Re: mini starter [Re: stinger] #672577
04/19/10 07:53 AM
04/19/10 07:53 AM
NY usa
540challenger Offline
NY usa
what I don't understand is all these people that say they have no problems with the headmen's and the few that do,what gives?
Alot of headers even the same part number are not the same. Why no clue old jigs, lack of quality control
Re: mini starter [Re: 540challenger] #672578
04/19/10 07:59 AM
04/19/10 07:59 AM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
looks like a 78030 but don't know for sure.elite's look the same to me.Sorry for the H/J. I'll smash some more as these are only for break in and driving the car to the body shop for paint,probably go with a set of Doug's later on.
Re: mini starter [Re: scratchnfotraction] #672579
04/19/10 08:25 AM
04/19/10 08:25 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
The 78030's are the ones I had trouble with.440 4 speed in a 63 Plym Savoy. You can run the mini starter if you don't mind beating the crap out of
the tube shown in the pics. It will still be very close to the headers. Large reg starter will work
with the 78030's The mini sticks out father from the block.
Re: mini starter [Re: pushbutton] #672580
04/19/10 09:58 AM
04/19/10 09:58 AM
Ontario,Canada
1967GTX440 Offline OP
Ontario,Canada
Thanks for all the info everyone.Not sure what to do now maybe just get my starter rebuilt.The car is a 67 GTX with headman headers has anyone put a mini starter on that combo.
Re: mini starter [Re: pushbutton] #672581
04/19/10 05:26 PM
04/19/10 05:26 PM
That's odd because I put a pair of 78030's in my '63 Dodge with a factory (truck) mini started and it clears fine! Did you have later K and engine mounts?!?
Re: mini starter #672582
04/19/10 05:31 PM
04/19/10 05:31 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
some considerations to this... B or RB blocks ?
remember the diff stroke height makes higher and wider location againts block or backwards, so then the starter
I have not seen yet diff headers for B or RB block to save this POSIBILITY
Re: mini starter [Re: NachoRT74] #672583
04/19/10 09:34 PM
04/19/10 09:34 PM
scratchnfotraction Offline
B/RB use the same TC and bell on the tranz
the wider part of a B/RB should be the heads not the tranz bell or starter location
they use the same tranz and starter and TC
well thats what I got from a 383 and a 440 in an A-body..wider at the VC not the block and tranz
guess it depaends on who is bending pipes and who has been out at lunch and bending pipes at the header factory
I have had the same part # and 2 diff header pipe shapes bends...one size to fit all kinda thing they did list them to fit 2x and 4x truck though they did not fit the 2x truck on the drive side
Re: mini starter [Re: scratchnfotraction] #672584
04/19/10 09:47 PM
04/19/10 09:47 PM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
well I took the torch and ball peen to it again and installed it tonight and have a good quater inch between the pipe and starter.after installing it I wish I would have ping a dimp next to a few plugs.
Re: mini starter [Re: stinger] #672585
04/19/10 09:53 PM
04/19/10 09:53 PM
mark it and bit the bullet,pull them off and clearance them now and be done
you will thank yourself later
they are not hot right now so get r done
Re: mini starter [Re: scratchnfotraction] #672586
04/19/10 10:33 PM
04/19/10 10:33 PM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
yeah I know
Re: mini starter #672587
04/19/10 10:33 PM
04/19/10 10:33 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
K frame was from 64 fury, mtr mounts correct big block mounts.
Re: mini starter [Re: pushbutton] #672588
04/19/10 10:40 PM
04/19/10 10:40 PM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
I don't see how the K frame or mounts would have anything to do with how far the Denso starter sticks out.
