Re: 512 on the hook [Re: AndyF] #672609
04/19/10 09:50 PM
04/19/10 09:50 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Well making down the quarter mile has never been a big priority with me.
It would be nice to see how the dragstrip dyno matches up with the engine dyno you use. Being only about 15 minutes from Woodburn Dragstrip... Bring it to the Mopar Nats at WB and while you stand around your tables I'LL make some runs in it.
Cory
Re: 512 on the hook [Re: AndyF] #672610
04/19/10 09:53 PM
04/19/10 09:53 PM
Well making down the quarter mile has never been a big priority with me. This car has big brakes, big anti-sway bar up front, big torsion bars, etc. It isn't designed for drag racing but it does have enough power to do okay.
That sounds funny when there's shoe polish on the window.......
Wayne
Re: 512 on the hook #672611
04/19/10 10:31 PM
04/19/10 10:31 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
What were the issues wth the roller bearing cam?
I want my fair share
Re: 512 on the hook [Re: AndyF] #672612
04/19/10 10:34 PM
04/19/10 10:34 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello Andy,
Did you have it on the pump with the exhaust manifolds in place.
Damon
Re: 512 on the hook [Re: mopardamo] #672613
04/20/10 03:42 PM
04/20/10 03:42 PM
AndyF Offline OP
AndyF  Offline OP
I ran it on the dyno three times. It spun a main bearing the first time we ran it so the engine had to be pulled apart and redone. The second time it filled the Oberg up with trash so we pulled it apart again. Couldn't find a problem the second time so it went back together and back on the dyno the third time. Last time the Oberg stayed clean so now it is heading into the car. This engine has been cursed since the beginning!
I ran headers for the dyno session just because it was easier than rigging up the manifolds. With the camshaft that is in this engine I doubt there is any power difference between headers and manifolds. The engine only makes about 575 hp. I thin the cam is about 240 at 050 so it isn't a hp monster. Just supposed to be a nice cruiser with a Viper like power curve.
The issue with the camshaft roller bearings is the same issue as the cross bolted main caps. Way too much work for too little gain. This was an R&D exercise that got a little carried away. I probably have $20K invested in this motor and it doesn't make anymore power than a good solid $10K motor. But that is the way it goes when you're trying new stuff.
Re: 512 on the hook [Re: Jeremiah] #672614
04/20/10 03:47 PM
04/20/10 03:47 PM
AndyF Offline OP
AndyF  Offline OP
Looking awesome as always Andy. I'd love to know the number off of that shifter handle.
I don't know the part number of the shifter handle. It is just the standard Hurst shifter for a Doug Nash five speed. I bought this shifter more than 20 years ago so I'm sure I've lost the box by now!
Re: 512 on the hook [Re: AndyF] #672615
04/23/10 11:06 PM
04/23/10 11:06 PM
Canada
Mofopar Offline
Mofopar  Offline
Canada
What are you using for a pan gasket?
Windage tray?
Older looking damper too - ever had any problems with older dampers? Fluidamper told me I should replace my 20yr old piece.
Re: 512 on the hook [Re: Mofopar] #672616
04/23/10 11:22 PM
04/23/10 11:22 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Wow, Bud. Thats going to be a blast to drive. Thanks for posting.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
