Re: Overheating
[Re: gtx69]
#669757
04/16/10 05:12 PM
04/16/10 05:12 PM
Posts: 149 Cen Fla
j3wbagell
Cen Fla
my camera takes fairly large photos, i've uploaded them into an album on photobucket you can view it HERE.EDIT: if you are looking at the wiring, the blue wire gets tunneled into the green wire on the fan housing assembly and i think that metal thing is supposed to be a temperature probe but its just mounted onto the radiator with the c clamp looking thing that is insulated with foam in the picture on summit
Re: Overheating
[Re: stumpy]
#669759
04/16/10 05:35 PM
04/16/10 05:35 PM
Posts: 149 Cen Fla
j3wbagell
Cen Fla
this may be true however at this time being a 19 yr old college student relying on the government and prepaid college terms, i am trying to minimize my budget to the smallest degree so if i can fix the current fan system i presume i will be happy. Is there really an improvement between a clutch fan and an electrical fan?
so far my bill runs me to a new water pump and thermostat. adding a clutch and fan may break teh bank plus i dont even know what else i would need.
Re: Overheating
[Re: j3wbagell]
#669762
04/16/10 09:49 PM
04/16/10 09:49 PM
Posts: 15,487 Florida
scratchnfotraction
I offerd to help you before,you are close by i understand the 19 and no $ in the budget i have a good WP you can have and may have a good clutch fan as well even have pulleys if you need them that car just needs a little mopar help
Re: Overheating
[Re: stumpy]
#669766
04/18/10 12:18 PM
04/18/10 12:18 PM
Posts: 149 Cen Fla
j3wbagell
Cen Fla
You can get the thermostat and water pump at any local parts store. Why are you looking at the high priced stuff at summit? You don't have a race car. Most every thing you will need for that car can be purchased at the local parts store.
i truly didn't know the line between what auto zone would and wouldn't carry. Regardless they have to special order the WP and is just about the same price as summit.
Are the belt lengths written on them? I have some fraying and this is as good a time as any to replace them.
Scratchin i'll shoot you a pm.
Re: Overheating
[Re: express]
#669769
04/18/10 01:40 PM
04/18/10 01:40 PM
Challenger 1
Cincinnati, Ohio
Unless the water pump is leaking I'll bet money it's not bad. I have never seen a water pump rust the impellers off.
CHANGE THE THERMOSTAT FIRST! This is a cheap fix. If the stat is stuck, the water pump is not circulating water to the radiator.
He never said if it was leaking or not, probally never looked close enough to know.
If it ain't leaking, it's working. lol Like you said.
Too bad our government won't fix our cars yet.
Re: Overheating
[Re: Challenger 1]
#669770
04/18/10 07:35 PM
04/18/10 07:35 PM
Posts: 149 Cen Fla
j3wbagell
Cen Fla
i did say it was not leaking, i don't knwo the mechanics of a WP running to the auto shop now 180 stat? they have economy or superstat does it matter it's a 5 dollar difference?
Re: Overheating
[Re: stumpy]
#669772
04/18/10 10:55 PM
04/18/10 10:55 PM
Posts: 10,307 Someplace you aren't
SomeCarGuy
190 stat Slant is good, Robertshaw used to be a nice piece, had bid slots to let lots of flow happen. You need an engine driven fan. Will save you a ton of heart aches. Take Sracthin up on his offer
I want my fair share
