B Body Fuel Sending Unit
#674843
04/19/10 02:16 PM
04/19/10 02:16 PM
Posts: 1,032 Ohio
dobie
Ohio
In searching things on the web yesterday, I found out that Right Stuff Detailing now has fuel tank sending units. I currently have their steel brake lines installed, and I've been very happy with them, and their company.
Obviously, my current sending unit isn't worth a crap, as it's way off, like everyone else's. It was bought new from Herb's Parts a few years ago. I just installed it last year, and it reads empty all the time. Grounds are good, as I even installed another ground wire to eliminate that problem.
Anyways, I called Right Stuff this morning and chatted with their tech guys. Of course, their's is imported as well, but no specific manufacture info could be provided. I had hoped for American made, thinking that finally someone will produce one that will actually work.
Anyways, does anyone here have one of the Right Stuff's sending units? I'm hoping for a good/bad/indifferent review of actual experience with one.
Thanks!
1968 Plymouth Road Runner
383 4 speed
Re: B Body Fuel Sending Unit
[Re: dobie]
#674844
04/19/10 03:19 PM
04/19/10 03:19 PM
Posts: 6,516 Santa Cruz, California
Lefty
Something else is wrong. I've never seen senders be more than 1/4 tank off the correct reading. Check the ohms, it should read between 10-90 ohms.
[Re: mopar mike]
#674847
04/19/10 03:55 PM
04/19/10 03:55 PM
Posts: 1,032 Ohio
dobie
Ohio
if the ground was bad, i beleive it should be reading way past full?? you could have a grounded wire to the sender??
I have a reproduction part sending unit ground strap installed. It runs from the nipple on the sender to the metal fuel line. It's the metal band with the 2 alligator type clips on both ends. I've tried taking it off, connecting it on other areas, it all makes no difference whether one is installed or not. All of my other factory gauges work fine. I've never tested the gauge itself, but with it being installed in the dash, there's no way I'm pulling it out just to test it at this point. If that's the case, I guess I'll just live with it for awhile.
383 4 speed
[Re: dobie]
#674848
04/19/10 04:07 PM
04/19/10 04:07 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
To test the gauge go to any electronics supply even Radio Shack may be able to help.. Get a 75 Ohm resistor & a 10 ohm resistor.. Together you should spend considerably less than $5.00 Connect the 10 ohm resistor to the wire going to the sending unit.. Ground the other end of the resistor.. Turn the ignition on, the gauge should read full... Now try the 75 ohm resistor, the gauge should read empty... If it passes both these tests look for a shop (like Instrument Specialties) to rewind your original Sending Unit...
[Re: dobie]
#674851
04/19/10 05:13 PM
04/19/10 05:13 PM
Lefty
This is the multimeter I have. Obviously I'd use the ohms stuff, but what setting do I set the dial at, and where should the leads be placed on the car/sending unit?
http://www.sears.com/shc/s/p_10153_12605_03482141000P?keyword=multimeter
Set it on the 200 ohms scale. Test the meter by touching the two test leads together and make sure you're seeing less than 1.00 ohm. If that test passes, put one lead on the body of the sender and one lead on the terminal you connect the wire that goes to the gauge. With the sender arm at each end of it's operating range you should see the 10-90 ohm sweep on the meter.
[Re: 1_WILD_RT]
#674854
04/19/10 09:46 PM
04/19/10 09:46 PM
Posts: 1,032 Ohio
dobie
Ohio
I certainly will. I plan on going to Radio Shack in the morning.
Thanks!
383 4 speed
[Re: Lefty]
#674859
04/20/10 08:21 AM
04/20/10 08:21 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Mopars go empty when no ground.Hook a long ground wire to batt and to the sender wire.Turn on key and see if gauge goes full.If not you have a problem with power to sender or bad gauge.Rocky
Chrysler Firepower
[Re: therocks]
#674860
04/20/10 10:50 AM
04/20/10 10:50 AM
Posts: 1,032 Ohio
dobie
Ohio
Ok, the car is jacked up on stands now. Went to Radio Shack this morning and got a 10 ohm resistor. Looks like I'd need to solder it though. No clue on how to accomplish that. Right now, the easiest seems to be the ground wire Rocky suggested. I got that ready to go and will update accordingly. I only have about 7-10 gallons in the tank right now, so I'm wondering if that matters when I try the ground wire. Or, maybe grounding as suggested somehow overrides things and will cause the gauge to go to full..??
One thing I might add, the gauge seems to work, somewhat. On a full tank the needle goes to 1/2 tank, then drops quickly to empty. Never really seen it go much over 1/2 tank. Not sure what that might indicate.
383 4 speed
[Re: dobie]
#674861
04/20/10 11:32 AM
04/20/10 11:32 AM
therocks
Niles , Ohio
Take the power off the sender attach the ground from batt.Turn on key and gauge should peg.Just dont leave it on too long.Rocky
Chrysler Firepower
[Re: therocks]
#674862
04/20/10 12:22 PM
04/20/10 12:22 PM
Posts: 1,032 Ohio
dobie
Ohio
No Sir, the needle didn't move one bit.
Just to make sure, hook one side to the positive terminal and the other to the sending unit itself, or the blue wire going to the sending unit?
383 4 speed
