Re: VIN Rivets, fender tag, and body stamps [Re: 6bblgt] #668764
04/14/10 04:09 AM
04/14/10 04:09 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Your core support and trunk lip should be stamped ?8R275854 with the ? replaced with A (Lynch Rd.), E (Los Angeles) or G (St. Louis).
It's a STL tag so the core should read G8R.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: VIN Rivets, fender tag, and body stamps [Re: 69CoronetRT] #668765
04/14/10 07:49 AM
04/14/10 07:49 AM
Detroit, MI
DetMatt Offline
DetMatt  Offline
Detroit, MI
Are the scalloped vin tag rivets easy to find, I have a friend with a source for them, but I was just wondering and how much should you pay for a pair?
`68 Road Runner "JUNKYARD DOG" `70 A66 FK5 Challenger, Rough project. `68 Coronet R/T Black & white 4 speed. `97 Dodge 1500 4X4, 228,000 miles and going strong!
Re: VIN Rivets, fender tag, and body stamps [Re: 6bblgt] #668766
04/14/10 10:47 AM
04/14/10 10:47 AM
MA
Mattyweb Offline OP
Mattyweb  Offline OP
MA
"Not sure where you got any blue paint treatments/accents info?"
I got this from a couple different online decoders:
CAR: Plymouth RoadRunner 2 Door Hardtop
ENGINE: 383cid 4-bbl HP V8
TRANSMISSION: 4-Speed Manual Floor Shift
TIRES: F70x14 Red Side Wall, Steel Belted
BUILD DATE: May 25.
AXLE: 3.23 Rear Axle Ratio, Sure Grip
INTERIOR: High Trim Grade, Vinyl Split Bench Seats. Black Interior.
PAINT: Monotone Silver Metallic Paint.
OTHER: Black Upper Door Frame Color. Bright Blue Metallic Racing Stripe.
MOLDINGS:
19: Wide Sill Mouldings
25: Drip Rail Mouldings
ABC OPTIONS:
R1: AM Radio
X1: Tinted Glass (all)
Y6: Black Vinyl Top
abc OPTIONS:
h7: Fender or Hood Mounted Turn Signal Indicators
u1: Sold Car When Built (Somebody Ordered It)
Is the Bright Blue Metallic Racing Stipe not correct? That'll teach me to beleive anything I read off the internets.
Thanks for the info about the inspector stamp too. I got the tag off last night and it is clearer on the back and definately stamped from the back.
1968 Road Runner hardtop 440 4spd 2010 Ram 1500 Laramie 1992 Ramcharger
Re: VIN Rivets, fender tag, and body stamps [Re: DetMatt] #668767
04/14/10 10:55 AM
04/14/10 10:55 AM
MA
Mattyweb Offline OP
Mattyweb  Offline OP
MA
I've seen them for $30-60 a pair ($15-30 each rivet!).
I understand it is illegal to even posess them so I am going to proceed with caution if I was to hypothetically think about finding a pair.
Re: VIN Rivets, fender tag, and body stamps [Re: 69CoronetRT] #668768
04/14/10 11:00 AM
04/14/10 11:00 AM
MA
Mattyweb Offline OP
Mattyweb  Offline OP
MA
Yup, the vin (rm23h8G) says St. Louis. How can you tell the fender tag was a STL tag?
Re: VIN Rivets, fender tag, and body stamps [Re: Mattyweb] #668769
04/14/10 01:19 PM
04/14/10 01:19 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
TIRES: F70x14 Red Side Wall, Steel Belted No steel belted tires in '68. They're actually NYLON cord. Goodyear SPEEDWAY
OTHER: Black Upper Door Frame Color. U/B - ok Bright Blue Metallic Racing Stripe. B/8 is the "buffed paint" - if it was S/8 - it would be a stripe code BUT there is no S/8 stripe in '68.
"8" is the paint code for "bright blue metallic" in '67.
Numbers when used for stripe colors are decals. (in '68)
Letters when used for stripe colors are paint. (in '68)
