arms. That cam is barely bigger than a factory cam, no need to get trick with the rocker arms. Listen to the advice people are giving you, save your money for something that matters.
With all due respect, Andy, I've broken dozens of Chrysler stamped steel rockers in my E/sa Duster. I had to use them back when I was racing in stock eliminator. I wouldn't use those things on my lawn mower. Crane Gold's are the best bang for the budget being discussed here.
[Re: AndyF]
#675897
04/21/10 09:15 PM
04/21/10 09:15 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Buddy ran 11.70's all day in a 67 GTX w/ a 509 and 4.10's. Stock rockers and shafts. I ran 12.0's in 67 coronet 440 all day stock rockers and shafts. If you do anything just run the old school ductiles
[Re: forphorty]
#675899
04/22/10 12:56 AM
04/22/10 12:56 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
If this is just a simple Hyd flat cam read on.. I know my opinion isnt worth but just a few penny's, but I cant believe anyone hasnt asked why such high spring pressure for a simple Hyd flat tappet cam? I mean for a engine that wont see or I should say cant see much over 6K...Why all the suggestions for $1000+ rocker arms? I would just use a good set of HD stock rocker arms. I mean 350 lbs open pressure on a MP 509 equivalent cam... That engine doesnt need much over 100 lbs seat and 225-250 lbs open pressure, and he wont eat parts from race to race. I can say this..they are 99% better than the proform junk
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: AndyF]
#675902
04/22/10 09:23 AM
04/22/10 09:23 AM
BobR
Left Coast
I would imagine that a E/SA motor gets wound a little tighter than what this guy will be doing. The engine build sounds so mild to me that I can't see him wasting money on aftermarket parts.
Shifted at 7000. The pushrod cup use to get knocked out of them like it was stamped out and the pushrod would go up and down in the hole without opening the valve.
[Re: AutoEngineer]
#675907
04/23/10 12:48 PM
04/23/10 12:48 PM
Posts: 179 Up in the North and Far Away
AutoEngineer
Thanx a lot for all your comments From stamped steel rockers I have so many bad earlier experiences. Pushrods hitting their way up through the cup. Yup, it's not worth of using close to $900 rockers on $900 heads and mild combo. When bought the set of Proforms, it honestly was a wrong decision. You just can't buy a cheap and a good in a same package. If you want, you have to buy them separately, and it will cost more money than buying the good at first. In our case we had the possibility to return the Proforms back to the Speed Shop. Find enclosed a picture from the Proforms. 14 of the set of 16 were similar and having blue anodization on the bearing surface. Harland Sharp rockers are having large fulcrum needle bearings between the arm and the shaft. I'm a little bit afraid how they stand against wear. Maybe I shouldn't, but 440Source set is having similar construction and I have seen one that had had excessive wear on shafts and arm bearings after only a few 100 miles. Ductile iron rockers, for sure they are bullet proof, but are they causing more wear to the valve tip and valve guides than rollers??? And a little bit higher mass inertia I know this inertia issue is not a critical characteristic on this combo, but it just came to mind when thinking pros and cons
[Re: AutoEngineer]
#675908
04/23/10 12:55 PM
04/23/10 12:55 PM
Thumperdart
State of confusion
As far as the wear issues w/ HS`s, I`ve been street driving and racing mine for over 5 years and they`re still going strong w/a solid roller w/580+ lbs open pressures for what it`s worth.
