Re: SS SPRING CARS.
[Re: MIKES_DUSTER]
#673218
04/18/10 03:02 AM
04/18/10 03:02 AM
Posts: 4,648 aotearoa
rebel
aotearoa
on the bottom hole for max tire clearence.
Re: SS SPRING CARS.
[Re: MIKES_DUSTER]
#673222
04/18/10 12:30 PM
04/18/10 12:30 PM
Thumperdart
State of confusion
I saw your other post and now this one and although some run hard w/ss springs, I`d save my coin and get Cal-Tacs and b done with it. It`s the LAST set of springs you`ll ever need and the quickest on the planet hands down + you can pick the ride height you`d like and use lowering blocks to dial it in if needed. ![](/ubbthreads/images/graemlins/Twocents.gif)
Re: SS SPRING CARS.
[Re: Locomotion]
#673224
04/18/10 01:50 PM
04/18/10 01:50 PM
Posts: 2,058 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
mine. SS leafs with a extra leaf in the right side, no snubber, long 50/50 shocks, 11.5 X29.5 MT tires, 6 cyl torsion bars, front lowered almost on bumpers static, calvert front shocks. 60' 1.40 (best 60' 1.370), ET 6.58.
Re: SS SPRING CARS.
[Re: '72CudaRacer]
#673225
04/18/10 02:03 PM
04/18/10 02:03 PM
Posts: 6,653 Near Reading PA USA
pinkduster
Near Reading PA USA
I put SS springs on my 71 Duster back around 1995. In my opiinion, they haven't sagged down a bit after all this time. I used to run the stock 14 inch rallye wheels and I thought the ride height looked okay. A year or so ago, I got bored with stock stuff and decided to start modifying the car. First on the list was wheels and tires. I got a good deal on a set of polished Centerlines. However, when I installed the Centerlines with taller rear tires, I thought the ride height just looked rediculous. So I flipped the front spring mounts to lower the ride height. I think it looks a lot better like this, but it has caused some issues. Once in a while the tires will rub the quarters. Trimmed the lip on the driver's side and installed a pinion snubber to limit travel. Also, the pinion angle will clearly need to be addressed. See the picture that I put together. The bottom two pictures are from after I flipped the front mounts. ![](http://i491.photobucket.com/albums/rr274/pinkduster70/ss_springs.jpg)
Re: SS SPRING CARS.
[Re: MIKES_DUSTER]
#673231
04/18/10 09:28 PM
04/18/10 09:28 PM
pinkduster
Near Reading PA USA
THANKS guys!!!!!! What makes some cars have the rears high in the air and some cars look normal??
My guess...
A-body too high = SS springs with front mount normal.
A-body normal = SS springs with front mount flipped.
B-body too high = SS springs with front mount in lower hole.
B-body normal = SS springs with front mount in upper hole.
E-bodies = I don't know. Never had one, but I imagine they are like the B-bodies.
Re: SS SPRING CARS.
[Re: donscuda]
#673232
04/18/10 10:19 PM
04/18/10 10:19 PM
Posts: 1,162 s e mich
ro23car
s e mich
Here's mine... It was the first day out of paint and I had the torsion bars cranked up WAY too much in front, so it might not help you see the difference. I'll see if I can find a more recent photo for you...
is that a four wheel drive ![](/ubbthreads/images/graemlins/biggrin.gif)
Re: SS SPRING CARS.
[Re: pinkduster]
#673235
04/18/10 10:49 PM
04/18/10 10:49 PM
Posts: 9,146 Now - Port Orange,Fla. Former...
MIKES_DUSTER
What a HUGE difference!!!! I like the new look.
