Page 3 of 3 1 2 3
Re: B Body Fuel Sending Unit [Re: PAINT IT BLACK] #674883
04/25/10 07:14 AM
04/25/10 07:14 AM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
New fuel gauge is in, and nothing solved.
I give up.
Thanks for the help though guys.
No offense, but I don't understand your mentality. If you let something like a silly sending unit beat you so easily, I can't imagine what other things in life have passed you by. Get out there, grab it by the horns and FIX THAT CAR!
So when are you getting here in Ohio? Seems like you're willing to help in person. Thanks!
1968 Plymouth Road Runner 383 4 speed
Re: B Body Fuel Sending Unit [Re: dobie] #674884
04/25/10 07:21 AM
04/25/10 07:21 AM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
Before I put the sender in, I tried it with the gauge. There was a huge dead spot. The float arm was 3/4 up when the gauge finally read anything, but at least it did go all the way to full. My factory gauge never did that. Right now I have about 14-17 gallons in it, and the needle barely comes off of E. Clearly, it's not the gauge, as it now appears to be the sending unit.
For now I guess I'll just burn through this tank of gas. No sense in draining out a full tank. Once empty again, I'll try working on the sending unit itself.
Re: B Body Fuel Sending Unit [Re: dobie] #674885
04/25/10 10:56 AM
04/25/10 10:56 AM
Red Bluff, CA
W
WilliamHall Offline
super gas
WilliamHall  Offline
super gas
W
Red Bluff, CA
Dobie, mine did the exact same thing(huge dead spot). The reason there is a dead spot is that the copper tab I pictured above is not making enough contact with the varying resistor. The solution is to bend the copper tab up so that it makes a harder contact.
Re: B Body Fuel Sending Unit [Re: WilliamHall] #674886
04/25/10 12:23 PM
04/25/10 12:23 PM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
I'll definitely try that. Any reason though why it worked better out of the car vs. installed in the tank?
Page 3 of 3 1 2 3
