Page 2 of 3 1 2 3
Re: almost D day! [Re: 8valves] #668447
04/13/10 06:34 PM
04/13/10 06:34 PM
ELYRIA,OH
blownzoom440 Offline OP
ELYRIA,OH
the IAT are 130/140 in the 1/4
i run just tap water 5gal total.
Re: almost D day! [Re: blownzoom440] #668448
04/13/10 10:10 PM
04/13/10 10:10 PM
SRQ, FL
8valves Offline
8valves  Offline
SRQ, FL
Interesting. Does the system have a heat exchanger in it as well?
Most of the turbo cars I deal with keep the intake temps from 40* at the line up to about 80* through the traps at anywhere from 145-200 mph, when using ice, of course.
Just curious, thanks!!
Aaron M
Re: almost D day! [Re: 8valves] #668449
04/13/10 10:14 PM
04/13/10 10:14 PM
ELYRIA,OH
ELYRIA,OH
no exchanger on the car.i have a radiator from a motorcycle to use.maybe under the trunk with a fan.i used ice a couple of times and melting 15lbs of ice each pass was interesting.
Re: almost D day! [Re: blownzoom440] #668450
04/14/10 12:23 AM
04/14/10 12:23 AM
Minnesota
RockChip Offline
RockChip  Offline
Minnesota
Looks really bad ass.
Lookin forward to the results!!!!
Re: almost D day! [Re: RockChip] #668451
04/14/10 08:25 AM
04/14/10 08:25 AM
ELYRIA,OH
ELYRIA,OH
Thanks.i am cleaning the headers getting it ready.i need to learn the LC-1 so i can use it.
Re: almost D day! [Re: blownzoom440] #668452
04/15/10 10:53 PM
04/15/10 10:53 PM
ELYRIA,OH
ELYRIA,OH
she will run saturday but she is hookedup all but the intercooler lines.
Re: almost D day! [Re: blownzoom440] #668453
04/15/10 11:25 PM
04/15/10 11:25 PM
ELYRIA,OH
ELYRIA,OH
here is 2 plg,header shots fot sunroofgtx.
Re: almost D day! [Re: blownzoom440] #668454
04/15/10 11:26 PM
04/15/10 11:26 PM
ELYRIA,OH
ELYRIA,OH
2
Re: almost D day! [Re: blownzoom440] #668455
04/16/10 06:15 PM
04/16/10 06:15 PM
ELYRIA,OH
ELYRIA,OH
would have it started today but the rear water plugs leaked.[screw in]i will have to take the engins plate off the back to get at them in the morning.scott put a lot of time on the throttle linkage today on my engine to make it right.THANKS SCOTT!
Re: almost D day! [Re: blownzoom440] #668456
04/16/10 06:21 PM
04/16/10 06:21 PM
ELYRIA,OH
ELYRIA,OH
1 of the leaks.i had to do the waterpump also.
Re: almost D day! [Re: blownzoom440] #668457
04/16/10 09:18 PM
04/16/10 09:18 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Wow, Mike. I can't believe the room you have around your plugs. I think our ProMod45 Boots will work great !Once you get it into your car, we'll get you squared away.. Thanks for coming over the other night. Good luck tomorrow. If Bills made a million, you should make 1.5 Million !!
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: almost D day! [Re: sunroofgtx] #668458
04/17/10 12:42 AM
04/17/10 12:42 AM
ELYRIA,OH
ELYRIA,OH
Thanks Rick!
Re: almost D day! [Re: blownzoom440] #668459
04/17/10 07:38 PM
04/17/10 07:38 PM
ELYRIA,OH
ELYRIA,OH
results and video to come.things went good once she was running with no leals and good oil psi.
Re: almost D day! [Re: blownzoom440] #668460
04/17/10 07:56 PM
04/17/10 07:56 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Wow, sweet.. Been waiting on pins and needles..
Re: almost D day! [Re: sunroofgtx] #668461
04/17/10 08:01 PM
04/17/10 08:01 PM
ELYRIA,OH
ELYRIA,OH
Re: almost D day! [Re: blownzoom440] #668462
04/17/10 08:58 PM
04/17/10 08:58 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
me too.LOL
http://www.youtube.com/watch?v=5jaJE_6H6pY
Quad numbers are very nice. Is this the first blown Koleno block?...ummm..I mean supercharged..lol
Re: almost D day! [Re: sunroofgtx] #668463
04/17/10 09:06 PM
04/17/10 09:06 PM
ELYRIA,OH
ELYRIA,OH
it very well could be.hay big bear!
Re: almost D day! [Re: blownzoom440] #668464
04/17/10 09:23 PM
04/17/10 09:23 PM
michigan
Steve Morris Offline
michigan
That looks a bit lean on O2's were you doing plug reads to verify the O2's ?
As far as cam tech goes there is quite a bit to look at on blown gas compared to blown alky and even blow pump verse's a good fuel like C16 in a higher heat app like a roots.
I do have a real good How to Tune Your Boosted Engine Video that I just released. I cover O2's, fuel flow, BSFC, dyno fuel systems, Timing, graph reading and Plug reading
Steve Morris
www.prochargervideos.com the best source for boosted tech videos.
Re: almost D day! [Re: Steve Morris] #668465
04/17/10 09:33 PM
04/17/10 09:33 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Steve !! Great to see you chime in. Ready for 2010? Waiting to get some lengths from you on a set of wires for the wagon!! Can I call you Monday?
Re: almost D day! [Re: Steve Morris] #668466
04/17/10 09:36 PM
04/17/10 09:36 PM
ELYRIA,OH
ELYRIA,OH
Steve Morris
no i did not look at the plugs.i suspect thay read leaner than actual.i will check the plugs tomorrow.
Page 2 of 3 1 2 3
