Page 2 of 3 1 2 3
Re: Overheating [Re: j3wbagell] #669754
04/16/10 04:44 PM
04/16/10 04:44 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I assume my power steering assembly is the reason there is no fan connected to the front of my block. I have a multi belt system and if there were a fan there it would only get in the way. However, i have a dual fan setup attached to the radiator which shorted out during the original overheat when it spilled all over my driveway. assuming the current wiring for the fan is correct all i need for the radiator fans to run again may be...
http://www.summitracing.com/parts/HDA-3653/
Oh my, good luck.
Advise...wire the fans to be on all the time to begin with until you sort out the cooling system. Then maybe spend the money on a controller if you can get the pusher fans to cool the engine.
Like I said, good luck.
Re: Overheating [Re: Challenger 1] #669755
04/16/10 04:49 PM
04/16/10 04:49 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Power steering would not be a reason not to have a fan on the motor. The fan would stick into the shroud to where it would only be an couple of inches away from the radiator which would put it way out in front of the power steering. bThere will be either a clutch on the fan or a spacer between it and the pulley ythat will move it forward away from the belts.
Re: Overheating [Re: j3wbagell] #669756
04/16/10 04:50 PM
04/16/10 04:50 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Can you post a picture of your pulley setup.I'm just wondering what type of setup you have that a stock fan wouldn't work or power steering.When the car overheated it shouldn't have shorted out unless it wasn't wired right.
Re: Overheating [Re: gtx69] #669757
04/16/10 05:12 PM
04/16/10 05:12 PM
Cen Fla
j3wbagell Offline OP
Cen Fla
my camera takes fairly large photos, i've uploaded them into an album on photobucket you can view it HERE.
EDIT: if you are looking at the wiring, the blue wire gets tunneled into the green wire on the fan housing assembly and i think that metal thing is supposed to be a temperature probe but its just mounted onto the radiator with the c clamp looking thing that is insulated with foam in the picture on summit
Re: Overheating [Re: j3wbagell] #669758
04/16/10 05:21 PM
04/16/10 05:21 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
There is no reason you can't get rid of those electric fans and install a factory clutch fan back on that engine.
Re: Overheating [Re: stumpy] #669759
04/16/10 05:35 PM
04/16/10 05:35 PM
Cen Fla
Cen Fla
this may be true however at this time being a 19 yr old college student relying on the government and prepaid college terms, i am trying to minimize my budget to the smallest degree so if i can fix the current fan system i presume i will be happy. Is there really an improvement between a clutch fan and an electrical fan?
so far my bill runs me to a new water pump and thermostat. adding a clutch and fan may break teh bank plus i dont even know what else i would need.
Re: Overheating [Re: j3wbagell] #669760
04/16/10 05:41 PM
04/16/10 05:41 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
A lot. Most of the cheap electrics won't cool an engine. It takes a good strong fan set up to do it. Is the water pump leaking? Start with a new thermostat and get the fans blowing. Then see what you have. You may not need a wterpump. If $30 for a water pump and thermostat blows your budget then your are in trouble to begin with.
Re: Overheating [Re: stumpy] #669761
04/16/10 09:43 PM
04/16/10 09:43 PM
Cen Fla
Cen Fla
where can i find a water pump for 30 dollars? I have to hang the exhaust with new piping and tips, i saw an oe replacement on summit for 60 bucks but i never explored the links on the main page.
Re: Overheating [Re: j3wbagell] #669762
04/16/10 09:49 PM
04/16/10 09:49 PM
scratchnfotraction Offline
I offerd to help you before,you are close by
i understand the 19 and no $ in the budget
i have a good WP you can have and may have a good clutch fan as well
even have pulleys if you need them
that car just needs a little mopar help
Re: Overheating [Re: scratchnfotraction] #669763
04/16/10 10:08 PM
04/16/10 10:08 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You can get the thermostat and water pump at any local parts store. Why are you looking at the high priced stuff at summit? You don't have a race car. Most every thing you will need for that car can be purchased at the local parts store.
Re: Overheating [Re: stumpy] #669764
04/16/10 10:23 PM
04/16/10 10:23 PM
Staten Island, NY
RO23dave Offline
RO23dave  Offline
Staten Island, NY
I would think that if you're going to change the water pump, while you're in there check the timing chain. i'm wondering if the backfiring and overheating maybe chain related. do the chain stretch test, where you rock the crank back and forth while watching the movement of the distributor rotor. you'll have the water pump off so shouldn't be too much more trouble to check the alignment of the chain. my dave
Re: Overheating [Re: RO23dave] #669765
04/16/10 11:41 PM
04/16/10 11:41 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Change water pump and themostat and get fan working or change to clutch fan and shourd d
Re: Overheating [Re: stumpy] #669766
04/18/10 12:18 PM
04/18/10 12:18 PM
Cen Fla
Cen Fla
i truly didn't know the line between what auto zone would and wouldn't carry. Regardless they have to special order the WP and is just about the same price as summit.
Are the belt lengths written on them? I have some fraying and this is as good a time as any to replace them.
Scratchin i'll shoot you a pm.
Re: Overheating [Re: j3wbagell] #669767
04/18/10 12:31 PM
04/18/10 12:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Shop around online. O'Reilly's sells and stocks the water pump you need for less than $25.
Re: Overheating [Re: stumpy] #669768
04/18/10 01:17 PM
04/18/10 01:17 PM
North East Missouri
E
express Offline
express  Offline
E
North East Missouri
Unless the water pump is leaking I'll bet money it's not bad. I have never seen a water pump rust the impellers off.
CHANGE THE THERMOSTAT FIRST! This is a cheap fix. If the stat is stuck, the water pump is not circulating water to the radiator.
cny25421@centurytel.net 70 Duster Turbo Charged 79 Lil Red Express Bonded Locksmith
Re: Overheating [Re: express] #669769
04/18/10 01:40 PM
04/18/10 01:40 PM
Cincinnati, Ohio
Cincinnati, Ohio
He never said if it was leaking or not, probally never looked close enough to know.
If it ain't leaking, it's working. lol Like you said.
Too bad our government won't fix our cars yet.
Re: Overheating [Re: Challenger 1] #669770
04/18/10 07:35 PM
04/18/10 07:35 PM
Cen Fla
Cen Fla
i did say it was not leaking, i don't knwo the mechanics of a WP running to the auto shop now 180 stat? they have economy or superstat does it matter it's a 5 dollar difference?
Re: Overheating [Re: j3wbagell] #669771
04/18/10 07:41 PM
04/18/10 07:41 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
A stant brand thermostat is a good one. And I would get at least a 190* to get the engine up to optimum running temp. Any cooler than that and you are creating engine wear and poor combustion properties. A 190* stat is wide open at that temp and won't cause your enigne to overheat.
Re: Overheating [Re: stumpy] #669772
04/18/10 10:55 PM
04/18/10 10:55 PM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
190 stat
Slant is good, Robertshaw used to be a nice piece, had bid slots to let lots of flow happen.
You need an engine driven fan. Will save you a ton of heart aches.
Take Sracthin up on his offer
I want my fair share
Re: Overheating [Re: SomeCarGuy] #669773
05/29/10 08:19 PM
05/29/10 08:19 PM
Cen Fla
Cen Fla
Alright 195 stat in place eddy carb running fine slight hissing, but STILL OVERHEATING.
The fans are not yet functional but I only have water running through the block. I start to see steam coming from the radiator at about 5 mins of idle is the 195 to high of a stat or should regular coolant do the trick?
Page 2 of 3 1 2 3
