Re: Transmission identification/ OD swap question [Re: kenworth_goose] #668890
04/15/10 03:01 PM
04/15/10 03:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The RH solenoids are also controlled by the PCM; the difference between the RH and the RE is the RE has no mechanical governor, a sensor in the tail takes the place of the mechanical governor.
Re: Transmission identification/ OD swap question [Re: John_Kunkel] #2705665
10/10/19 07:20 PM
10/10/19 07:20 PM
Canada
7t8warlock Offline
7t8warlock  Offline
Canada
Ok guys I need help , I have a 46rh 2 wire trans, so will a non lockup converter around a 2400 stall work with the overdrive . Engine is a la 360 . Running this converter in a 727 now . What else would I need to do this conversion as far as vacuum switches or just install a switch to engage the overdrive . Thanks in advance
Re: Transmission identification/ OD swap question [Re: 7t8warlock] #2705697
10/10/19 09:16 PM
10/10/19 09:16 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
it should work just fine, if its a good converter, I have a switch on my console for the OD
Re: Transmission identification/ OD swap question [Re: CSK] #2705708
10/10/19 09:37 PM
10/10/19 09:37 PM
BDW Offline
BDW  Offline
