Engine tuning questions - video included....
#672772
04/17/10 07:06 PM
04/17/10 07:06 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
So I've finally bolted my exhaust on so it's a little easier to hear myself think under the hood. I'll preface this by saying this is my first actual ground-up rebuild of a v8. I don't have anyone around as an official "mentor", nor do I know anyone I can bribe into acting as one. I'm having a hard time getting a "smooth" idle out of the engine. A couple of things: Starting with the carb IMS's at 1.5 turns out, adjusting the screw on the right outward produces no results, while I continue screwing out. Hmm? Going counter-clockwise (out) with the left screw produces a small increase in idle, but since my idle isn't rock solid stable, it's too difficult to determine. If both screws are bottomed out (accidentally did this earlier), the engine will still run and actually idle pretty well. Hmm? If I unplug my vacuum gauge from the carb base plate, there is no discernible difference in idle speed or quality. These above factors lead me to believe I've got a vacuum leak. The question is: how can I have 22" of vacuum at idle and still have a vacuum leak? Also, you might be able to hear it in the video, you might not. It almost sounds like a "miss" but it isn't constant in the firing cycle. It just isn't smooth, and you can see that when I point the camera at the dwell/tach meter. I do not have any clue if I've timed the engine right. I do not, currently, have a dial back light. I've got a standard light and if I disconnect the vacuum source going to the distributor vacuum pot (and plug it), and shine my light at the balancer at idle, the line is almost an inch below where the 10 mark is on the lower aspect of the timing indicator. I hope that makes sense. Where do I go from here? This will eventually be my daily driver, and I want it to be rock solid. The truck starts on the first crank, throttle response is crisp and sharp, and the engine refires and runs after it's hot and turned off. Please help me get in the right direction here. Thanks, and cheers -Pat Link to the video: http://www.youtube.com/watch?v=Qn3f48QKhTA
Re: Engine tuning questions - video included....
[Re: Pat_Whalen]
#672773
04/17/10 09:45 PM
04/17/10 09:45 PM
Posts: 598 NC, USA
davenc
NC, USA
Pat,
Here are a couple of thoughts...in the video the vacuum gauge was at 18 inches, not 22. If the car runs with the IMS closed, then it is getting fuel from somewhere other than the primaries. This could be via a carb leak (bowls not tight), or the secondaries are open too much. Cover the primaries with a rag to block them, and see if the motor still runs. Then, try the same on the secondaries.
What sort of cam and carb does the the engine have? I assume it is a hydraulic cam? The vacuum is fluctuating some, but not a huge amount.
Do the engine run more smoothly at 1500? 2000?
Regards, Dave
[Re: davenc]
#672774
04/17/10 10:47 PM
04/17/10 10:47 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
Pat,
Thanks Dave. I'll give that a shot tomorrow.
Hydraulic RV cam and 1406 Edelbrock carb. Not a "hot" setup by a long shot. Its in my 1980 ramcharger.
Regards, Dave
Engine does run fine at higher rpms. It just doesn't like sitting still at idle. I suppose I really should learn how to properly time an engine from start to finish.
[Re: Pat_Whalen]
#672777
04/18/10 06:40 PM
04/18/10 06:40 PM
Posts: 598 NC, USA
davenc
NC, USA
Pat,
With respect to timing, there are three things to consider on a street vehicle, initial, total mechanical, and total with vacuum. For starting, leave the vacuum disconnected from the distributor, and the vacuum hose plugged.
The amount of initial the engine will need will depend on several factors, including the size of the bore and the amount of overlap in the cam between intake and exhaust valve timing. With a stock 440 and a RV cam, the motor should not need a huge amount of initial, and if you have a stock distributor too much initial will lead to too much total mechanical advance at higher rpm.
How does the motor run with the initial timing set to 10 degrees before top dead center (BTDC)? I would suggest starting somewhere in the 10-12 degree BTDC range, and see if you can get the carb adjusted to the point where you think the idle is good.
To check the total timing, you will need a dial timing light. I know you stated you don't have one right now, and given that, you need to stay conservative on the initial to not end up with too much total. Factory distributor may have 26-28 degrees in it (don't remember the specifics), and a BB with iron head will likely run best with 36-38 degrees total.
Regards, Dave
[Re: davenc]
#672778
04/18/10 07:07 PM
04/18/10 07:07 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
Pat,
Regards, Dave
Thanks again Dave
I'm away from the truck right now (husbandly duties of hanging useless crap on my pristine, hole-free walls), but I'm almost positive if I were to run the truck at 10* btdc it would stall. When I shine the light down there as it is, idling like you see in the video, it's probably at around 16*. Could that be very wrong?
[Re: Pat_Whalen]
#672780
04/18/10 08:39 PM
04/18/10 08:39 PM
Posts: 18,025 S.E. Michigan
ZIPPY
S.E. Michigan
Judging from the way it comes down to idle quickly when you goose the throttle (in the open header video), I don't think there's a vacuum leak.
