Re: mini starter
[Re: stinger]
#672562
04/17/10 09:17 PM
04/17/10 09:17 PM
Posts: 433 St.Clairsville Ohio
EV2RUNNER
St.Clairsville Ohio
just a word of caution but this starter will not fit between the block and headmen headers,not sure on the other brands.
Big Block or Small with fitment issue? Mine fit on 383 w/ mini starter. ![](/ubbthreads/images/graemlins/Twocents.gif)
Re: mini starter
[Re: stinger]
#672567
04/18/10 02:36 AM
04/18/10 02:36 AM
DaytonaTurbo
Manitoba, Canada
Junkyard 90's dodge v8 ministarter fit perfect on my 440 with summit brand(rebadged hedman) headers.
Re: mini starter
[Re: DrCharles]
#672568
04/18/10 12:24 PM
04/18/10 12:24 PM
Posts: 463 Detroit Michigan
stinger
Detroit Michigan
my 440source mini starter fit with Hedman 78030's on a 451 (lowdeck), but not without a bit of massaging of one tube with a ball peen hammer and a torch
YEP ^^^^^^^^^^^
I would like to spring for another set but figure what's the point if I have to beat them into submission.
Re: mini starter
[Re: stinger]
#672569
04/18/10 12:52 PM
04/18/10 12:52 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
YEP ^^^^^^^^^^^
Because they cost one-fifth as much as the "perfect fit" types, which STILL sometimes require a bit of persuasion!
Re: mini starter
[Re: stinger]
#672572
04/18/10 06:03 PM
04/18/10 06:03 PM
Posts: 37 MI
Jerseyboy
MI
I just went through this on my 68 Coronet 383 with headman elite headers. I bought a starter for a 94 Dakota 318 and it wouldn't fit. The later model V8 starter (I checked a 2002 dakota V8) has a shorter motor then the earlier one. I probably could have fit the later starter. My local Auto store had them for $129 plus core. The Earlier unit was only $80 plus core. I ended up putting the original back in for now. I'm eventually going with a late model 6.1 based stroker so this is only a temporary setup for me and I decided to save the cash now.
Re: mini starter
[Re: stinger]
#672576
04/19/10 07:50 AM
04/19/10 07:50 AM
Posts: 15,487 Florida
scratchnfotraction
on my SB I have the hedman truck headers and can R&R the starter with out removing the header I can R&R the header with out removing the starter also I run the center dump mannys on the 440 and have lots of room what part# on the headers that are tight like in the pics?? cars only? any trucks this way? may just be the style of headers and body style together that does this ![](/ubbthreads/images/graemlins/popcrn.gif)
