Re: VIN Rivets, fender tag, and body stamps
[Re: 6bblgt]
#668764
04/14/10 04:09 AM
04/14/10 04:09 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Your core support and trunk lip should be stamped ?8R275854 with the ? replaced with A (Lynch Rd.), E (Los Angeles) or G (St. Louis).
It's a STL tag so the core should read G8R.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: 69CoronetRT]
#668765
04/14/10 07:49 AM
04/14/10 07:49 AM
Posts: 334 Detroit, MI
DetMatt
Detroit, MI
Are the scalloped vin tag rivets easy to find, I have a friend with a source for them, but I was just wondering and how much should you pay for a pair?
`68 Road Runner "JUNKYARD DOG"
`70 A66 FK5 Challenger, Rough project.
`68 Coronet R/T Black & white 4 speed.
`97 Dodge 1500 4X4, 228,000 miles and going strong!
[Re: 6bblgt]
#668766
04/14/10 10:47 AM
04/14/10 10:47 AM
Posts: 15 MA
Mattyweb
MA
"Not sure where you got any blue paint treatments/accents info?"
I got this from a couple different online decoders:
CAR: Plymouth RoadRunner 2 Door Hardtop ENGINE: 383cid 4-bbl HP V8 TRANSMISSION: 4-Speed Manual Floor Shift TIRES: F70x14 Red Side Wall, Steel Belted BUILD DATE: May 25. AXLE: 3.23 Rear Axle Ratio, Sure Grip INTERIOR: High Trim Grade, Vinyl Split Bench Seats. Black Interior. PAINT: Monotone Silver Metallic Paint. OTHER: Black Upper Door Frame Color. Bright Blue Metallic Racing Stripe.
MOLDINGS: 19: Wide Sill Mouldings 25: Drip Rail Mouldings
ABC OPTIONS: R1: AM Radio X1: Tinted Glass (all) Y6: Black Vinyl Top
abc OPTIONS: h7: Fender or Hood Mounted Turn Signal Indicators u1: Sold Car When Built (Somebody Ordered It)
Is the Bright Blue Metallic Racing Stipe not correct? That'll teach me to beleive anything I read off the internets.
Thanks for the info about the inspector stamp too. I got the tag off last night and it is clearer on the back and definately stamped from the back.
1968 Road Runner hardtop 440 4spd
2010 Ram 1500 Laramie
1992 Ramcharger