However you're there and I'm not, and it's always good to satisfy or deny any feeling it might have a leak.... so I recommend testing for vacuum leaks with water instead of carb cleaner so you don't eat up your new paint. A spray bottle with a "stream" adjustment on it works well. Any leak hit with water and sucked in will slow the idle down a bunch.
Rich H.
Esse Quam Videri
[Re: Pat_Whalen]
#672782
04/18/10 10:37 PM
04/18/10 10:37 PM
Posts: 598 NC, USA
davenc
NC, USA
Pat,
Yes that vacuum reading is lower than it should be for a stock-ish BB. It makes sense to eliminate the simpler stuff first. Zippy's method of finding a leak is better than what I suggested, and you should try and cross leaks off as a possible cause. Remember to spray anywhere that could suck air...any hose (entire length) that is connected to the carb, the carb to manifold gasket/sealing, and the manifold to cylinder head gasket/sealing.
When you get a chance, let us know about the cam installation. There was just another thread today in this forum about cam socket timing marks, and how easy it is to get it wrong the first time you install a cam, particularly if not degreeing it in.
Also, did you pull any plugs to see if there are any abnormal signs (oil, sooty, etc)?
Regards, Dave
[Re: davenc]
#672783
04/19/10 12:38 AM
04/19/10 12:38 AM
Pat_Whalen
super gas
super gas
Mesa, AZ
Pat,
Regards, Dave
I've also heard of using propane to check for vacuum leaks. Is that the "drier" method?
It would make sense to have a higher vacuum reading like I was getting with 16*+ of initial advance.
The cam, chain, and crank were all left alone during my rebuild. Their relationship with one another was not touched, and the engine ran perfectly fine. The only thing that I did move was the distributor drive gear to prime the oil pump. I suppose I could have dropped it back in out of orientation. I just don't understand the sporadically unsteady idle. Could me having the distributor drive gear installed on the wrong tooth cause that?
I guess my next step is going back to basics. Find TDC on compression of number 1, make sure rotor is pointing at number one wire at that point. Go from there?
Finding a vacuum leak with those other methods is a little difficult, especially because the idle climbs 100+ rpm sporadically on it's own, just while it's sitting there....
[Re: Joshs68]
#672785
04/19/10 01:24 PM
04/19/10 01:24 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
A couple of things that I found out this morning:
While checking the distributor diaphragm (it does hold vacuum), I noticed the reluctor had an arrow on it, indicating it's direction of rotation. Mine is obviously for a small block, as it's arrow indicates a clockwise rotation. How much, if any, does this matter?
I pulled the plugs. Not pretty. #1's ground strap was all but touching the electrode and is pretty much a solid black color. The others appear a bit better, with no coloring on the ground strap or electrode until about half way down the ground strap.
I also decided, while the plugs were out, to do a quick dry compression test. Numbers don't look good. I only got through cylinders 1 (125psi), 3 (112psi), and 5 (115psi).
I'm going to take a couple shots of the spark plugs and post them in a bit.
[Re: Pat_Whalen]
#672786
04/19/10 01:29 PM
04/19/10 01:29 PM
Posts: 6,109 Valencia, España
NachoRT74
Valencia, España
its in relation with PHASING
http://www.hotrodhotline.com/md/html/rotorphasing.php
http://www.msdignition.com/uploadedFiles...tor_phasing.pdf
BB are CCW and use a diff notch for the location pin. Thats for the diff movement of the vaccum/pickup plate too.
[Re: NachoRT74]
#672787
04/19/10 01:34 PM
04/19/10 01:34 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
So then the answer is that, yes, it does make a difference?
[Re: Pat_Whalen]
#672788
04/19/10 02:18 PM
04/19/10 02:18 PM
ZIPPY
S.E. Michigan
The reluctors have two roll pin slots, one with a CW arrow next to it and one with no arrow. For a big block, the roll pin should be installed in the slot that does not have an arrow near it.
15" of vacuum at a "normal" advance, and noticeably more manifold vacuum when the advance is cranked up is quite normal, and is what I'd expect for a mild cam in a low compression 440.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#672789
04/19/10 02:51 PM
04/19/10 02:51 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
Thanks Zippy
So I could just pull the roll pin out and put it in the other slot for the side that has no arrow, correct?
Here are a couple shots of the plugs. #1 looks like something may have impacted it, sending the ground strap close to the electrode. When is it a safe assumption that plugs cannot simply be cleaned up with a small wire brush and actually need to be replaced. These are new, with zero miles and about 2 hours total of operation on them.
Cylinder #1:
Cylinder #5:
[Re: Pat_Whalen]
#672791
04/19/10 03:44 PM
04/19/10 03:44 PM
Posts: 701 Northern California
lilcuda
Northern California
You said that the engine was rebuilt, but now you're saying that the cam, crank & timing chain were left alone. Did you just do a re-ring? Big difference between a rebuild and a re-ring. What was done to the heads?
